Getting there mate good job. I'm afraid to have a look below my sill covers god knows what kind of surprises are lurking lol.
Not sure what plans for the underneath you have but I used Lanoguard on the underneath of mine which is far better than waxoyl and seems to be doing a good job.
Reactions: <tuffty/>
I have some HB Body 955 Tough Liner to spray over the sills, floor pan and inner arches... will be cleaning everything first then spraying the high zinc primer then this tough liner stuff...
One of the causes for the spotty rust areas seems to be movement or friction related... so the idea is that if there is a friction resistant protection layer then the arch liners and sill covers won't rub the paint causing these potential rust areas to manifest...
Plus it should make the underside a lot more resistant to corrosion so hopefully keep her out of Chris "S3 Breaker" McDermott's hands for a long time to come :)
<tuffty/>
Reactions: hydro s3
@&lt;tuffty/&gt; how good is HB Body 955 Tough Liner...There is couple more bedliners on the market highly recommend.Herculiner,raptor...I like in general body products...Do you have previous experience with HB Body 955?
btw.Very nice job!Reason why I ask...I have to paint my beetle this month.Changing color.Is good idea to check and protect floor as well.
Thanks,
Djordj
Sent from my Mi A3 using Tapatalk
Simple answer... no idea.... :)
Raptor and this are more or less the same thing... not sure on overall durability but given I am not using it as an actual bed liner then should be durable enough...
Main reason for me using this over Raptor is that my local paint supplies place sell it... if I run out mid application then its easy to get and supports local business etc
I have some of the 740 2k thinners as well... I have got a shultz gun that I was originally looking to use to apply it with but I think I will give it a go with my spray gun instead... shultz guns are quite "spitty" and as I am doing this outside I would rather have a bit more control over the process
<tuffty/>
<tuffty/>
Thank you @<tuffty/> absolutely makes sense. It's very difficult and expensive to get one of these. I also can easily find body as well. I'm kind of doing the same thing as you on my car. I'll find more information online, but you have enough information to finish my stuff.Thank you again
Bit more progress...
Added seam sealer where it was needed...
PXL 20220503 190039001
PXL 20220503 190102793
I also wire wheeled all the factory sealer from the inside edge of the pinch rail too and seam sealed the cr*p out of that...
On to the rear wheel well and cleaned up corrosion in several areas of it...
PXL 20220504 171854069
PXL 20220505 185154802
PXL 20220505 170736749
Decided that not all the wheel well needed to be painted as it was mostly ok so tried the wax product I have instead as a test...
PXL 20220504 171909421
PXL 20220504 171922489
I think I will go to town with the wax anyway but its decent stuff from the looks...
On to the front area behind the wing.... My A pillar is in need of some work as its been bubbling for a long time... this was down to a poor windscreen replacement back before I owned the car... I will need to take the screen out to deal with it and almost certain I will need to make patch panels to replace the corrosion there... not looking forward to that job!
But one thing I did tackle was where some sealer had come away at the bottom of the A pillar...
PXL 20220504 175144984
PXL 20220505 190105118
I have since gone over it with seam sealer so that should slow things down until I get a chance to look at the A pillar properly
There were a few other areas that needed a bit of work...
PXL 20220504 175153389
PXL 20220504 175157156
PXL 20220505 170728093
PXL 20220505 190110904
PXL 20220505 190117403
Have also added some seam sealer and will wax this area once the paint is done...
One of the last little jobs I needed to sort out was the missing two holes for the sill cover fixings... which... are square!... so a 7mm drill and a flat needle file later and..
PXL 20220505 183023151
PXL 20220505 183740569
Nothing more to do now but mask up ready to shoot the high zinc primer and the bed liner under coat... to help me stand a better chance of getting paint underneath (using an air driven paint gun) I decided to invest in a new trolley jack...
PXL 20220506 092106910
Pretty sure I was close to tipping the car over with this but settled on a sensible height and had to break out the 3 tonne Halfrauds stands as I ran out of height on the 2 tonne ones
Much cleaning and masking then ensued...
PXL 20220507 154425358
PXL 20220507 154432315
PXL 20220507 154444771
Followed by paint gunnage!
PXL 20220507 163451273
PXL 20220507 163459192
PXL 20220507 163529427
PXL 20220507 163544750
PXL 20220507 163556598
PXL 20220507 163605512
I am hoping to grab some 2k thinners tomorrow so I can shoot the bed liner product... I could just use the shultz gun I have but they are a bit spitty and I am outside on axle stands... not really much fun... once I have some thinners I can mix up smaller batches of the product and lay it down much better with the gun..
I decided to poke the wings rust with the pointy end of my panel hammer...
PXL 20220505 190521045
Bit of weld and a grind should sort that...
Nearly there on the drivers side... passenger side next!!! eeep!
<tuffty/>
Reactions: hydro s3
Nice.
I've not used S50 but was pretty pleased with the Dynax UC I used on the TT last year.
Nice.
S50 is supposed to be quite thin initially allowing it to seep into crevice's (fnarrr)... given the level of vehicular dismemberment the old girl is currently undertaking I think I will just spam it everywhere :)
Trying to be marginally realistic too as I want to leave some areas obvious for when a body shop takes her on for the respray... rather than do half a job and cover it up so to speak
<tuffty/>
Amazing as always PT! it’s really nice to see someone going to all this effort continuously with these cars. I know there are less and less of them about, but still….. it inspires the ones that do have them to keep them going and not send them to the McDermott graveyard
Managed to grab some 2k thinners so game on!
PXL 20220508 123955800
Went on nicely....
PXL 20220508 135145009
PXL 20220508 135151325
PXL 20220508 135202214
PXL 20220508 135223740
Painting under the car was as always a mahoosive challenge... I did get quite a bit of coverage but I think I might just go over the trickier to get areas with a brush at a later date then I will be waxing the flip out of everywhere :D
That signalled the end of the main work on the drivers side... I have fitted anything back yet and still need to wax things but will do that after I have finished the rust repairs and paint work on the passenger side... and to that end I turned the car around and jacked up the passenger side... removing all the trim and the sill covers came a lot easier this time... however...
...rear wheel tub...
PXL 20220508 145219912
PXL 20220508 145222694
PXL 20220508 145227896
PXL 20220508 145232285
Rear jack point...
PXL 20220508 145252907
...and of course the front jack point...
PXL 20220508 145309425
*sigh*
At least I have a better idea of what to do now so hoping this will go a bit smoother... thankfully the uppper sill area looks a lot better than the drivers side did
PXL 20220508 152045896
As does the the bottom of the door
PXL 20220508 152127619
PXL 20220508 152131521
See you in a couple of weeks :)
<tuffty/>
Reactions: desertstorm, hydro s3, craigt1985 and 1 other person
Posting latest progress as rain has stopped play :(
Passenger side is generally 'rustier' in terms of surface and general scabbiness... the hole in the sill was about the same as the drivers side but this time the floor pan faired much better...
PXL 20220509 160114715
As per the drivers side I added in a 3mm thick to add a bit of strength
PXL 20220510 153414119
PXL 20220510 154813230
Not sure if I will add the extra angled bit of steel like I did to the drivers side but that was more to make up for the state of the floor pan than anything (and also my dodgy welding!)
Cut a section from the A3 sill panel and took to it with grinders and hammers...
PXL 20220510 163846041
PXL 20220510 165907529
Then threw some molten metal at it in some hope it would stick...
PXL 20220513 164435878
The pinch rail looks a bit lumpy but thats by design... (my design at least lol)... I wanted make it form around the protruded spots caused by adding the 3mm strengthening plate and tabs from the internal sill strengthening assembly... this will mean less of a gap to fill with seam sealer...
Cleaned up the 'nose' of the sill... as per usual there was pitting and thin metal as I gave it a gentle tap with the pointy hammer... basically ended up spending 20mins with the MIG chasing blown holes to add metal back... all worked out and now solid...
PXL 20220513 164440814
PXL 20220513 184024740
With the wing off I could see the seam sealer was gone at the bottom of the A-pillar much like the drivers side...
PXL 20220513 184126154
So will clean that up and so the same as I did there
PXL 20220513 184133661
On to the rear jack point... I straightened out the crumpled metal by first hammering it flat then pulling down the return lip...
PXL 20220514 124611285
PXL 20220514 124631032
This was then wire wheeled to remove the factory seam sealant in prep for paint...
The rear wheel tub was definitely worse than the drivers side with a lot more rusty scabbiness... had to remove all the seam sealer at the bottom to ensure I got to it all...
PXL 20220514 140839676
PXL 20220514 140842785
Also had bubbling on the outside of the arch but this thankfully turned out to be surface rust and not coming from inside... at least from what I could see... I will be removing the rear cards later to wax things at a later date... hopefully there won't be anything lurking...
PXL 20220514 140847239
Getting into the crevice to clean out the rust was tricky but after a good scrape/rust conversion later I prepped the sill and arch for etch primer...
PXL 20220514 170902833
PXL 20220514 170910109
PXL 20220514 170921320
Then zinc primed by hand the areas in the arch I wanted to seam seal...
PXL 20220515 113420666
And splodged the sealer all over...
PXL 20220515 115137964
This stuff is quite tricky to apply nicely so will let it go off then try a final smoother coat with a bigger/stiffer nylon bristle brush...
It was at this time the heavens did open so played a few rounds of Infantry only on BF2042 with my mate instead... happy days :)
bit more sealer to apply, bit more old sealer to remove and to work on the front wheel well then I can mask and zinc prime the lot followed by the tough liner
...once its stopped raining of course
<tuffty/>
Reactions: s3mad_dude, S3 Rav and S3AMJ
Rotting sill saga update!...
Spent some time digging out the factory sealer from the inside of the pinch rail... it was partially separated from the return so made sense to clean this up and re-seal
PXL 20220517 152935942
...etch primed the bare metal followed by high zinc primer then splooged a load of brush on seam sealer to top it off...
PXL 20220519 185658426
Dealt with the rust around the fixings for the sill cover...
PXL 20220518 160751438
Flatted, rust converted and etch primed...
PXL 20220518 163532359
PXL 20220518 163541593
A few bits left to sort before masking up to do the main painting...
PXL 20220519 161511736
PXL 20220519 161515675
PXL 20220519 172835673
PXL 20220519 185639118
This was better on the passenger side than the drivers oddly...
PXL 20220519 172831051
PXL 20220519 185636003
Next job was to degrease the underside with APC and degreaser then on to the masking...
PXL 20220520 175935449
PXL 20220520 175943410
PXL 20220520 180054894
Rain stopped play (again) but thankfully today was loverly soooooo....
PXL 20220521 123708923
A few coats of zinc primer followed by a few coats of 955 Tough Liner coating...
PXL 20220521 160906100
PXL 20220521 162151089
PXL 20220521 162205002
PXL 20220521 162325895
PXL 20220521 162333648
PXL 20220521 162747781
Happy days.... I have left one of my wings with my local paint shop to mix up 1/2ltr of silver base coat... I will need this for the wings at the very least but I think I will paint the sills in too... will give me a bit of practice prior to trying to blend the paint on the wings... not convinced I will do a brilliant job (first time and outside etc) but tbh as long as it looks ok from a distance it will be fine until I get the car actually professionally resprayed...
After all the object is to remove the rust and protect from it coming back... if it kinda looks the right colour then that'll do for now :)
One thing I also plan to do is to clean everything and everywhere thats typically hidden...
PXL 20220521 170741927
With the rear bumper removed it was pretty mucky so will clean up all the plastics and metal brackets along with the inside of the bumpers, arch liners and sill covers before refitting...
I also need to finish off the cavity wax application too but I am waiting for the paint to dry off a bit first so might sort that tomorrow after cleaning things...
<tuffty/>
Reactions: hydro s3, desertstorm and S3AMJ
Busy day doing all the things.....
The A3 sill doesn't have the holes for the sill cover fixings so had to add a couple like I did on the drivers side...
PXL 20220522 102245228
Pilot hole followed by a 7mm drill...
PXL 20220522 101605856
...a bit of fettling later using a flat needle file and...
PXL 20220522 102250589
With that out of the way I could crack on with the giving the car a good waxing!!!
PXL 20220522 102915257
Basically went mental applying this stuff mostly everywhere... in the sills, in the wheel wells and the floorpan/inside lip of the pinch rail...
PXL 20220522 111102280
PXL 20220522 111107308
PXL 20220522 111120314
PXL 20220522 113936801
PXL 20220522 145845757
PXL 20220522 145853506
I applied the wax before adding new bungs then went over the bungs with wax just to seal them in...
I did this on both sides which involved dropping the car off the stands and turning her round (the VR sounded soooo good!) but before I used the jack I added powerflex jack pads (the Mk1 TT comes with similar pads from the factory)... the idea being I will use these to jack the car up from rather than the jack points...
PXL 20220522 115158665
PXL 20220522 115437556
PXL 20220522 115442849
However... there is a problem with the fronts... the rear box section the pad fits into is solid as a rock but the front is not quite as solid and... using the jack on the pad up front actually dents the floor up... there is a cavity it dents into so does not push into the cabin but something to be aware of all the same if you plan to use these...
PXL 20220522 142245268
Personally for me its the lesser of two evils... I can live with the dent in the floor vs potentially damaging the jack point again despite reworking it... truth be told I would rather not have to do all this work again in a few years!
Next job is to clean things....
PXL 20220522 120333841
Cleaned up the rear valance...
PXL 20220522 122021631
...cleaned up the arch liners...
PXL 20220522 125400151
PXL 20220522 125405685
...bit of rubbage from when I ran the car lower and on 235/40/18's... will look for some replacements at some point but for now these will do
Cleaned up all bumper plastics too...
PXL 20220522 134455431
...as well as painting the screws :)
PXL 20220522 134510836
Took the insert out of the rear bumper... this was full of crud...
PXL 20220522 152221381
Cleanage...
PXL 20220522 155110432
PXL 20220522 155129522
Assembly of stuff....
PXL 20220522 162635050
PXL 20220522 162821373
PXL 20220522 164700633
Also cleaned the front bumper...
PXL 20220522 181001776
...and the front of the car...
PXL 20220522 180633942
Like I said... busy day :)
<tuffty/>
Reactions: vanilla_ice, hydro s3, S3AMJ and 1 other person
More progress... home stretch now :)
Prepped and painted the rear bumper mounting hardware...
PXL 20220523 205448625
Used PPF where hardware fixings were used to mitigate potential metal to metal rubbage...
PXL 20220525 144958923
PXL 20220525 145005205
...and replaced the rusty bolts with stainless ones...
PXL 20220525 145027460
Next task was to work on the wings.... both had the usual stone chip damage at the lower part of the return...
PXL 20220525 160135543
So much wire wheel action later...
PXL 20220525 171623754
PXL 20220525 171639897
PXL 20220525 171646611
Getting into the lower area on the inside of the wing wasn't the most fun...
PXL 20220525 171630694
...many different wire based attachments were used including a few on the dremel... managed to get it to a point I was happy to let the rust converter do the rest of the work...
PXL 20220525 175607685
Bit of prep and masking later....
PXL 20220525 183952140
The drivers side wing has a pinhole that had rotted through so prepped that...
PXL 20220527 151752122
...for a little bit of galvanised steel as a backstop patch...
PXL 20220527 153640390
PXL 20220527 153825255
Welded, ground and etch primed...
PXL 20220527 163041517
...I also gave it a light skim of filler to fill the remaining flaws.... this was followed by a healthy dose of zinc primer....
PXL 20220527 183754834
PXL 20220527 183819671
Once dry it was on to the seam sealer...
PXL 20220528 095019923
PXL 20220528 095027199
...and finally treated the inside and the outside of the lip to some 955 Tough Liner... this "should" give it a bit of stone chip protection...
PXL 20220528 134033116
In the week I picked up some base coat...
PXL 20220526 141216890
...this was colour matched to one of my wings so hopefully will be fairly close... much masking and cleaning and yet more rust removal ensued...
PXL 20220528 125603976
...followed by a top up of the tough liner...
PXL 20220528 134045081
The next bit was a tad scary to say the least... not actually sprayed a basecoat using what could arguably be called "proper equipment"...
PXL 20220528 142901167
Eeeeeepp!!!...
PXL 20220528 144807505
I did use rattle can clear coat though but in fairness it was a decent product that I have used before and goes on really well as well as being a "2K" based product like the base coat...
PXL 20220528 154335975
Unfortunately my lack of experience and quite possibly a little bit of rushing to get it done in a timely fashion so the neighbours wouldn't hate me too much lead to a couple of rooky mistakes :(
Clearly I hadn't left the tough liner to dry enough which created a reaction to the base coat (both are 2K products)....
PXL 20220528 152730614
PXL 20220528 154242975
...plus I totally forgot to sort the masking out properly and create a couple of feathered mask areas so I could fully paint over the tough liner...
PXL 20220528 154026559
Both are fixable... and I know better for next time but the pressure of the potentially variable weather and not wanting to leave the car masked up over night got the better of me... DOH...
Joys of doing this outside the front of the house... along with this of course!
PXL 20220528 152946288
Ah well... passenger side to do (better hopefully) and then some work on the wings before I blow them over with silver...
<tuffty/>
Reactions: hydro s3, Djordje1 and S3AMJ
Eeeeeepp!!!...
<tuffty/>
Step by step you'll paint the whole car by yourself :)
Make sure you are using anti-silicon and tack cloth. That should help with the strange things you get on the paint. It's clearly happening in the corner, that might be some grease or something like that.
1653770915237
1653770835837
It was freshly painted in the morning with tough liner, keyed with grey scotchbrite, cleaned with degreaser and tacked off... Only thing I can think of is I hadn't left it long enough but hey ho
<tuffty/>
Reactions: Djordje1
The weather is seriously getting in the way of progress which is a little annoying as I am close to having the car drivable again...
Sunday was mostly a bust... I managed to fit the new fixings for the sill cover... I used a little RTV too to help seal and prevent them moving around potentially damaging the paint which I think will be tougher than ever now...
PXL 20220529 111703809
...then it rained... so played games for a few hours... but it cleared up for a while and ran out to sort the rear valance out so I could get the rear bumper on properly... there were a few little spots of rust to deal with...
PXL 20220529 182539304
PXL 20220529 182543345
...and managed to get some etch primer on too but it was far too late to get the compressor out so this afternoon after work I ran out again and gave the valance a couple of coats of zinc primer then after a bit of time a couple of coats of 955 Tough Liner
PXL 20220529 184114945
PXL 20220530 145906741
PXL 20220530 160230477
Will let that harden over the next day or so then I can get the rear bumper refitted...
I also dug out some parts I have been sitting on for about 5 years... I had been saving them for when I got the car resprayed but now seemed as good a time as any..
PXL 20220529 202458184
The grille is essentially brand new but I have painted the chrome surround black... the guy I got the kit from had got the parts painted... looks a bit better than mine at least...
PXL 20220530 181154573
They had been fitted to the car before he broke it for parts so I need to clean the insides a bit and do some mitigation work on the blades to prevent them from potential future corrosion issues...
One last thing I have had through the post recently are these...
PXL 20220529 203222891
I have a spare subframe and front arms that I need to de-rust and paint... I was going to get them powder coated but I am impressed with the zinc primer/tough liner combo so as I have the paint and the kit I think I will just paint them myself... the tough liner is designed for truck beds so should be hard wearing enough for a subframe and arms...
<tuffty/>
Bl**dy showers and other unforeseen wibble has given me a hard time on the passenger side...
Mostly inexperience too tbh...
Colour match on the wing is not great but... This was to be expected as this wing has been painted before and I gave my factory painted wing to the paint shop so is a better match to that... Granted I think I could have blended it better but I haven't really got a clue what I am doing sooooo... There is that!
PXL 20220531 174557721
PXL 20220531 174553438
Had some reactions with the tough liner on the sill... Thinking maybe a sealing primer would have been useful but again no experience of such things...
PXL 20220531 174624975
PXL 20220531 174618582
...and the great outdoors is great!!!... (apparently)
PXL 20220531 174609544
At the end of the day... Rust has been dealt with... Some paint and other animals has been applied for protection.... It's kinda oneish colour... I know I can do better with more experience and advice I am sure but given the circumstances of doing this outside etc I am pretty happy with the result
PXL 20220531 174135531
It was never going to be showroom and was always going for a proper paint job but at least the vast majority of the corrosion (and a couple of rather big holes) had been dealt with...
One wing left to sort... A potential revisit to this wing maybe and then the doors which again is damage limitation rather than showroom finish...
...oh and the bl**dy "A" pillar... as that's getting nasty
<tuffty/>
Reactions: hydro s3
While the weather is being all weathery as per usual I haven't been able to get the other wing painted... so just cracked on with a few jobs that are weather agnostic...
Essentially cleaning things and getting trim etc refitted... first up was refitting the rear bumper...
PXL 20220601 173745975
Unfortunately the top trim for these appears to have "warped" and is not fitting as it should... its held on by two screws at the side and held to the bumper by the heavy duty velcro VAG are so fond of... only problem seems to be that the warping is applying tension stronger than the double sided tape I was using for securing the velcro... no pictures as yet as I need to come up with a solution to that so will cover it later..
Anyhoo... with the car back together enough I thought it best to wash the old girl after 2 months of hammering, grinding, welding and other animals... I knew that there was a covering of grinder debris so out with the iron-x (well... Korrosol...) ... boy oh boy did she bleed!
PXL 20220603 142442797
PXL 20220603 142635585
Now that she was clean I moved on to the trim... I can't really fit the blades at this time as I want to leave the sills a bit longer for the lacquer to fully go hard and the rear blades are attached to sill covers and I still need to address the bottom of the doors before I can fit the door blades... I have however machine polished all the replacement trim parts and dressed everything else...
PXL 20220604 143356313
Grabbed a window of opportunity in between the showers to fit the bumper trim...
PXL 20220604 145554902
PXL 20220604 145605501
I still need to clay bar the whole car followed by a quick once over with the DA but she looking like a car again...
I have cleaned and polished one of the sill covers... looking at the state of it underneath I think when the car gets a full paint job I might look at PPF for the sills and a couple of other areas... talking of PPF... one cosmetically challenged area on the S3 is the rear sill cap or more specifically the "PPF" on the lower part of the sill cap...
This stuff looks a mess particularly on light coloured S3's like mine and one of mine (I have seen this on other S3's too) was painted (from a previous 'repair')
PXL 20220516 152049184
I did make a start of trying to get this off in one piece but its more like a flexible gel than a film and proved a right royal PITA to remove and certainly not in one piece... I left that one and tried one of my spares instead...
PXL 20220516 152614781
PXL 20220516 155759874
Took a bit of effort, a little heat too but the best method seemed to be to roll it up with your thumbs... this did the job (slowly) and left the least amount of residue to clean up after... for which I used IPA and degreaser...
If you do it wrong then it becomes a complete nightmare to clean up after...
PXL 20220604 174423252
As you don't appear to be able to buy replacements for this I tried a bit of left over Lamin-X that I had used for a set of headlights in the past...
PXL 20220516 161845221
PXL 20220516 162802208
This was a scrap bit hence the imperfections but it was a proof of concept so wasn't too worried... the plan was to buy new if it worked.... which....
PXL 20220518 170420361
PXL 20220518 170427385
...it didn't :(
Lamin-X simply isn't sticky enough... so I ordered up a small bit of "3M" PPF (eBay... so probably not 3M) and tried again...
This faired a little better but I had made a template from the lamin-x bit and I think this was the wrong way to do it as I found using heat made it easier to work with and if I had not cut to shape I could have easily gotten rid of the creases...
PXL 20220603 185807939
PXL 20220603 185814921
But it held on so have stripped both end caps and cleaned them up to have another go later to see if I can be a bit more successful... that said I am also tempted to PPF the whole end cap given the stone chip damage...
PXL 20220603 185824886
Not a fan of using PPF all over the car like some but I think its worth considering using sparingly in places prone to stone chipping like the sill covers, inside return edge of the front wing and maybe the underside of the front bumper...
Hoping the weather will hold off enough for one day next week so I can paint the wing... I can then actually fit the front bumper properly and be able to drive the car again...
<tuffty/>
Finally a dry day!!!... weather has been a bit of a challenge of late but the sun was out and so was the compressor!!
Drivers wing was already prepped and ready... been watching a few vids on you of tube on painting and blending stuff... so thought I would give it a go...
PXL 20220606 180327125
Base coat went on a bit better after faffing with the gun settings a bit...
PXL 20220608 151739150
PXL 20220608 151746307
Clear coat was aerosol though, HB Body 496 2K HS Clear... its one of the nicest clears I have used and compatible with the 2k base coat I am using... it was a bit of a challenge to lay it down though due to the wind... always something with the flippin' weather!!!
PXL 20220608 153405297
Its a little duller than it normally lays down but I will give it a few more coats later as ironically the weather started to cloud over and it was looking like it might rain (which it eventually did!)
PXL 20220608 190501274
The colour match actually looks decent but I will see once I have given the wing a once over with the DA... either way this was more successful than the passenger side so I am going to revisit that wing a bit later and see if I can get a better result now I have had a little practice...
While waiting for the wing to dry enough to be handled I moved on to the front brakes... I had noticed the rotors had started cracking in the grooves which is a shame as they were generally fairly decent still...
PXL 20220608 163207282
They have had a good innings mind... Bill had retired them from the Badger Wagon some 5 years ago as they had a few micro cracks... so I fitted them to the car and been using them ever since :)
They have lasted well but they needed to be changed so got some rotors from Reyland Motorsport...
PXL 20220608 115245778
PXL 20220608 163203417
I also had new pads... Mintex M1155's like before as I kinda like them...
PXL 20220608 170719556
I had cleaned up my old bells back when I fitted Bills rotors as he had gone over to a floating disc setup so I used the discs complete with his old bells (which is why they have extra holes as was drilled for 4 x 100)
New bolts fitted (also from Reyland) and on they went...
PXL 20220608 172843598
Just need to let the clear dry a bit longer then I can fit the wing back properly along with all the bracketry etc... I have finished off the passenger side fitting the A pillar/door jamb splash guard trim and the arch liner...
Once the drivers wing is done I will be able to safely drive the car... quite looking forward to that.. :)
<tuffty/>
Reactions: desertstorm and S3AMJ
Sooooo.... I have been driving the car :D
Front wings are fully bolted up and all relevant plastic parts are on... feels nice to be driving the old girl again...
Not a massive fan of the drivers wing overall finish... in the sunlight its really difficult to tell the "blend" but in shadow its quite obvious... the paint appears to be a darker tone overall which in itself is fine but I think I may actually revisit both wings and just repaint them all over... at the end of the day they are silver, the rust has been removed and future corrosion issues mitigated (hopefully)...
I had left the sill covers off for the time being as they needed a little tlc... and by tlc I mean sorting the crack that the jack made when it went through the sill!!!
First up... drill a hole to stop the crack from growing...
PXL 20220616 120853529
PXL 20220616 120903387
Used some aluminium tape to hold the crack together... its got no flex so holds stuff like this well
PXL 20220616 121106253
The scuff up the back to help with adhesion...
PXL 20220616 123114388
I had watched more than a few youtubes on plastic bumper crack repairs and there are a fair few ways to do it... some requiring a substantial investment in kit!!... so I decided to go cheap and step it up from there if needed :)
PXL 20220616 123234410
The metal mesh is to help reinforce the the epoxy... seems to have worked ok....
PXL 20220616 161647916
PXL 20220616 161658589
There was some damage on the other sill cover too...
PXL 20220616 161711221
PXL 20220616 161724633
Once that had set I took a dremel to the other side and dig out a groove for the epoxy...
PXL 20220616 163924867
PXL 20220616 163917384
...and all done :)
PXL 20220616 190505177
PXL 20220616 190557201
PXL 20220616 190543033
Its sorely tempting to finish these off now and paint them but they are plastic and given my level of experience so far I think I will practice on some spares I have plus I will need to get some special "stuff" to allow the paint to work with the plastic shizz...
I think for now I will just fit them as is though as I have plenty of other things to sort out first and in anticipation I cleaned up the screws and painted them :)
PXL 20220616 195553142
Next up will be sorting the bottom of the doors...
<tuffty/>
Reactions: hydro s3 and S3AMJ
Interesting you've moved from tech -> mechanical -> body work....
Will you start making your own oil next? :D :D
It's a great commitment as usual Tuffty ;)
Thanks dude :)
More of a case of having too.... getting to that stage if you want to keep and maintain a 20yr old car then you have to broaden your skill set somewhat...
Its been a bit of a learning curve but its been fun (other than the weather) and have learnt a lot... while I would like to have been able to get better results from the painting side of things I am under no illusion as to the limitations I am working with and happy with the results so far....
The biggest take away from it all though is the amount of time the actual prep work takes... the painting side of it is over very quickly... it takes longer to clean the gun after painting than the painting does... the masking and other prep work is the real killer time wise... I have spent most of a day working up towards paint with masking, cleaning, keying etc...
Painting using a compressor and spray gun is very addictive though... more so than using cans for sure :)
<tuffty/>
Decided to take advantage of the nice weather to start sorting the bottoms of the doors... went in heavy with the wire wheel to reveal what I already knew was there...
PXL 20220620 160344013
PXL 20220620 160354442
PXL 20220620 160406004
PXL 20220620 160411471
PXL 20220620 160505179
Out came the MIG and I threw some metal at them...
PXL 20220620 163651532
PXL 20220620 170430357
PXL 20220620 170432846
PXL 20220620 170435531
The metal was getting quite thin and was blowing holes left right and centre... trying to get a decent angle to grind back the welds was proving to be interesting too... so I will try getting her back up on stands to see if it helps... failing that I will look to swap the door with my dented spare and then work on it at my leisure...
I called it a day on that work for now and just etch primed over it for now... wanting to actually achieve something today I fitted the sill covers...
PXL 20220620 185239645
PXL 20220620 185254616
Also fitted the passenger side but only the front section and not the end cap as I still have a bit of filler to sand and paint on the rear arch...
Looking more like an S3 every day :)
<tuffty/>
Reactions: hydro s3
Jacking the car up gave me better access to the door... so made a small plate to fill the large hole on the corner of the door
PXL 20220623 160753941
PXL 20220623 160800784
Tacked that in and then decided it would be easier to remove the window frame to get to the inside of the door... I also removed the lower crash bar to be able to see what I was doing a bit better
PXL 20220623 165336343
PXL 20220623 165340868
Not pretty I know but never said I could weld :)
While the door was this dismantled I took the opportunity to swap out the door lock...
PXL 20220623 165353001
PXL 20220623 165606716
PXL 20220623 170203515
PXL 20220623 170220597
I little fiddly but pretty straightforward and works like a charm....
Back to the "welding" (I use the term loosely lol) I threw a load of metal from the inside of the door as this was actually easier to do than welding from the outside... this is where the fun began!!!... the steel seems quite thin at this point probably due to the folds in the steel stretching it a bit plus the corrosion... this meant I was faffing with the MIG settings quite a bit as I was essentially chasing blown holes in the door... the result of which is not pretty at all!!!...
PXL 20220623 175952735
But it did give me a bit more to work with on the outside..
PXL 20220623 180004058
PXL 20220623 180022457
PXL 20220623 180024631
PXL 20220623 180026748
Needs a little more work and have ordered a power file to be able to get a bit more control over finishing the weld on the edge as I want to minimise the amount of filler I will end up using...
I also need to get the hammer and dolly out I think as chasing the holes warped the area around the weld a bit :/
PXL 20220623 180853496
I really don't know how this will end up at the moment... I still have some pin holes to fill and grind back and one blown hole to fill... there is also the issue with the blade mount pins... most are corroded which in itself is no biggy as there are 4 screws holding the blade in place but I would ideally like to do something with the bad ones and one idea is to use part of a nail... drill a hole where the old pin was, cut the head off a suitable nail and weld it in... that is of course assuming I can recover the door well enough...
I do have another door but its dented and not sure if thats more work to sort out than what I am doing to my current door...
PXL 20220623 180328869
PXL 20220623 180332281
PXL 20220623 180323775
PXL 20220623 180336945
Will see how I go but I think I will be looking out for a replacement door all the same... be silly not to get a minter if I can for the respray
<tuffty/>
Reactions: Bempa and hydro s3
While the weather has been a bit variable of late I cracked on with some other work... some on the A2 as she needed a little TLC and a bit on some parts for the S3..
I have a spare set of front cast arms to refurb... borrowed a bush smasher (fnarr) kit from a mate...
PXL 20220702 142849436
...and removed the old bushes...
PXL 20220629 194652351
The kit won't always remove the alloy bush surround though...
PXL 20220629 194658007
...so a hammer and cold chisel made short work of those :)
Wire wheeled and aqua blasted the arms before masking the relevant machined surfaces
PXL 20220630 161703691
A few coats of UPOL Etch Primer....
PXL 20220630 184952685
Followed by a couple of coats of Manor High Zinc primer...
PXL 20220701 130210973
...and finished off with HB Body Tough Liner...
PXL 20220701 144805282
PXL 20220701 203210901
All the machined surfaces were then chemically blued...
PXL 20220701 203213895
PXL 20220701 212714678
...and then fitted the Powerflex Black Series bushes
PXL 20220702 131154684
Will sort the subframe out when I do the DSG swap and fit all the refreshed items then...
Hoping to get the bottom of the doors painted this week then onto the DSG wiring
<tuffty/>
Reactions: Djordje1, Bempa and s3mad_dude
Weather was better (ish) for long enough to get some work done on the car... I removed the drivers seat... mainly to be able to make a start on cleaning the interior as its dusty AF but also to try an minimise the amount of dirt/dust that gets on the alcantara as its a beatch to clean...
PXL 20220704 171401125
PXL 20220704 171415163
F$%k me S3 Recaros are heavy!!!... it was not the most fun in the world I have had getting that up into my loft office!!!... one thing I did find though was...
PXL 20220705 124300723
PXL 20220705 124255238
Appears to be a limit switch for the electrics... I never adjust the seat so tbh no idea how long its been like that or which part of the adjustment this limits but I will try and fix that back on later
Anyhoo... I spent a bit of time trying to knock as much of the rippling out as I could then broke out the filler...
PXL 20220704 175740329
PXL 20220704 181626363
PXL 20220704 184057978
Not perfect but I actually have a pair of unmarked doors on the way so they will be used when the car eventually goes for a proper paint job...
Masked up the lower part of the door and threw some paint at it... I still have a lot to learn about using an airgun and proper base coat... first attempt I think I was spraying far to much paint and it ran like forest gump on acid.... like that flash off and wet sanded back down... attempt 2 went better... a little streaky which apparently is common with silver but flashed off ok... then applied the clear coat (HB Body C496 2k clear in a can)... the C496 is great clear but a little thin so easy to get runs... which of course I did... but they will be easy enough to deal with once the clear goes off hard...
Given I am a complete amateur and I am doing this outside the house on the road I am pretty happy with the results...
PXL 20220705 173539483
PXL 20220705 180630718
PXL 20220705 180637405
I still can't blend for toffee of course...
PXL 20220705 180622939
...but the paint job is functional and will do for now...
While waiting for the paint to dry enough to feel comfortable removing all the masking I addressed the rust repair I had done on the nearside rear arch...
I had put filler in it a while back but not done anything with it until now... so flatted the filler down and primed it...
PXL 20220704 175730055
PXL 20220704 184047674
Then sprayed it silver....
PXL 20220705 180121874
Yes its a rather pants match but this is the same issue as the nearside front wing... this side has had paint... its darker than the factory paint that I had the basecoat matched too... tbh its now rust free and protected... it also acts as a reminder to the bits I have attacked so the body shop can see where I have attacked it all and make a call on if it needs reworking or not...
Next job will be to sort the nearside door...
PXL 20220705 182303635
This side is rust free but as it was repainted before the paint is flaking off so will clean it up and give a blow over... I am less concerned about the doors now with the replacements on the way... I did want to keep the car as original as poss bodywork wise but for the sake of preservation its simply not worth it
One job remains bodywork wise and to be quite honest I am not looking forward to it...
PXL 20220704 185845083
PXL 20220704 185849407
PXL 20220704 185855832
Offside 'A' Pillar curtesy of a windscreen replacement prior to my ownership... pretty sure I will need to patch a bit of metal in so might try and get a complete A pillar from a scrapper and use that as the repair panel
Happy days :)
<tuffty/>
Reactions: S3AMJ
Credit where credit is due mate….. good effort! Yeah that A pillar is quite shocking, I see mines got a couple bubbles appearing under the trim.
I bought some doors that were supposed to be in decent enough condition... turns out that the drivers side had a similar issue as mine although not quite as bad...
PXL 20220706 145657786
Wire wheeling this lot off revealed a pinhole... disappointing as I was kinda hoping not to do any remedial work on the doors other than a bit of surface rust removal... will clean up the rust as the door itself is in ok condition... has one small dent I have seen so far (PDR should sort that) and a few scratches but it would be painted anyway so not a drama... the main issue is that pinhole and pitting around that edge as ideally you don't want to use filler as it will chip off easily and while I could weld it I would rather not at this time so will present it and my current door to whoever I choose to paint the car and they can decide how they want to proceed...
Looking at the work I did on my drivers door again I am inclined to see if its worth them sorting that over using the one I have just acquired
PXL 20220707 195152022
PXL 20220707 195137869
PXL 20220707 195133050
Its not fantastic but it maybe more solid and need less work than the other door but I will leave that up to the bodyshop to decide... for the time being my functional painting skillz will do :)
Talking of which it was time to urn my attention to the passenger door which as it turns out was not as bad as I was expecting...
PXL 20220707 184143987
The worst bit was thankfully surface rust with not real pitting
PXL 20220707 184150751
So prepped and painted it using the aerosol basecoat...
PXL 20220707 190806657
PXL 20220707 194243967
PXL 20220707 202706675
The aerosol was actually fairly pants... I could have done a better job using the gun (even with my limited skillz in using it!) but the colour match this side is way off anyway and all I would essentially do is make more work for the bodyshop to prep it for paint later so its de-rusted and has paint on it...
<tuffty/>
Reactions: S3AMJ
Helloooooooo there!
Great effort mate! Car is looking better and better! Can’t believe this thread is still going, love it!
Hope you’re all good my friend!
  • Love
Busy few days despite the heat... which is annoying :) (I am typically British!)
Finished cleaning the inside of the car...
PXL 20220709 124124505
All the dustiness from the bodywork is gone and I refitted the passenger seat (still chuffing heavy!!)... I left the drivers seat out so I had more room to sort the DSG wiring out...
PXL 20220713 161242345
PXL 20220713 161411497
Attaching the CAN wires and power wires for the selector... I am waiting on another fuse block to replace the 2 way one I use for WMI and inline fuel pump so I can fuse the selector power too
On the subject of wiring... here is my current setup... this was derived from the one @desertstorm originally put together for his TT track car but I have adapted it a bit for my setup..
DSGWiringv100
I have updated this to reflect where I connected things in my car... also as I have retro fitted a MFSW I have added CAN from the module too so the paddles will work... alternatively you can rewire them as switches and use inputs to IECU instead...
The selector wiring is pretty straight forward...
PXL 20220713 150621579
PXL 20220713 173350112
The illumination control wire in case its not obvious where that goes connects to the larger plug of the light switch
PXL 20220713 160231846
...which is labelled '17' and corresponds to the 58d pin on the switch
PXL 20220713 160317818
With the selector wiring done it was time to move onto the gearbox wiring... I had put together a power distro/relay board to handle all this...
PXL 20220713 173159797
This will handle the gearbox main power and power to the various relays I have in place so reverse light (as no switch on a DSG box), starter inhibitor (ideally needed on an auto), gearbox switched power and the two extra relays I use for the brake servo vacuum pump and turbo coolant after run pump...
PXL 20220714 152152359
Power and earth is feed from the 12v battery point I have fitted previously for the battery relocation to the boot and the factory earth point on the chassis leg
PXL 20220714 162913766
A lot neater than having the relays just floating about...
PXL 20220714 172053374
PXL 20220714 172109262
PXL 20220714 173414514
PXL 20220715 172246122
Once that lot was done I ran the loom up past the ECU... I needed to connect a few wires there first... mainly the reverse light output (switched earth), starter inhibitor (switched earth), vacuum pump output (switched earth) and VSS signal to the cluster as the DSG has no speed sensor...
PXL 20220714 180413126
Once that lot was done I ran the remainder of the wires through to the cabin... this was the CAN wires, K-Line wire and speedo signal wire...
PXL 20220714 195543692
PXL 20220714 195535811
With all those hooked up I put the interior back together and refitted the drivers seat...
PXL 20220715 201042830
PXL 20220715 201049097
I need to address the red power cable for the distro though... really messing with my OCD!! :)
PXL 20220715 172505536
PXL 20220715 172516147
With the car drivable again I took her up to Bills where my box has been residing....
PXL 20220716 114253570
...and connected it up using an extension test lead I made up...
PXL 20220716 112651303
PXL 20220716 112655789
PXL 20220716 112641678
Then tested everything... clumsily... with one hand...
All works :D
There are a couple of fault codes in the box around missing messages but this is normal for this type of retro fit...
Next job is to clean up the box, swap out the mechatronic cover for the new one I have and I guess its then just a case of slinging it into the car :)
<tuffty/>
Reactions: Gops, hydro s3, Rainbird and 1 other person
All works :D
Epic! Nice one mate, very excited for this!
Looking good. Don't forget that spigot bearing in the end of the crank. Wouldn't want to have to pull the gearbox again.
already one in there on the VR as was DSG before but have a new one supplied with the DMF to go in
<tuffty/>
Good stuff PT, great to see the car coming together again in its latest evolution
Without a doubt the cleanest build i have seen over the years
D
733
Deleted member 65282
D
