Hi mate... no... not worked it out as yet... changing the CAN protocol for the clocks gets rid of it but unsure of the knock on... Brian suggested it so maybe worth pinging him
Ok cheers dude it’s odd because it never came up prior to the gearbox map, so thought maybe that was the cause. I’ll give Brian a shout and see what he thinks. It is something I could live with worse case. Did you ever get an issue with your YAW sensor since? Fault clears after recalibration and all good for a little while then returns.
I have coded my ESP out so I may never see those errors if I get them
Reactions: S3AMJ
I think I’ll code mine out if it persists mate, turns out when ESP is off Ignitron still implements some form of “traction” control.
Do you code it out via VCDS or Ignitron dude?
VCDS in the ABS module... only works on MK20 ABS modules iirc... don't remember the exact value but its either subtract 2048 or 1024 from the value to remove ESP... VCDS "should" pop up available values
Reactions: S3AMJ
2048 is the one - though I could never find the reason why despite lots of Googling. I've had to use it on the Golf to resolve the usual ESP issue running a quick rack (LCR/TT) on the standard GTI. Should have kept my ****** LCR, was far less faff for minor stuff like that :laugh:
Reactions: S3AMJ and <tuffty/>
I have had the ESP coded out on my TT for years with no issues. I did used to get intermittent errors with the Yaw sensor when I first had the car and there is a common issue with these. The IC on the PCB is very poorly soldered and can actually detach from the PCB. The PCB is potted in the box and when I removed it the IC detached from the PCB and was left in the potting material.
Ignitron doesn't implement any form traction control unless you configure it to do that. Disabling the ESP doesn't stop the ABS module from activating traction control.
I believe EDL is still active after using 2048 to code out ESP... there are further 'codes' (more a bitwise calculation) to disable EDL too but I left mine on.... I think... been a while :)
Reactions: Rainbird
So your still able to use LC, Race mode, etc when ESP is coded out?
I’ve been given a known working YAW sensor, so I can always swap it out and see if it persists. Although it appears that the same issue is with Germains TT, so potentially using the TT DSG squib is at fault maybe?
I swapped the squib in my car for the one used in the DSG cars as it has more ways available for the DSG paddle connections , I have no issues. With ESP disabled on the ABS I couldn't get launch control to work on my DSG gearbox as the stock software needs to see ESP switched off before allowing launch. When I enabled ESP on my ABS launch then worked correctly on the DSG gearbox. One of the reasons I had a TVS remap on my gearbox is they alter the mapping so launch works with or without ESP. Thus I can run without ESP and still have launch available on the DSG gearbox.
Race mode hasn't got anything to do with ESP working or not.
Reactions: S3AMJ and Rainbird
I’ve also got a TVS map on my gearbox now, thanks to Badger5. I was under the impression that you couldn’t launch without abs as you rightly pointed out, I wasn’t aware that you can run with it without or without ESP though with the TVS map, I’m unsure weather my map has that “enabled” per say. Race mode is purely just how I’ve got mine setup, it’s enabled when turning off ESP via the button on the dash, just makes everything simpler that’s all. One button does all basically. Something I’ll look into once I’ve got the car back from Bill. Also something to consider is mines a DQ500 rather than the DQ250.
Reactions: desertstorm
Been a while I know but been busy with work and nothing much to report on the car until now...
I had noticed the rear brake lines were looking a little past their sell by date so had bought up the stuff to sort the front to rear hardlines and flexi's... I had already replaced the lines to the rear calipers when I did the rear calipers :)
I have been putting it off for ages as the one line means I have to drop the fuel tank and its not a job I particularly relish doing on axle stands outside the house... but... while checking out if I could just cut and shut the line to replace just the bad bit...
PXL 20230528 130546163
PXL 20230528 131825620
...it kinda broke... Soooooo... guess I just needed to suck it up and get it done...
Used a plug and bleed nipple to stop fluid from leaking from the ABS unit while I faffed about under the car... had to use an M10x1 and M12x1 as they are different for whatever reason VAG decided on...
PXL 20230603 125712177
As is the way with the 8L these days... parts are proving difficult to get and I could only find one line (nearside) which even then wasn't the right one exactly missing the flexi part....
PXL 20230603 131228762
The nearside line wasn't as bad as the offside oddly but it was still pretty grim...
PXL 20230603 134036067
This of course was the easy line to replace ironically...
PXL 20230603 134015839
Now for the fun bit (said no one ever)... had to drop the prop and various heatshields.... followed by the tank... thank fully it only needed to tip down a bit at the front so no need to fully undo and drop it...
PXL 20230605 165316977
PXL 20230605 165551909
Bit of wrangling and out it came...
PXL 20230605 170047492
As I couldn't find a part OE or otherwise for this I bought some cupro-nickel tubing... bit more resilient to the weather than bog std copper...
PXL 20230605 170135234
As the OE line was steel I taped the replacement tubing as I was bending it to make it a bit easier to handle and also helped get the shape as close as I can
PXL 20230605 173752557
PXL 20230605 174439081
Took the line up to Bills so Alex could use his fancy flaring tool to sort the ends...
PXL 20230606 104843602
....should mention that some pillock (that would be me) managed to use the wrong fittings (some imperial things I had laying about) rather than the proper 10x1 so I had to cut the flare off and get them redone with the right ones (DOH!)
I of course painted the pipe before fitting it back in...
PXL 20230613 162618372
..and bled everything up...
PXL 20230613 175357012
Have to say the pedal feels better than it did given I recently replaced the fluid and bled everything before so I do wonder if that pipe was flexing where it was thin... scary thought tbh....
Reactions: yoursixx, S3AMJ and Ian W
Not a lot to report but I have been doing a little beta testing for a new IECU firmware that addresses specific issues to do with the Cxx TCU my gearbox has... being the first iteration and the dumbest of the TCU's getting things like rev matching to work appears to be different to the later TCU's and before the car would lurch forward (as though not disengaging the clutch properly) on downshifts... this is now fixed and the car drives much smoother now...
I have been chasing a clunk from the front of the car too... this as it turns out was initially down to the the thread going on the rear subframe mount in the body...
PXL 20230814 162726428
So out with the helicoil kit...
PXL 20230814 164517457
PXL 20230814 170551090
Got full torque and yield spec on the bolt after that so happy days... however... there is still a slight clunk (not as bad as before) on hard acceleration and the only other thing I can think it might be is the replacement poly jobbers on the rear of the subframe aren't gripping the body as well as OE as it sounds much like the subframe shift clunk common in Mk5 chassis cars..
Needless to say I need to get the car in the air on a ramp and do a complete spanner check as the whole conversion was done on stands outside the house (not a bad thing) and its easy to miss something when you have limited space (and really bad close up eyesight lol)
While testing the firmware I also played with the boost a bit hoping that I could potentially get back up to 1.2bar but alas the clutches weren't having any of it and so I brought the profile back down again to keep the box happy...
I26b v18 R32 Turbo DSG 116 001
Bit of playing about with the PID and imax etc and...
I26b v18 R32 Turbo DSG 116 20231008 1553001
That is pretty bob on to what I was going for... the engine feels strong when on boost which is far earlier than the 20v could do (for obvious reasons) and the less aggressive torque onset keeps the box happy and is less likely to break things
Reported hp I think is a bit off but would need to get on the dyno to confirm... I suspect with the lower boost I might be knocking on the door of 500hp given at 1.2bar I managed 524hp...
Future work should only really be remedial now but need to chase this clunk... will look to rebuild my spare DSG box with a new clutch pack (Golf R is the one to use apparently) and might try and source an Fxx TCU as this would improve the box operation as a whole I think... the Cxx is a nightmare when cold... won't change into 2nd in drive so have to force it... assumedly this is a cold oil thing...
I also still have the rest of the body work to look at, rear subframe/diff refurb (and I still want to try this 8P rear diff conversion) but other than that I think the old girl is in a good place... until something else breaks lol
Reactions: yoursixx, S3AMJ, Rainbird and 2 others
Looking lovely as always PT! I looked into this 8P rear diff thing back when I had my S3, although short lived but packaging wise it looked like it fits. Not sure on the Haldex controller but worth a punt!
Reactions: <tuffty/>
Good to see you're still posting forum updates Tuffty... so is the transmission holding the car back, or is it in the zone.
Its a combination of things tbh... the TCU itself is about at its max clamp pressure without patching the map with custom code to increase that... the box itself was on 80k when I got it and no telling what sort of life the clutch pack has had... there are ways you can use VCDS to determine wear but in reality its largely irrelevant....
The box itself mechanically is based around an 02M so there are limitations there if I push the torque and the engine is on the upper end of what I believe is safe in its current configuration without going for a bottom end build
If I wanted to push further (and the 3.2 VR has a lot to give) then I would need to build the bottom end to be safe, bigger injectors as I am at 85% IDC on the 630's I have, DQ500 DSG gearbox to take the increased torque...
As it stands I am around the torque figure my 20v was making but it comes in sooner and holds longer (albeit to a lower rev limit) and nothing is being nearly as stressed as the 20v build...
Fitting Golf R clutches and an Fxx TCU will not really help the longevity of the box as the limiting factor is the internals on the DQ250 at that point... the DQ500 is a far stronger gearbox in comparison
I am 'hoping' that I am in the zone as you say for both the engine and box... the setup seems happy at the moment but I guess only time will tell... obviously its hugely subject to how one drives the car... driving a highly tuned car is always going to narrow the reliability window but she feels less fragile than the 20v setup did for sure
Been a while since I have posted anything but tbh there has been not a lot to report... the car just does car things and I have been driving her a bit more this year than usual... I even drove her to the office (140 mile round trip) once and she just sat on the motorway and returned an average 26mpg for the journey which I was happy with...
Anyhoo... things that have happened...
I bought a mini pc to replace the 10" tablet I was using for ignitron...
PXL 20240109 094132255
This quite a bit smaller than the 10" (fnarr) being only a 5.5" screen
PXL 20231101 201445068
...but it is more powerful and less intrusive... I did not want to just stick some phone mount pads on this though so thought I would use the opportunity to learn a bit of fusion 360 and design a holder for it...
Screenshot 2024 09 28 200826
...and a back plate for more mount options...
Screenshot 2024 09 28 201047
...and finally a mount so I could still vent mount it using the YOSII mounts
Screenshot 2024 09 28 200912
This work out better than I had expected tbh.. although I did go through an R&D stage
PXL 20240110 211321286
PXL 20240117 090109009
PXL 20240117 090328920
PXL 20240117 090335629
PXL 20240117 090342476
PXL 20240110 193534879
The downside of a smaller screen however is that my old eyes could no longer really 'glance' at the dials so I redid the tablet view screens to make them actually more readable and actually useful
PXL 20240928 185831396
I plan to do a different version of this at some point but for now it works as intended..
Off the back of that I then wanted to tidy up the USB lead as this currently loiters about the passenger kickwell and passengers have been known to kick it... not ideal so back to fusion 360 and have come up with a mod for the blanks next to the ESP button to house a USB C socket
PXL 20240213 235522294
PXL 20240214 203805246
PXL 20240214 204712467
This would let me run a shorter USB cable keeping it out of the way and looking a bit neater
PXL 20240214 205500516
Next job that happened was to replace my alternator as for some reason I felt it was contributing to my battery issues... bought a genuine Bosch 140amp one for a very good price... and is the VR way... off with the front!!!...
PXL 20240430 161515105
PXL 20240430 163607528
PXL 20240430 164627079
Turns out the old alternator wasn't faulty after all but... I now have a new alternator along with the recently replaced new air con pump so meh... plus I had developed an oil leak from the oil filter housing... more on that in a bit...
I was getting into 3D printing more and more now and being able to draw up functional parts in fusion opens the door a bit to making parts for the car that I think would finish off the build nicely... my trusty Ender 3 V2 had been a fantastic intro machine but I needed something I could print engineering materials with so bought a Bambu Labs X1C with AMS... this means I can print fancy materials like ASA, ABS and Nylon...
Its also multi colour capable so I tried that out by drawing up some drink mats for Bill
PXL 20240519 191841781
I drew the mats/design and caliper holder in fusion... was an interesting process in making a drawing that could then be easily 'coloured' in the slicer for printing
I then bought some Carbon Fibre reinforced Nylon 6 material... I drew up some separators for the AN6 PTFE fuel lines on the S3....
PXL 20240914 144457836
PXL 20240914 090242253
I also drew up some stand offs so I could attach them to the OE bracket to hold them in place
PXL 20240914 182429237
PXL 20240914 182437329
The material should hold up to the under bonnet temps... I guess time will tell but they are holding up so far....
So... the oil leak... the VR6 has a water cooler the same as a 20v but is fitted to the side of the filter housing... this is secured using a plastic cap much like the TDi's... all mine was brand new when I first fitted the VR in... but it developed a weep out of the plastic cap and I thought it was loose... turns out it isn't and I dare not tighten it any more than I have...
The VR's oil temps are still a little too high for my liking given its a road car... I have seen over 100-110deg just from a short spirited drive on a cool day... so to remedy both the leak and the temps... I bought an oil cooler (finally!)
PXL 20240919 103247834PORTRAIT
19 row rad, 80deg thermostatic plate and a metal cap... I will probably remove the water cooler and just fit this... I suspect it will take a bit longer to get the oil to temp but tbh thats not a massive issue for me... I would rather the temps were kept in check once up to temp as I don't rag on the car until I am at 70-80deg anyway
Talking of oil leaks... I also discovered the haldex is leaking... I suspect this to be the controller gasket as I replaced the controller a little while back... I noticed this when I did all the fluid changes recently and was having the 'skipping' issue on low speed turning.. that went away when I did the fluid change so assume the skipping was down to low haldex oil..
I have new gaskets and oil so will address that soon too
Reactions: superkarl, Gops and Rainbird
Been a while since I posted but to be honest there has not been much to report... just been driving the S3 more than the A2 of late and enjoying the old girl...
I did develop a vac leak meaning I had to disable the vac pump... although that turned out to be a leak elsewhere and (hopefully) fixed a leak from the haldex...
PXL 20250503 141107648
Found the face had a bit of a mark on it but probably not enough to cause a problem..
PXL 20250503 141118628
...but cleaned it up anyway as why not...
Used a new gasket and the rubber band trick to keep the bolts and gasket in place while I wriggled it into the small gap...
PXL 20250503 142432060
....then of course cleaned up all the leaked oil and refilled the haldex with new oil... which as anyone thats done this before knows how much fun that is :)
PXL 20250503 150842931
I took the front bumper off to check the vacuum pump... turns out it wasn't the pump or the hoses there but was the hard pipe up by the servo (should have realised that really)
View: https://youtu.be/Vr807nS343I?si=xy5wLc6QNIca5yx_
Fixed that then had a look at options for the oil cooler...
PXL 20250503 161334985
PXL 20250503 161340523
PXL 20250503 161501100
...guess I will need to have a think about how best to go about it lol
In other news..... I have been playing with the tuning a bit to try and keep the gearbox happy... the reality is that I will need a clutch as the box was around 70/80k miles when I got it so probably a little on the tired side and now its got a bit more than its designed torque being shoved through it I was having slipping issues...
After a few trips to mexico I am pretty happy with the current tune...
Screenshot 2025 04 25 131753
Screenshot 2025 04 25 131855
Screenshot 2025 04 25 131955
max boost of 1.1bar or 16psi in old money and kept the torque flat through out the rev range and controlling spool... no slip now and still pulls like a train
I might be able to turn the boost up a bit to lift torque once spooled maybe towards to the higher end of the rev range once I have swapped out the clutch but tbh I would rather have the reliability...
Soo bought a clutch kit...
PXL 20250425 132945576
PXL 20250423 134031367
Swapping the clutch itself is actually pretty easy... the joy of course is the removal and refitting of the gear box :)
To finish up I redesigned the mini PC holder I use with my Ignitron ECU... this is more a proper 'case' then the holder I designed previously
1734566164371
Reactions: voorhees, Alex C and Sandra
One thing I have always wanted to address was my original DSG shifter mod...
PXL 20220821 125809376
This was basically a hacked about DSG trim panel from an 8P A3 and a hacked about 8L gaiter ring...
PXL 20250513 133304521
PXL 20250513 133326845
The 8P trim is much wider than the 8L so you can't really do much else than hack it about..
PXL 20250513 133353136
...and while I was happy enough at the time I did it its starting to look a little like its been thrown in... so now I have a basic understanding of Fusion 360 and a decent 3d printer I decided now it the time to have a go at remaking something a bit better..
The only bits I need from the 8P trim is the illuminated insert bit and the electronics...
PXL 20250513 133423405
The 8L shift trim is 'shapely' to say the least so worked out the radiuses and printed out some circular bits with datum marks so I could take more accurate measurements and bingo bango...
PXL 20250513 165326290
PXL 20250513 185131253
PXL 20250513 203913021
...I had a baseline drawing that fitted pretty well into the hole... so armed with that I then replicated the gaiter ring to get a baseline for the rest of the dimensions...
PXL 20250513 222559350
PXL 20250513 222635063
Happy days.... using this drawing as a template I then progressed to a trim panel to hold the illuminated insert...
PXL 20250515 201503843
...which now fits much better than my original.... from there I drew up the gaiter ring and its required details to allow it to fit and expanded the drawing of the illuminated insert panel to allow the electronics to be fitted...
Printed off a few iterations to get to where I wanted it to be... joys of a fast printer... and...
PXL 20250518 180850780
PXL 20250518 180907849
PXL 20250518 181150412PORTRAIT
PXL 20250518 181049641
Gaiter trim fits in perfectly... the illuminated insert panel fits on separately to make printing the parts simpler minimising overhangs and requirements for support material...
Works much better than my original that was essentially hot glued in..
PXL 20250518 181742933
PXL 20250518 181255635PORTRAITORIGINAL
PXL 20250518 181326480PORTRAITORIGINAL
PXL 20250518 181335030PORTRAIT
And all fits together perfectly...
PXL 20250518 182251255PORTRAIT
The OE shifter trim does require a small amount of trimming to allow the wiring plug to fit...
PXL 20250518 181516000PORTRAIT
PXL 20250518 182047146
Overall a good result I think... I had a few hiccups along the way while iterating through the changes which has made the Fusion time line a little more messy than I would like but it was a great learning exercise in Fusion 360...
Screenshot 2025 05 18 172214
Screenshot 2025 05 18 133905
I now need to remove the knob (fnarr) and gaiter from the car so I can test fit it to the current version of the print... I know I need to tweak the design further to add relief for the gaiter seam to make it sit flush but once that's done then I will do a final print in ABS/ASA material (more suitable for an interior car part than the PLA I am using for the development process)
The joy that is a fast 3D printer is that can quickly and easily iterate a design based on the physicality of output.... couple of things that came out of my initial design was that the gaiter was an absolute nightmare to fit as the frame was all one piece and the gap between the indicator section and the gaiter frame was 3mm
PXL 20250519 170741708
Another thing that came out of being able to test a physical item is that the gaiter frame hit the selector and pushed the whole frame out of the OE trim when I attempted to fit it properly in...
PXL 20250519 185741596
Soooo back to the "drawing board".... did some changes to the design by adding a relief in the frame to clear the selector and split the indicator section and gaiter frame section so that the gaiter would be easier to glue on...
This also had the benefit of making the 'join' between the two parts stronger....
Screenshot 2025 05 20 190146
Screenshot 2025 05 20 190259
Screenshot 2025 05 20 190348
PXL 20250520 124806821PORTRAITORIGINAL
PXL 20250520 124817109PORTRAIT
The two parts are secured using M3x8 machine screws....
PXL 20250520 123636482
PXL 20250520 124635804
...and now clears the selector...
PXL 20250520 124235873
Fits rather well if I do say myself...
PXL 20250520 124256845
I have printed these "final" parts from ASA filament... its a version of ABS and is strong and heat resistant... printing this from PLA would mean that the slight sniff of the sun and a bit of hot weather and the PLA would as limp as a limp thing (fnarr)...
Gluing the gaiter on was much easier this time as I had proper access all the way round... note for this application I actually used the original manual S3 gear gaiter as the selector sits higher in the car than the vehicle it was sourced from (9R Polo) and all the DSG gaiters are too short
PXL 20250520 164803124PORTRAITORIGINAL
I trimmed off the excess leather including the bit I glued across the relief I just added for clearance!!! (DOH!!)
PXL 20250520 171807513
Seems to have worked out ok...
PXL 20250520 165045352PORTRAIT
PXL 20250520 172134297
Need to do a little testing using the car to make sure its all secure and nothing fouls anywhere then I will make the files available on my Makerworld profile
Small update....
I have been to see the people that will be sorting the bodywork out on my car... this will happen at some point next year as they are quite busy plus its not going to be cheap as there is a degree of restoration that needs to be done (A pillar and roof rails mostly) ...
I am sure I can get a paint job much cheaper elsewhere but as the car has had paint over my ownership (roof rails) which has essentially failed after only a few years I want a proper job done and these guys have my confidence... more on that as it happens...
In the meantime I have made some slow progress with the oil cooler solution... the recent hot weather has highlighted how quickly my oil gets to over 100deg with very little spirited driving and I want to remove the OE cooler to stop heat transferring (both ways) between the oil and coolant...
One problem in removing the OE cooler is that I will lose effective cooling if the car is not moving so stuck in traffic etc so to mitigate that and improve the overall cooling of the oil I am adding a fan...
This isn't a bad shout anyway as the cooler placement won't be ideal for airflow so fired up fusion and drew something up...
Screenshot 2025 07 17 180559
Printed off the first test version...
PXL 20250716 210427996
...and after a few tweaks I printed the final version using PET-CF filament
PXL 20250717 075303366
PXL 20250717 075322525
PXL 20250717 163122281
PXL 20250717 163344007
PXL 20250717 163350956
Pretty happy with that... now need to find a spare output on the ECU I can use to switch the fan on with...
I also need to make a bracket but that will probably be metal rather than 3d printed although I may still need to design something to help with the mounting
Treated myself to a little bit of not as OEM as I normally OEM goodness... Ash showed me his (fnarr) and I was so impressed I decided to grab some for myself...
PXL 20250721 103616828
PXL 20250721 103623736
PXL 20250721 103654606
I am of course referring to some fancy magnetic paddle shifters (video at the end ;) )
These were easy enough to fit as they are plug and play for the OE (as long as you have them set up as CAN based units through the steering module like I have)... battery disconnected then off with the airbag... the 'fun' bit was wrestling off the MFSW switch trim which was not much 'fun' at all...
PXL 20250721 110642692
OE paddles unplug from the back of the front switch units and look kinda dinky compared
PXL 20250721 111507099
New paddles are pushed back into place and held in with a screw
PXL 20250721 111648434
The place the paddles further out to the edge of the wheel which actually feels more comfortable but...
PXL 20250721 111822947
...this moved the up shift paddle real close to the wiper stalk (assumedly this is not a problem in the cars my wheel comes from originally)... the down shift paddle cleared fine though
PXL 20250721 111801736
...so I just moved the paddles to the other side of the mechanism...
PXL 20250721 112053423
This seems to give enough clearance (for now)... not actually tried them on the road as yet as my battery is on charge... if the clearance needs a tweak I can easily draw up some spacers in Fusion 360 and print them..
Definitely feels more grrrr than OE :)
View: https://youtu.be/IzJ1vm_I1Hs?si=o58_vFbOdPjb9z3E
Reactions: Winston Todge, Perplexer, Farmor00 and 1 other person
Been a while but tbh the car has been behaving herself fine... I have just been driving her about enjoying the paddles and generally burning fuel like its gone out of fashion....
...until....
PXL 20251109 141920230 web
...the old girl broke down on me... in a pretty awkward place too as is the way of these things... so a quick phone call to a friend asking to bring a fuel filter over as I knew it was the inline pump that had failed...
Screenshot 20251109 172624 web
The DA-32 I had fitted way back in 2009 had finally packed up and the fuse for the intank pump (a DW65) had blown trying to push enough fuel through so no idea how long that had been happening tbh
Using the fuse from the inline (as that had not blown) for the intank and a fuel filter to bridge the connection from the now removed inline pump I nursed the old girl home where she sat for about 3 months (life, christmas, weather... then more weather!!!!... then even more weather!!!!!!!) until I managed to get her sorted...
I replaced the battery as that was goosed but then the engine would just die a few seconds after starting... turns out the intank had given up too
One nice new Sytec 420 intank later and a single sunny but chilly day I got on with the swap...
PXL 20260214 121432420 web
PXL 20260214 123050251 web
PXL 20260214 123725304 web
Removing the pump is not too bad as long as you do not have a full tan of fuel... typically half or less is advisable but as was my luck I had not long filled up when the pump failed soooo
PXL 20260214 123728978 web
Wasn't great fun and the fuel was ****** cold too!!
Anyway, popped up to Bills to do the job so if I got stuck I would have access to a little more experience than I had doing this job as Bill and the boys have done loads
PXL 20260214 132132126 web
PXL 20260214 135310593 web
All back together again and fitted back into the car I decided to check everything was working ok before removing the filter and fitting the new inline pump...
PXL 20260214 150525432 web
Did the neat Ignitron trick that allows you to crank with no ignition or fuel being commanded to build up some oil pressure first seeing as she had been sat for a bit... then the engine fired up first turn... and fuel pressure was steady... happy days...
Lastly I fitted the inline...
PXL 20260214 152252554 web
This also worked fine and to my relief wasn't noisy like some... just that nice reassuring low buzz in the background....
Today I took the car out for her first run... drove impeccably and warmed up nicely I went for a third gear log run... that did not go quite as planned
Spinny
...seems that the Haldex didn't get the memo and is still on holiday :(
Not 100% sure what the issue is as it was working fine before being parked up but I am pretty sure its the connection by the diff thats the issue but won't know until I get her in the air for a faff
Ah well... just glad to have her up and running again... :)
Reactions: crispynz1, superkarl, calico101 and 2 others
The rain decided to take a day off so managed to play with the haldex... for now it only seems to want to work with the HPA out of the picture so need to pull the HPA loom and check over the wiring to see if thats the issue...
I have AWD for now but boy do I miss how well the HPA took the delay out of the stock haldex controller waking up when I plant my foot...
All was going well until I was on my way home from a family visit and the rad fans stopped working... thankfully it was cold enough outside that pure airflow seemed to be enough to keep the engine cool for the most part but it did go over 100deg once I parked up...
Little disappointed to say the least but thankfully the issue wasn't too bad...
About 10 years ago I had the same issue which is the common problem of the fan power fuse melting...
20151206 IMAG1507
I originally fixed this using an inline fuse holder....
20151206 IMAG1508
...but I guess its time was up...
PXL 20260228 130047833 web
PXL 20260228 134417643 web
Ironically the fix was simple... I just used the spare midi fuse point that had a 50a fuse in it by cutting the wire from the 3 pin plug, fitting a ring terminal and bingo bango etc....
PXL 20260228 133705407 web
Happy enough with that for now but I plan to come up with a better overall solution as well as revisiting the relay/fuse board I put together when fitting the DSG box as I need to add another relay to drive the oil cooler fan when I finally fit it
Gotta love old cars :)
Hi
<tuffty/>​
Great work you did with your build, really a epic project. I am also doing the same. Bought a complete audi tt R32 8N 2004 model already forged the motor and busy fitting the gearbox. I have a question. I upgraded my megatronic's to the AE version before the TT got stripped. The car was not running because the meg unit was shorted out. So we installed the MK5 2008 model megatronic's and we downloaded the file and updated the gear ratio information on the meg unit to be in syc with the dsg box.
So will the following Can gateway module work with the build because the gearbox send's out canbus signal and not vss like very first gen megatronic units. Just to note after fitment of the new megatronic's i drove arround with the TT for a week before the strip but speedo did not work and i know it won't work in my car. Need the can gateway. I am also running emu black with PNP adaptor in my S3
Hi
<tuffty/>​
unsure of that tbh dude as I use Ignitron and it pulls a signal from the ABS natively to send to the cluster... there is no need for a can gateway in that instance as lots of cars are running dsg and using switched inputs using the original Mk1 TT clock spring to send the correct CAN msgs to the box...
I ended up having to use the can gateway to allow me to use the 8P wheel module and CAN shifters to talk to the gearbox as the shifters work on a different bus
I don't know anything about the EMU Black ECU's so not sure how they deal with it as my experience is solely using Ignitron...
Thx bud , yes 100% i can do it with the emu black. CanBus signal already going to the ecu and i can use speed pin ou to cluster. I am also using the 3dcolor MFA and the redbox 8.4 steering module. I just need a backup plan to use the paddels as my switches is currently beeing used for cruise control. I am using the 2012 rs3 steering wheel and with the redbox 8.4 i can use all the multi media buttons to control the rns-e radio on canbus. No one used the redbox to control the shifters . My backup plan is to do the same as you , canbus control with can gateway and steering module. This is the hardware i got so far and this part i am not sure of. Will this hardware work because if the 1K0 907 530 L does not work i need to get the 1K0 907 530 L .What steering control module do you use?
  • DQ250 TCU (02E 927 770 AE) ≈ 2007
  • Gateway 1K0 907 530 L ≈ 2007–2009
  • Steering module 8P0 953 549 K ≈ 2010–2013
  • RS3 flat-bottom LIN 2.0 wheel ≈ 2011–2013
Not sure the LIN wheel works as you need an earlier CAN wheel... I think Adam Forbes of Forbes Automotive was working on a can > lin adaptor though
Have you finished this yet??
Just popped on for my occasional wind up, however, great work mate as always, great to see her coming along.
It is always a pleasure reading your thread @<tuffty/> , although I am not actively participating in the forum! I have found loads of useful information from your build. I am resuming the work on my car as well and might update my thread.
Keep up the good work!
Thank you... I started this thread as I struggled to find information I needed to help me in my S3 journey so by essentially documenting everything I have done to the car (the good, the bad and the ugly) hopefully it helps one or two people with thier builds or even general maintainance as its not all about banging big snails or more cylinders in :)
Reactions: johna650
Thank you bud for the update, did you only had to pin the N75, IAT on the ecu small plug? Did you have to wire any wires into the big ecu plug, before or after the dsg swap and is this plug still the s3 stock plug? . Trying to find the info on this thread
I don't think I ended up sharing the pin out setup I ended up using as I mapped it on the IECU pin out spreadsheet I had..
I'll go back through the files I have and double check it all then sort out some screen shots for a post
Hi
<tuffty/>​
I managed to get the ABS CAN to VSS working using the Redbox, and the paddles are also working using the 3DColorMFA Redbox 8.4. The main things I am not sure about are the connections for the reverse lights, the DSG shifter lock, and the starter inhibitor.
Hi
<tuffty/>​
All wiring info can be found here... https://www.audi-sport.net/xf/threads/76389/page-109#post-3764573
TL;DR
Reverse light and starter inhibitor are controlled from Ignitron ECU...
DSG shift lock needs no further wiring or intervention as its a function of the shifter and the shifter knows when the brake has been depressed to disengage lock..
The pin 2 park signal output of the shifter is for the ignition key lock out so it will not allow the key to be turned (or removed?) if the shifter is not in park...
The Mk1 TT used a physical cable but subsequent VAG cars use a solenoid on the column and the park signal is for that... I did not wire this in as I considered the starter lock out to be enough
Hi @<tuffty/>
thank you for the above this is going to help alot, just wanted to know dod you use the TT loom big plug connector from raintray or the stock s3 one?
1782306529004
I didn't touch anything in that area at all... I used the stock S3 large plug loom and the TT small plug loom... wiring changes were done to the TT loom only.... I'll dig out my ecu pin out diag of what I did...
So the small plug changes... the ones in red are ones I had to add to the loom as they don't exist in the TT VR loom...
Screenshot 2026 06 24 141812
...and the differences noted for the 14pin plug by the battery
Screenshot 2026 06 24 142345
