- Joined
- Sep 14, 2008
- Messages
- 24,880
- Reaction score
- 6,117
- Points
- 113
- Location
- Wibbleton
- Website
- www.tuffty.co.uk
Made some progress... had an issue with one of the GSF fans (new at the time of fitting the VR6 in)... I had been getting quite a large vibration from the fan when they were on and turns out that the larger fan was the culprit and the blade assembly had come loose
...so a bit of locktight later and it (and did the smaller fan too) was sorted...
The CFS rad is quite a bit thicker than the OE rad....
Also being a fabricated product the tolerances were a little out in places...
Nothing a little filing can't sort out... with all that sorted I fitted the fan pack...
Next job was to sort the PAS pipework.... I used the 20v pipework when I originally fitted the VR but due to the way the engine tilts forward its got a habit of hitting things...
Also the feed hose from the reservoir was modded as best I could at the time to try and clear the alternator that was more forward now....
I had to cable tie it out the way to clear the pulley... when I bought the 4 motion gear box I also grabbed the PAS lines... so now fitted those...
I didn't get a pic of the feed hose but the 4 motion one clears the alternator by miles now... the only issue now is that the run to the rack goes a different way to the S3 pipe... this means I need to sort a bracket out for it to secure it properly... I think I will be needing to change the PAS pipework again once I get the DSG box on but thats a problem for when that happens
During the last week I worked on the inlet manifold and headlights (as they were getting a little misty)... sanded down the powder coat...
...followed by some etch primer, Simoniz's best wheel silver and a few coats of clear lacquer...
Next up was the headlights...
Used the same lacquer on the headlights too...
Today I did some more on the car... I swapped out the fuel rail to the AN fittings one and fitted the mani...
Then came the 'fun' part.... I knew the aircon would be an issue...
...so some tactical modding later and....
I now need to mod the front clip now lol....
Ah well... joys of modding cars right?
. Things we do hey! Glad to see your getting through it. Catch up with you tomorrow
good to finally meet Nick after all these years. That VR does sound epic mind!
glad your testing negative now mate.
