APR Stage 1 map results and problem
Connorcupra
So got my S3 APR mapped today by Ecotune, made very good figures, alot more than i expected with a very good power curve.
One problem is when i was driving home if i was full throttle from say 2500rpm then at 3000(ish) rpm the revs would go up to around 3800 and not move very much with lack of power... but if i feather it over the 3000rpm and go say 50% until 3500rpm then 100% throttle then it pulls to redline no bother at all.. can anyone shed some light on this as i dunno if its clutch issues or ecu getting used to the map??
Power figures from today
Sounds like the clutch slipping to me. If the RPM increases without a proportional increase in speed the clutch is usually the issue.
Reactions: Boydie
Time to upgrade - get a Sachs organic and while you are there replace the OEM LUK flywheel and wheel bearing
However, you will not get much change from £1000 :(
20
13
27
3K
12
894
