Audi A3 8V Reverse Camera (High) DIY Retrofit guide!!
Now u are just trying to make me look silly... honest it won't work !! downloads and shows error !
EDIT - Just downloaded Adobe Reader and now I can finally read it !.. Very odd... must have been an issue somehow with the standard Windows 10 reader. But it deff will not open on a Mac. That asks for a password.
lol..I hate computers....Glad it's working for you now...:friends:
Reactions: jungle650
Ok so my order from vag-tec arrived yesterday. I say 'order'... some or my order anyway. They didn't send me the camera module holder or the removal keys - no idea why, they just didn't. I'll be on to them later to get a refund for those.
I'm slightly annoyed that their kit doesn't appear to be made up of 'new' parts. Everything has most definitely been removed from another car. The long wire from camera to camera module has green plugs on it rather than the colour coded grey ones I'd expect it to.
I had a few hours spare so I made a start on fitting it...
I started by laying everything out to familiarise myself with how it all connects and I instantly start to query the supposed location of the camera module. Why make / provide such a long cable if the module is meant to sit 1 - 2m from the boot release / camera itself? In my mind, with a cable that long, the module box belongs up front... at least in a 3dr like mine.
The first part of your guide is no use for a people with 3dr cars, so I just started 'winging it'.
There are 2 x T25 screws to remove under where the warning triangle lives. I removed the 2 flaps that provide access to the lights on the tailgate / boot itself and basically just used these are places to 'pull' ! 14 Clips later and it's off. Each side has 2 clips. 4 along the tope near the wiper arm, 2 right at the bottom near the latch and 4 somewhere in between (but nearer the bottom).
The remove the trim around the window, use your trim tool or a screwdriver to lift the 2 visible round poppers / clips and pull them out. The trim has 2 clips on each side and 4 along the main bit. As with the last one, just pull it.
Now unclip the lead from the old boot release handle and undo the 2 x 10mm nuts on it with a socket set or spanner. This thing is much harder to get at on a 3dr than the saloon pictured in the guide. The rear clip is still visible but the little tiny white tabs are a pain. I ended up using an L shaped Allen Key (probably a 5mm) to get access to them and push them in. You have to get the key through little round cut outs in the metal work in order to push them in. Once you've removed it, push the other one into place, do the nuts back up on it and put the lead back in - so you can open the boot if you accidently close it!
Knowing that the cable needed to head back towards the glove box area, I opted to route the cable to the left of the tailgate rather than the right and then have to double back on myself.
Now we're onto the removing the lower boot trim...
Pull the weather strip / seal off from around the boot opening. It's a pain and gets in the way! Now empty the boot... really empty it! Take the false floor out. Unclip and unscrew the sub (if you have one) - remove it and the spare wheel. Remove the polystyrene bits with the jack etc. in.
Remove the bit of trim covering the boot catch itself - the one that's the width of the car and gets scratched up! To do that, I recall you have to unclip it on each side and then pull it up. It slides over 2 button type fixings on the metal work - these are visible.
And now onto the trim on the left of the car...
There's a T25 screw you need to remove from the upper plastic trim around where the parcel shelf fixes in and another T40 one (guide says M8 spine but I don't have one and this worked) from the anchor point on the soft stuff.
Twist the coin slot type fasting at the top of the little 12v auxiliary socket cubby hole and gently pull it out. Unclip the lead going to the 12v socket and put the whole thing down somewhere safe. You now need to remove that entire section of trim. This part is fairly straight forward... it uses the same clips as on the other pieces you've removed. I have a little down facing LED that I had to unclip before I could totally remove the trim. The plug comes apart if you use a tiny (1 or 2mm) flat blade screwdriver and push it down on the silver bump. This bit of trim also clips over a button type fixing on the metal work. You don't notice it when removing the trim, but you need to make sure it goes back over it when you put it back. It's right down the bottom.
I didn't fully remove the head lining style trim just above it with the speaker in it... mainly because I couldn't. I managed to unclip it just enough to gain access to what I needed.
Rather than pulling 5m of cable through the rubber channels that go between the car and the tail gate, you obviously want to feed the cable through from the inside of the car rather than the other way around. The channel is already quite full of wires and so I took the plastic off the end of my coax wire by levering out the tiny purple clip using a screwdriver and using it again the release clip. The wire should then slide out. After that, all you need to push through the rubber is a slim line round bit of metal... no more chunky piece of plastic. I fed that through first and then very gently pulled on it to bring the power wires (and their plug) through as well. Now you can reconstruct the coax plug. Route the cable how you see fit. I spent ages trying to figure out the OEM way of positioning the cable and plugs, but never managed it! I'd love to see how it's done on a car that had the camera installed from the factory.
With the trim that's already off, you can cable tie or tape the wire to the existing loom as it heads towards the front of the car. This is where it became a nightmare. You can't really route the cable nicely / properly without taking off the rear door (but not a door in a 3dr car) trim. That's not an easy thing to do when you have no idea what you're doing! Bits of trim that look like individual parts are in fact not individual parts. The bit with the front seatbelt going through it has to come off. There are 3 clips at the bottom. One is technically on the side and hooks it over the lower trim. The other two just need pulling out from the lower trim. It's held in place at the top by 2 spears that go up into the metal work and another wrap around clip in the top corner of the rear passenger window. So once the bottom is unclipped, get the side off by the window, get your hand up behind it, try to push / pull it towards the other side of the car and pull down.
The main rear passenger trim is held in place by about 3 clips in line with the front seatbelt and numerous other ones along the top of it (bottom of the glass) and various places. With enough yanking around you might be lucky and get it off. Only you can't get it right off because it seems to fixed in position by the fixings for the rear seats?! There's a complete hole (as in, not a 'broken' hole) and one side of the fixing for the seat uprights goes through it. Anyway, with it pulled forward enough, you should manage to slide you hand behind it, route the cable and maybe tape it up as I did.
The trim by the passenger door unclips easily enough and it can be removed from the rear trim by sliding it forwards. There's a lug that stops it doing that easily, so you have to get past that and then slide. Unfortunately, that front bit of trim can't easily be removed either as it appears fixed under the rear bench.
So basically, if you want to get all of the trim off completely, it appears you need to remove the rear seats. I've done some Googling since yesterday and it appears the rear bench can be removed if you pull up from the front. There are 'U' shaped metal brackets / clips at either end (which I did see) and they have to pull out from whatever they're located in. I did give it quite a tug yesterday but was worried I would break something if that wasn't in fact how you got them out. The rear uprights might come out if you undo the centre fixing... I haven't looked into that too much.
If you can get the seats out, I've no doubt the rest would be much easier...but I cannot say if it's worth it or not time wise.
So now I have my wire to the front of the car and today I'll have a go at removing the glove box etc. and actually wiring it in.
The wires from the camera module that need wiring into the loom / fuse box are quite short... probably 1 - 1.5m, so that's why I'm thinking the box belongs at the front of the car. Plus that way, nothing needs extending.
I do have some photos from yesterday, so I'll try and insert those in the relevant places when I'm done.
Reactions: pns2007, Schizophonic and Salik Sajid
Just at work so a quick reply. Thanks for your experience with the 3rd to date. Just to clarify I have checked elsawin and the module definately goes in the rear right side of the boot.... same equivalent position of that of my 4 Dr saloon. On the cabrio it goes behind the left hand trim in the boot. Only places you can fit the large bracket/holder.
Wiring loom won't be OEM... audi didn't have OEM wiring loom when I rang so either is bits taken out or completely made up afterwards.
Regarding parts being used... DJALIX said the same when he coded my camera module as it already had coding on it rather then all 0s in the coding line.... but if it works it's fine. New parts from audi will cost 3 times more minus the loom
Reactions: rasA4
Ok so I'm stuck :(
Having told the car I've got a back-up cam installed, I can't then go into the module and do anything with it because it says there's been no response.
It's getting power ok and I'm pretty sure I've done the cam connections ok... what else could it be?!
Sure, here it is...
Code:
VCDS Version: Release 15.7.4 Running on Windows 7 x86
Data version: 20160216
www.Ross-Tech.com
Friday,29,April,2016,17:37:06:57150
Chassis Type: 8V (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 37 42 44 52 55 5F 6C A9
VIN: WAUZZZ8V8EA114263   Mileage: 26865km-16693miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 0100
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Cannot be reached 0100
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CJXC)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 259     HW: 06K 907 425 A
   Component: 2.0l R4 TFSI  H09 0006
   Revision: --H09---
   Coding: 0A1D00322426010B2004
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM20TFS0218V0906259 001008
   ROD: EV_ECM20TFS021_AU37.rod
   VCID: 7DF1C585EC2E50D615-8028
2 Faults Found:
17178 - Databus
          U1123 00 [044] - Received Error Message
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 4
                    Mileage: 26864 km
                    Date: 2016.04.29
                    Time: 09:59:42
15418 - Cam Adjustment Actuator B; Cylinder 3
          P11AC 00 [096] - Implausible Signal
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 6
                    Mileage: 25764 km
                    Date: 2016.02.19
                    Time: 16:22:45
Readiness: 0000 0000
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 011 R    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H52 4317
   Revision: 05852204    Serial number: TFK01311150552
   Coding: 0014
   Shop #: WSC 04742 780 00200
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 2447D0E12F04C11E3A-8070
1 Fault Found:
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
             Freeze Frame:
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 907 379 AA    HW: 5Q0 907 379 G
   Component: ESC           H31 0457
   Revision: 00000000    Serial number: 63233000000003
   Coding: 30F193A254212A700179070641C6690CC92A5480E08296F6024100080608
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
   ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
   VCID: 7BF5CB9DF23A5EE62B-802E
2 Faults Found:
0297 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 56
                    Mileage: 26864 km
                    Date: 2016.04.29
                    Time: 09:59:42
32928 - Function Restricted due to Insufficient Voltage
          U1400 00 [137] - -
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 17
                    Date: 2014.12.11
                    Time: 16:03:47
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Part No SW: 8V0 820 043 D    HW: 8V0 820 043 D
   Component: AC Automat    H13 0052
   Revision: 20026000    Serial number: 00000000202496
   Coding: 00100014000000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
   ROD: EV_AirCondiFrontVaAU37X.rod
   VCID: 336523BD9AEA56A6B3-8066
No fault code found.
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011333702601
   Coding: 07141C46C20106FD03044004B31C07A80000000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 012001
   ROD: EV_BCMBOSCH_AU37.rod
   Slave 1:
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 131126  041 0580
   Serial number:         131128165112
   Coding: 0A47F7
   Slave 2:
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Component: G397_RLFS  H06 0002
   Serial number: 22019092
   Coding: 00006C
   Slave 3:
   Subsystem 3 - Part No SW: 8V0 941 531 G    HW: 8V0 941 531 G
   Component: E1 - LDS MQB  H05 0032
   Serial number: 02 08 2013  00000087
   Subsystem 4 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0315
   Serial number: 000000000ZY132982R1B
   Subsystem 5 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000028308421
   Subsystem 6 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.009  H02 0007
   Serial number:     WOO2593402%
   Coding: 901E00
1 Fault Found:
204549 - Remote key 2
          B147A 54 [008] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 57
                    Mileage: 26865 km
                    Date: 2016.04.29
                    Time: 16:37:53
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231333800524
   Coding: 0030150051
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   ROD: EV_EPHVA18AU3700000_AU37.rod
   VCID: 3B750B9DB2BA9EE66B-806E
1 Fault Found:
13637426 - Databus
          U1123 00 [008] - Received Error Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 56
                    Mileage: 26864 km
                    Date: 2016.04.29
                    Time: 09:59:42
Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    011 0361
   Serial number: 003M2R049TLV
   Coding: 98CCC0000C0000005C5400CA00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
   ROD: EV_AirbaVW20SMEVW37X_AU37.rod
   VCID: 4B955B5DE21A2E66DB-801E
   Crash sensor for side airbag; driver side:
   Subsystem 1 - Part No SW: -----------    HW: 480 000 312 13
   Component: SideSensor_Df  001 0887
   Serial number: 35767000000C77056E0-
   Coding: 2D2D2D
   Crash sensor for side airbag; front passenger side:
   Subsystem 2 - Part No SW: -----------    HW: 480 000 312 13
   Component: SideSensor_Pf  001 0887
   Serial number: 358670000001C7056E0V
   Coding: 2D2D2D
   Crash sensor for side airbag; rear; driver side:
   Subsystem 3 - Part No SW: -----------    HW: 480 402 311 13
   Component: SideSensor_Dr  001 6149
   Serial number: 3516502B1122076200EP
   Coding: 2D2D2D
   Crash sensor for side airbag; rear; passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 480 402 311 13
   Component: SideSensor_Pr  001 6149
   Serial number: 35265029B1220763832Y
   Coding: 2D2D2D
   Crash sensor for front airbag; driver side:
   Subsystem 5 - Part No SW: -----------    HW: 480 401 211 13
   Component: FrontSensor_D  001 6149
   Serial number: 3556502C31088B0353D7
   Coding: 2D2D2D
   Pedestrian protection crash sensor; driver side:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 811 13
   Component: PedP_Sensor_D  001 6149
   Serial number: 22865029F1220762C061
   Coding: 2D2D2D
   Pedestrian protection crash sensor; front passenger side:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 811 13
   Component: PedP_Sensor_P  001 6149
   Serial number: 22965029F1220763805+
   Coding: 2D2D2D
   Center pedestrian protection crash sensor:
   Subsystem 8 - Part No SW: -----------    HW: 480 400 911 13
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502C51088B0371C0
   Coding: 2D2D2D
2 Faults Found:
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [137] - Open or Short to Plus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 26864 km
                    Date: 2016.04.29
                    Time: 15:37:45
9446677 - Redundant signal path for airbag shut-off; passenger side
          B1025 15 [137] - Open or Short to Plus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 26864 km
                    Date: 2016.04.29
                    Time: 15:37:45
Address 16: Steering wheel (J527)       Labels: 5Q0-953-549.clb
   Part No SW: 8V0 953 521 BP    HW: 5Q0 953 549 C
   Component: Lenks. Modul  002 0110
   Revision: --------    Serial number: 02121308490347
   Coding: A418
   ASAM Dataset: EV_SMLSKLOMQB 017001
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 0919A155A8E67C7629-805C
Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
   Part No SW: 8V0 920 970 R    HW: 8V0 920 970 R
   Component: KOMBI         H03 2220
   Coding: 27AD000A2A8046000101EA00100000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008031
   ROD: EV_DashBoardVDDMQBAB_AU37.rod
Address 19: CAN Gateway (J533)       Labels: 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001301260
   Coding: 030100042B085A005B0002681C0B00000001000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear.rod
   VCID: 3F8D7F8DA6A282C647-806A
   Alternator:
   Multifunction unit control module:
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Component: E221 - MFL  H02 0014
   Serial number: 13 11 2013  D0350735
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Component: J367-BDMHella  H03 8043
   Serial number: 1460921803
2 Faults Found:
131689 - Rear View Camera System Control Module
          U104C 00 [009] - No communication
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 16
                    Mileage: 26864 km
                    Date: 2016.04.29
                    Time: 15:37:46
131692 - No Communications with Undefined Control Module
          U1126 00 [009] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 16
                    Mileage: 26864 km
                    Date: 2016.04.29
                    Time: 15:37:46
Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00012.10.13
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002001
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 46836A69F978D30E04-8012
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver (J386)       Labels: 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 B    HW: 5Q0 959 593 B
   Component: TSG FS        020 0025
   Serial number: 25111303110358
   Coding: 005D0E205C01040100001002
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 408F7C71DB5CFD3E3E-8014
Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8103
   ASAM Dataset: EV_SteerAssisMQB 010031
   ROD: EV_SteerAssisMQB.rod
   VCID: 35611DA5949E48969D-8060
Address 52: Door Elect, Pass. (J387)       Labels: 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 B    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0025
   Serial number: 28111302090013
   Coding: 005D06205E01040100001002
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
Address 55: Headlight Range (J745)       Labels: 7P6-907-357.clb
   Part No SW: 7P6 907 357 B    HW: 7P6 907 357 B
   Component: AFS-ECU       H01 0040
   Revision: --------    Serial number: --------------
   Coding: 01AE00002B230200
   ASAM Dataset: EV_HeadlRegulLEDAFSMQB 001001
   ROD: EV_HeadlRegulLEDAFSMQB.rod
   VCID: 3E730289A1A88BCE4C-806A
   Subsystem 1 - Part No SW: 7PP 941 472 E    HW: 7PP 941 472 E  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H06 7520
   Coding: E00100
   Subsystem 2 - Part No SW: 7PP 941 472 E    HW: 7PP 941 472 E  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H06 7520
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
   Component: LeiMo links  H01 7000
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
   Component: LeiMo rechts  H01 7000
   Coding: E00100
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 8V0 035 036 D    HW: 8V0 035 036
   Component: MU-H-LND-EU   H43 0383
   Serial number: A300E0FB004145
   Coding: 017300010000000021111102000A00102F00022501000100DE
   Shop #: WSC 22828 002 104857
   ASAM Dataset: EV_MUHig6C3HBAS 001040
   ROD: EV_MUHig6C3HBAS_AU37.rod
   Engine Control Module 2:
   Subsystem 1 - Part No SW: V03 959 800 QA    HW: -----------
   Component: ECE 2016  --- 0134
   Serial number: --------------------
   Seat Adjustment Driver Side:
   Subsystem 2 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
   Component: DU High  H49 0013
   Serial number: AUZ8Z9DY2004M3
   Sound System:
   Subsystem 3 - Part No SW: 8V0 919 614 R    HW: 8V0 919 614 D
   Component: ControlUnit_H  H64 0766
   Serial number: C1000029101300010612
   Door Electronics Rear Left:
   Subsystem 4 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote  --- 1008
3 Faults Found:
6697 - Databus
          U1121 00 [008] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 57
                    Mileage: 26804 km
                    Date: 2016.04.21
                    Time: 20:10:45
7176 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 57
                    Mileage: 26864 km
                    Date: 2016.04.29
                    Time: 10:00:04
7179 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 16
                    Mileage: 26864 km
                    Date: 2016.04.29
                    Time: 16:06:55
Address 6C: Back-up Cam.
Cannot be reached
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0008
   Serial number: 131115201152
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X.rod
End-------------------------(Elapsed Time: 04:36)--------------------------
Sure, here it is...
Code:
www.Ross-Tech.com
   Revision: --H09---
2 Faults Found:
17178 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Mileage: 26864 km
                    Date: 2016.04.29
                    Time: 09:59:42
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 6
                    Mileage: 25764 km
                    Date: 2016.02.19
                    Time: 16:22:45
   Coding: 0014
1 Fault Found:
             Freeze Frame:
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 56
                    Mileage: 26864 km
                    Date: 2016.04.29
                    Time: 09:59:42
          U1400 00 [137] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 17
                    Date: 2014.12.11
                    Time: 16:03:47
   Slave 1:
   Coding: 0A47F7
   Slave 2:
   Coding: 00006C
   Slave 3:
   Coding: 901E00
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 57
                    Mileage: 26865 km
                    Date: 2016.04.29
                    Time: 16:37:53
   Coding: 0030150051
1 Fault Found:
13637426 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 56
                    Mileage: 26864 km
                    Date: 2016.04.29
                    Time: 09:59:42
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 26864 km
                    Date: 2016.04.29
                    Time: 15:37:45
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 26864 km
                    Date: 2016.04.29
                    Time: 15:37:45
   Coding: A418
   Alternator:
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 16
                    Mileage: 26864 km
                    Date: 2016.04.29
                    Time: 15:37:46
          U1126 00 [009] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 16
                    Mileage: 26864 km
                    Date: 2016.04.29
                    Time: 15:37:46
   Coding: 0001
Cannot be reached
   Coding: 8103
   Coding: E00100
   Coding: E00100
   Coding: E00100
   Coding: E00100
   Sound System:
3 Faults Found:
6697 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 57
                    Mileage: 26804 km
                    Date: 2016.04.21
                    Time: 20:10:45
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 57
                    Mileage: 26864 km
                    Date: 2016.04.29
                    Time: 10:00:04
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 16
                    Mileage: 26864 km
                    Date: 2016.04.29
                    Time: 16:06:55
Cannot be reached
Initial thoughts are you have a cabling and or power issue as your Gateway looks to be coded ok. Need to double check all your connections and possibly test each pin for continuity.
Lots of DTC's in your scan also. Might want to run an AutoScan again > clear DTC's > Untick Display Freeze Frame > Run AutoScan.
Ok so I'm stuck :(
Crickey sorry to see you are not having fun. I am about 2-4 days behind you in that I have ordered a rear cam, just waiting for delivery.
So very much interested in your progress and tips to a quick / easier future install.
Hopefully you can find / resolve the issues with @DJAlix help.
Thx
Jungle
Forgot to say will dig out the wiring / current flow diagrams also but will not be in a position to do this until tomorrow as well as I have to do the whole Greek Easter "Big Friday" thing tonight. Would rather help with this to be honest :)
Any help mate?
I think my earth point was iffy... I'd already tested it for continuity, but I've moved it now and we have lift off :)
Now I have another problem... haha!
When coding the 6C module, it must be new / have been reset as it's all zeros currently.
Coding
If I fill out the appropriate boxes in the long coding helper, my code is 027300012201000300.
When I click 'Do It!', it asks me...
VCDS: Re-Code Invalid
This appears to be an uninitialized control module;
valid WSC/Importer/Equipment data may be required.
Click [Yes] for VCDS to use default values of 12345/123/12345.
Click [No] for VCDS to try the values currently in the module.
Click [Cancel] to go back and manually edit the values.
Yes No Cancel
I've tried 'Yes' and 'No', it still fails with the same error...
VCDS
Coding rejected
Error 31: Request out of range
OK
oh and I've just redone the autoscan. Cleared DTCs, disabled freeze and done it again.
Code:
www.Ross-Tech.com
Friday,29,April,2016,19:06:33:57150
01-Engine -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
  Revision: --H09---
Readiness: 1110 0001
  Coding: 0014
  Slave 1:
  Coding: 0A47F7
  Slave 2:
  Coding: 00006C
  Slave 3:
  Coding: 901E00
  Coding: 0030150051
  Coding: 2D2D2D
  Coding: 2D2D2D
  Coding: 2D2D2D
  Coding: 2D2D2D
  Coding: 2D2D2D
  Coding: 2D2D2D
  Coding: 2D2D2D
  Coding: 2D2D2D
2 Faults Found:
  Coding: A418
  Alternator:
1 Fault Found:
  U1126 00 [009] - -
  Coding: 0001
Cannot be reached
  Coding: 8103
  Coding: E00100
  Coding: E00100
  Coding: E00100
  Coding: E00100
  Sound System:
1 Fault Found:
  U1111 00 [009] - -
Address 6C: Back-up Cam. (J772)  Labels: 5Q0-907-441.clb
  Part No SW: 5Q0 907 441 A  HW: 5Q0 907 441 A
  Component: MQB RVC Mid  H07 0140
  Coding: 000000000000000000
  Shop #: WSC 00000 000 00000
  ASAM Dataset: EV_2CamSysRearPASE 006016
  ROD: EV_CamSysRearPANAAU914.rod
  VCID: 306F2CB16BFC6DBECE-8064
3 Faults Found:
10490624 - No End-of-Line Programming
  B2013 00 [009] -  -
13636352 - Control module not coded
  U1013 00 [009] - -
10489856 - No Basic Setting
  B2010 00 [009] -  -
End-------------------------(Elapsed Time: 04:37)--------------------------
Glad it was just a dodgy earth.... where did you earth from?
Your CAN soldering looks great :D. I'm not a big one on coding so let's see what DJALIX and the likes have to say.
Question out to the forum re Power supply for reversing camera...
Just having a good look around the boot this morning and I have question re power...I know you cant tap into the reversing light power as that might throw error codes with the power spike but... Why not use the 12V socket power supply in the boot? Is that why the power lead is the length it is??
Surely that stops the requirement to run power all the way up to the fuse box at front of car.
Or am I missing something ?
Unless there are CAN connections in the boot too, you'd still need to (extend+) run those to the front anyway... Along with the video feed from the module - the lead that came with mine was only about 1.5m long and it has the little pin sockets on it to push into the 12 way plug. I'm sure they must have their reasons for making the leads the length they do.
Hats off to you @amit87 , not often to people choose to retrofit the OEM solution as the cheaper aftermarket (usually Chinese) option is usually preferred.
Well done.
Reactions: amit87
Ok thx.. Mine arrives Tuesday, so next week/ weekend I have some fun in store!
Yes No Cancel
VCDS
Coding rejected
OK
Try:
VCDS Main Screen > Options > User Interface and Identification > Enter 12345/123/12345 > Save
Screen Shot 2016 04 30 at 175441
Try long coding again and let us know how you get on. If all is ok then:
VCDS Main Screen > Right Click on VCDS Icon in the top left of window > Delete config file and close (to return VCDS to stealth mode - all the zeros)
Screen Shot 2016 04 30 at 175502
Thanks for the suggestion DJAlix.
I've done what you said but it still doesn't work :(
Code:
www.Ross-Tech.com
  Revision: --H09---
  Coding: 0014
  Slave 1:
  Coding: 0A47F7
  Slave 2:
  Coding: 00006C
  Slave 3:
  Coding: 901E00
  Coding: 0030150051
  Coding: 2D2D2D
  Coding: 2D2D2D
  Coding: 2D2D2D
  Coding: 2D2D2D
  Coding: 2D2D2D
  Coding: 2D2D2D
  Coding: 2D2D2D
  Coding: 2D2D2D
2 Faults Found:
  Coding: A418
  Alternator:
1 Fault Found:
  U1126 00 [009] - -
  Coding: 0001
Cannot be reached
  Coding: 8103
  Coding: E00100
  Coding: E00100
  Coding: E00100
  Coding: E00100
  Sound System:
1 Fault Found:
  U1111 00 [009] - -
3 Faults Found:
  B2013 00 [009] -  -
  U1013 00 [009] - -
  B2010 00 [009] -  -
You seem to have added a module within your Gateway which the 8V does not use - 37-Navigation. Might want to un-tick this :) The other remaining DTC's look to be related to your ongoing install.
Just thought I would update the thread in relation to RB_172's issue. I believe it would seem that the place the module was sourced from "tried" to flash the module back to stock / factory settings before sending it out... but they have not completed the process correctly, hence the "No End-of-Line Programming" DTC. Unit needs to be re-flashed and tested or exchanged.
Reactions: amit87 and RB_172
Hi guys,
New here.. Recently purchased a S3 Sedan that came with 5.8" display, AMI and BT... I'm in the process of adding a Mirrorlink for AirPlay on my car, but also wanted to upgrade to 7" display. Does anyone know if I grab one of the 7" display off eBay, is it a direct swap or is there any coding needed to convert it to the high resolutions? Thanks!!
Hi guys,
Screen change is not possible as its hardware limited. The standard MMI unit does not have the video card or the drivers capable of running the larger screen.
Thanks for the info! Oh well guess will have to go aftermarket screen then...
Installed Audi Rear Camera retrofit today with a lot of help from @RB_172 . Thx also go out to @amit87 who put a guide up and assisted with all of my many questions.
Things are very different between a saloon and hatchback/sportback. We took lots of photos so will be adding to the guide with a lot more detail over the next coming weeks.
It was a long slog... But pleased as punch.
Thx guys... Really appreciated.
Reactions: Salik Sajid, amit87, RB_172 and 1 other person
I took lots of photos during my recent install and working alongside @amit87, @RB_172 and @DJAlix the original guide has now had a major update.
The original link will automatically take you to the latest version. Below is the link again for the lazy.
https://www.dropbox.com/s/h22a6xa5g...Reverse Camera Retrofit Guide_SECURE.pdf?dl=1
@Bristle Hound , @Sandra if you feel this is worthy pls can you place in the sticky threads under the same place as other "How to" fitting guides.
http://www.audi-sport.net/xf/thread...how-to-guides-on-the-8v-chassis.198794/page-2
Thx v much
Jungle
Reactions: RB_172 and DJAlix
Nice update to the guide Jungle :) Love that you added you'd spent ages trying to get the boot release out and I did it in about 3 seconds! haha
Hate to nit-pick but I had a quick look and spotted a couple of bits that aren't quite right to do with the fusebox.
There are *3* tabs you need to push in / unclip in order to remove it and you *only* need to slide out the top purple thing (it only moves a few mm) in order to then slot the new power connector / cable into place (which you can locate into position more easily if you guide it in having poked a long/thin screwdriver through from the front - as per the pic). Unless you've got tiny fingers and fingernails of steel, lever the purple thing out with an allen key or something. Space is somewhat limited in the working area and it's not easy to get a screwdriver in there to do it.
Oh and the guide mentions fixing it into slot SC18... but on my fusebox, the slot is actually labelled F18 (on the front anyway).
Reactions: amit87
Thx @RB_172 we will get that amended and updated.
The boot release still gives me nightmares and makes me laugh in unison! What a pig on the hatchbacks. You clearly had the knack !!
@amit87 pls can you amend as above where appropriate.
Many thx
Jungle
Reactions: DJAlix and amit87
Thanks very much @amit87 for the detailed write-up and @DJAlix for the support along the way.
After reading you posts, I have already ordered a reverse camera set and it will arrive this week. I can't wait to have it installed on my basic MMI (no nav and low res.)
Reactions: DJAlix, Usman786 and amit87
Finally fitted with the reverse camera. Without the guide I could not have coordinate my supplier to custom made the cable looms (as they only supply the one for LHD vehicles) here are some pics of the retrofit.
Reactions: jungle650, DJAlix and amit87
Had the opportunity to conduct some testing around the issue which some people are having when trying to code the 6C Camera Module.
A module supplied with all 0's was returning "out of range" and "no end of line coding" errors. The module was posted to me, I made up a custom loom and connected the module to my own car for testing, and in order to resolve the issues a firmware re-flash and a parameterisation were needed.
If anyone encounters the same issues and cannot code their module, and cannot return / exchange it, please feel free to send me a message :)
Reactions: dantdi, pns2007, fatyin and 4 others
Hi Guy's, great write up and thanks for all the info.
My kit arrived yesterday and I'm hopefully going to start my install later and/or tomorrow. The loom that came with my kit looks as though the camera module is designed to go in the front. Has anyone had this or can recommend where to site the camera module safely and securely. Not taken apart as yet and just planning ahead.
(S3 Sportback)
Reactions: DJAlix and TimWills28
There are 2 horizontal metal supports that become visible once the glovebox is out. One will probably have a tracker on it, the other is perfect for the module.
Reactions: jungle650 and pns2007
