Retrofit reverse camera
calw123
Chesterfield
Afternoon,
So today I have fitted a genuine reverse camera by following the pdf guide that I found on the forum all went well, now I have access to obdeleven and I have activated anything I can see relating to reverse camera and still nothing.
Could anyone advise what I need to do and if it's possible with obdeleven ?
Many thanks
Reactions: dantdi
Well guys I got this all sort thanks to DJAlix couple of messages sent me the long coding all up and running, the man's a genius
Reactions: dantdi, Baldyone, AlS3BE and 4 others
Afternoon,
Many thanks
Hi any help as I fitted the camera but try to code but nothing shows on the mmi screen?
details like...
part number
connections
coding changes made
More chance of guess the colour of your car then the reason your camera is not working without detail.
details like...
part number
connections
coding changes made
details like...
part number
connections
coding changes made
B
details like...
part number
connection
coding changes made
just found out it’s an Ali express camera
8VQ 827 566 B
Code vps to activate and vps bus to terminal 15 still don’t work
Need to change coding in 10, 19 and 6C also, but looking at the part number it’s incorrect for the car. Could be that the camera has been flashed to work on an a3 tho. Need to visit a specialist.
Aliexpress stuff is hit and miss. Some bits work great, other bits don't at all.
If you've checked all the wiring is correct and coding is correct, you'll have to get another camera.
