NA vs FI is a world apart. volumetric efficiency can be dramatically changed by altering teh ratio of stroke to bore (under square vs oversquare), whilst this is still important to the character of the engine dynamics with a turbo engine you are not relying on those characters to fill the bore with air by creating a vacuum and "drawing air"....you have ****** great turbo pushing it in sometimes at pressures higher than your tyres!
If you bore a turbo block and lose torque you have done it wrong. you can actually lose overall available torque across the curve by big porting everything (inlet, TB, valves, exhaust ports). you have a big port head anyway (BAM/AEB S3 heads) , leave it alone unless you are really looking for a massive top end and are fitting a much larger Inlet manifold. It does just fine with stock cams and stock ports and bang for buck is an expensive option. get your valves done as you won't want the heads dropping off at higher revs and temp.
your stock block is bored at 81mm.
It can take 83.5 but you are sailing very close to the edge.
83mm is a good compromise. It also gives you the option of using readily available 2l gasket kits.
Coupled with a longer 92.8mm crank and you can have a nice 2008cc block, otherwise a stealthy 1.9l. (a lot less hassle than the stroker as well!)
personally I think the 1.8t engine benefits from it as it lacks driveable torque at low revs. but it depedns entirely on your driving style. It you are rev limit bouncer then you probably won't see any difference as the top end figures are more limited by the port sizes and flow restrictions in your turbo, exhaust and head/inlet as someone else mentioned.
If you like to tootle around town with your kids in the back and get sick of dropping into first gear when you go round very slow corners then you should see a useful (but not mindblowing) increase in torque.
your stock pistons are bulletproof. re-ring and hone will see you a long way.
If you want to change the dynamics of the way your engine delivers power an give you potential for spooling much larger turbos more effectively in the future then bore it
