RichHouseman
- Joined
- Jan 2, 2014
- Messages
- 11
- Reaction score
- 0
- Points
- 1
Evening, been having issues with my electric steering rack for a while now. i was using a snap on verdict computer to look through for any fault codes last night. when i came to the car this morning it wouldnt start and all the the dash warnings are on. the radiator fan is running all the time. i got it plugged in to vag com tonight and this is what was found on the full scan. im just wondering if any one has come across this before after using a diagnostic and then the next morning the car not playing ball.
thanks for your time and i look forward to anyone's advice!
Thanks again
Rich
[FONT="]Thursday,27,February,2014,18:51:21:51710
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
Dealer/Shop Name:
Workshop Code:
VIN: WAUZZZ8P14A076066 License Plate: YC53MBD
Mileage: 237730km-147718mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WAUZZZ8P14A076066 Mileage: 237730km/147718miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Cannot be reached 1100
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 B HW: 8P0 820 043 B
Component: KlimavollautomatH11 0130
Shop #: WSC 00000 000 00000
VCID: 2B5FE9E48ACCCE46111-807E
3 Faults Found:
01592 - Air Quality Sensor (G238)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 7
Reset counter: 145
Mileage: 237736 km
Time Indication: 0
Date: 2014.02.20
Time: 19:42:50
Freeze Frame:
Temperature: 14.5°C
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 7
Reset counter: 145
Mileage: 237736 km
Time Indication: 0
Date: 2014.02.20
Time: 19:35:50
Freeze Frame:
Temperature: 8.5°C
Voltage: 12.30 V
RPM: 0 /min
Load: 0.0 %
Load: 9.0 %
01206 - Signal for Duration of Ignition Off Time
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 105
Mileage: 237736 km
Time Indication: 0
Date: 2014.02.20
Time: 00:04:42
Freeze Frame:
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H29 0501
Revision: 00029000 Serial number: 00000000172212
Coding: 05884F00A2141000000000000000000000
VCID: 3B7FD9A47AAC5EC6811-806E
Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0180
Coding: 16711696
Shop #: WSC 00000
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 009 0030
Coding: 0000012
Shop #: WSC 06435 000 00000
VCID: 3065FE88A3EAAD9E243-8065
No fault code found.
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 HX HW: 8P0 920 980 HX
Component: KOMBIINSTR. VDO H25 0160
Revision: D14 Serial number: 2249ED14000679
Coding: 0004403
Shop #: WSC 05467 067 57207
VCID: 942DD218B7B2F1BEA0B-80C1
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 2400103802DA64
Coding: 3D0F0B40070101
VCID: 264918D0912EF32ECEF-8073
5 Faults Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 237736 km
Time Indication: 0
Date: 2014.02.20
Time: 00:05:07
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 237736 km
Time Indication: 0
Date: 2014.02.20
Time: 00:05:07
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 237736 km
Time Indication: 0
Date: 2014.02.20
Time: 00:05:07
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 237736 km
Time Indication: 0
Date: 2014.02.20
Time: 00:05:07
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 237736 km
Time Indication: 0
Date: 2014.02.20
Time: 00:05:07
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D14 Serial number: AUX7Z0C8FN9084
Shop #: WSC 00673 210 83197
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000120
Shop #: WSC 00673 210 12142
VCID: 3973C3AC70906CD693D-806C
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 008800186D288505485AC63000
Shop #: WSC 63142 116 54170
VCID: F9F383ACB0102CD653D-80AC
Subsystem 1 - Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Subsystem 2 - Part No: 1K0 907 719
Component: Neigungssensor 002 0002
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
1 Fault Found:
01312 - Powertrain Data Bus
013 - Check DTC Memory
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000120
VCID: 3A71DCA0759667CE9A7-806F
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 195 HW: 8P0 035 195
Component: symphony II EU H55 0460
Revision: 23S Serial number: AUZ5Z4C5374322
Coding: 0011201
Shop #: WSC 00652 210 81339
VCID: EFE7BDF4FE547266FD9-80BA
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
Component: PTC-Element 0404
Revision: 00600000 Serial number:
End ---------------------------------------------------------------------
[/FONT]
Thanks again
Rich
Dealer/Shop Name:
Workshop Code:
Address 01: Engine
Cannot be reached
Cannot be reached
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 145
Mileage: 237736 km
Time Indication: 0
Date: 2014.02.20
Time: 19:42:50
Freeze Frame:
Temperature: 14.5°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 145
Mileage: 237736 km
Time Indication: 0
Date: 2014.02.20
Time: 19:35:50
Freeze Frame:
Temperature: 8.5°C
Voltage: 12.30 V
RPM: 0 /min
Load: 0.0 %
Load: 9.0 %
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 105
Mileage: 237736 km
Time Indication: 0
Date: 2014.02.20
Time: 00:04:42
Freeze Frame:
Coding: 16711696
Shop #: WSC 00000
1 Fault Found:
Address 15: Airbags
Cannot be reached
Coding: 0000012
Coding: 0004403
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 237736 km
Time Indication: 0
Date: 2014.02.20
Time: 00:05:07
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 237736 km
Time Indication: 0
Date: 2014.02.20
Time: 00:05:07
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 237736 km
Time Indication: 0
Date: 2014.02.20
Time: 00:05:07
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 237736 km
Time Indication: 0
Date: 2014.02.20
Time: 00:05:07
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 237736 km
Time Indication: 0
Date: 2014.02.20
Time: 00:05:07
Coding: 0000120
Cannot be reached
1 Fault Found:
Coding: 0000120
Coding: 0011201
[/FONT]
