8V VCDS Mods
Can confirm the same. I did pop out the other day to test but was limited on time. Was just in the car and found the Regulator settings and tests within the "front" modules. I also cannot find any control modules for rear doors within ElsaWin. Diagrams have what look like pictures of a module but it's not itemised. At this point I think that the needed settings are gonna be unlabelled bits within the bytes of the fronts. A full beta of VCDS 15.7.3 is gonna be out soon (the one I linked above, before investigating, is the vcds.exe only needed to fix a communication bug with MIB mk2's) and will have updated label files. For the moment tho I am gonna see if I can raise this with RossTech to see if they can advise further.
Definitely there is a rear door module
the part number is 5Q0 959 595
it has been shown on etka
Hello
I retrofited a oem parking kit
I can access and programming adress [10]
But i cant activate the visual display on mmi+ screen
Hello
Assuming your retrofit has been successful, and you have an up to date VCDS install, you will need to complete the following:
  • Control Module 10 - Park/Steer Assist
  • Coding - 07
  • Long Coding Helper
  • Select Byte 02
  • Bit 0 Optical Parking System (OPS) Active = Enable
You may also need to to set Bits 2-3. Trying testing one at a time with the following in addition to the above:
  • 04 Display and Operating Protocol (BAP) v4.0 active
  • 08 Display and Operating Protocol (BAP) v3.3 active*
*factory setting for cars with rear sensors only
  • Coding - 07
  • Select Byte 02
thank you
i already tried change bit 0
in my car bit 2-3 is setted "04 Display and Operating Protocol (BAP) v4.0 active"
i try to change
i still getting this errors:
Sunday,27,December,2015,15:04:20:04550
VCDS Version: Release 15.7.0 Running on Windows 10 x64
www.Ross-Tech.com
Address 10: Park/Steer Assist Labels: 5Q0-919-294.clb
Control Module Part Number: 5Q0 919 294 E HW: 5Q0 919 294 A
Component and/or Version: PARKHILFE 8K H03 0048
Software Coding: 0031051011
Work Shop Code: WSC 00028 028 00025
ASAM Dataset: EV_EPHVA18AU3700000 002024 (AU37)
ROD: EV_EPHVA18AU3700000_AU37.rod
VCID: 3D64249BFD71576A3406779-8068
2 Faults Found:
12583936 - Data Bus for Suspension
U10AC 00 [008] - No Communications
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 17
Reset counter: 191
Mileage: 9233 km
Date: 2015.12.25
Time: 12:12:51
12666390 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 144
Mileage: 9233 km
Date: 2015.12.25
Time: 12:12:40
Can you detail what parking options your car had before your retrofit indeed the items which you did retrofit?
Example:
Before = Rear parking sensors only
Retrofit = front parking sensors, front parking control module and Parking Plus button
Example:
My car had no parking sensors.
I bought a full kit from www.cars-equipment.com
In the kit all wires has labels indicating where to conect.
2 wires are not conected, the ones that must connect to dashboard switch. We tried, but the pins indicated i think are not correct, because the switch not worked and the light was allways on.
Having trouble finding the kit on that site, but is not an issue. First things first, can you let us know what codings and adaptations you have completed up to this point and can you confirm what is and what is not working (if anything)? Sorry for the questions. I am just trying to work out a "start point" if you see what I mean?
With regards to the errors you have at the moment complete the following:
  • Run an Auto Scan
  • Once complete, Clear all DTC's
  • Once complete, Untick the "Freeze Frame" option
  • Run an Auto Scan again
As for the x2 wires you are yet to connect, I am guessing that the "Kit" came supplied with a replacement switch panel. If yes and the button is staying "yellow" it could be that your wires are reversed (but am guessing you have tested this) or that your coding is incorrect as you do need to tell the "car" that a button has been installed.
@DJAlix disconnecting the battery negative terminal wire will reset all the setting to factory stock? i have done visual parking aid, needle sweep and oil temp on DIS thru vcds, will i have to do coding again after removing battery wire?
I've disconnected the battery to remove my steering wheel air bag - it will not reset any VCDS codings.
Reactions: Salik Sajid
thanks, for how long u need to disconnect the battery terminal
As far as I know this won't reset any VCDS mods you have to go back into VCDS and change the values back - if you did an autoscan and saved it or set it to log any mods then look back at these for original values.
As already said, disconnecting the battery will not wipe / revert and changes, it might cause issues with your parking brake tho but nothing that will not reset on its own.
The only process that might wipe your settings is if you take your car to a dealer for works and they perform a software update, everything will be returned to factory settings. I have made a sheet detailing all my retrofits and settings and always give this to the dealer when leaving my car with them so they know what to do. Some retrofits like auto lights and wipers they can add to the online database (PR code list)..
Reactions: Rob2k68 and Salik Sajid
  • Run an Auto Scan
I really, really appreciate your effort in helping me
I did the autoscans
Code:
Monday,28,December,2015,19:53:04:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
VIN: WAUACJ8V8E1016611   License Plate:
Chassis Type: 8V (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 30 42 44 52 55 5F
VIN: WAUACJ8V8E1016611   Mileage: 9532km-5922miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
30-Special Function II -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-CJSA)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 B    HW: 06K 907 425 A
   Component: 1.8l R4 TFSI  H09 0003
   Revision: --H09---
   Coding: 0A2500122404010B2800
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM18TFS0218V0906264B 001003
   ROD: EV_ECM18TFS0218V0906264B_AU37.rod
   VCID: 3B6C27CFE365595A0A32591-806E
No fault code found.
Readiness: 1110 0001
Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
   Part No SW: 0CW 300 046 C    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5110
   Revision: 00043014    Serial number: CU501310137025
   Coding: 0014
   Shop #: WSC 17734 418 534600
   ASAM Dataset: EV_TCMDQ200021 001001
   ROD: EV_TCMDQ200021_AU37.rod
   VCID: 3A6222CBEC5F6052112454D-806E
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 907 379 AA    HW: 5Q0 907 379 G
   Component: ESC           H31 0457
   Revision: 00000000    Serial number: 63203000000410
   Coding: 13F16AA234212A72017D060141C429C8562C5480608294F4004100388608
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
   ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
   VCID: 7BECE7CFA3E5995A4AB2991-802E
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H13 0052
   Revision: 20026000    Serial number: 00000000188722
   Coding: 03000014110000011000000000001500
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
   ROD: EV_AirCondiFrontVaAU37X.rod
   VCID: 32720AEB342F9812D994FCD-8066
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011332100982
   Coding: 04141A42C26122FD03804004B10807A80000000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 012001
   ROD: EV_BCMBOSCH_AU37.rod
   Slave 1:
   Subsystem 1 - Part No SW: 8V1 955 119 C    HW: 8V1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 131009  041 0585
   Serial number:         131010225604
   Coding: 0A47F7
   Slave 2:
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Component: G397_RLFS  H06 0002
   Serial number: 21947355
   Coding: 00006C
   Slave 3:
   Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
   Component: E1 - LDS MQB  H05 0032
   Serial number: 12 08 2013  00000797
   Subsystem 4 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0315
   Serial number: 000000000ZY1326744PW
   Subsystem 5 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000028151891
   Subsystem 6 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.009  H02 0007
   Serial number:     WOO2559988K
   Coding: 901E00
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 94231414703117
   Coding: 0031051011
   Shop #: WSC 00028 028 00025
   VCID: 3D6829D7FD71576A3406779-8068
1 Fault Found:
12666390 - Databus
Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Component: AirbagVW20    014 0385
   Serial number: 003MMR00GJ4R
   Coding: 98CCC000000000005C540000004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
   ROD: EV_AirbaVW20SMEVW37X_AU37.rod
   VCID: 00169023CA03FA821F60D65-8054
   Crash sensor for side airbag; driver side:
   Subsystem 1 - Part No SW: -----------    HW: 480 003 010 13
   Component: SideSensor_Df  001 0887
   Serial number: 357670000006D76C1E01
   Coding: 2D2D2D
   Crash sensor for side airbag; front passenger side:
   Subsystem 2 - Part No SW: -----------    HW: 480 003 010 13
   Component: SideSensor_Pf  001 0887
   Serial number: 358670000003D66C1E0+
   Coding: 2D2D2D
   Crash sensor for side airbag; rear; driver side:
   Subsystem 3 - Part No SW: -----------    HW: 480 400 811 13
   Component: SideSensor_Dr  001 6149
   Serial number: 3516502991118A30E10-
   Coding: 2D2D2D
   Crash sensor for side airbag; rear; passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 480 401 511 13
   Component: SideSensor_Pr  001 6149
   Serial number: 3526502A11230BC321E/
   Coding: 2D2D2D
   Crash sensor for front airbag; driver side:
   Subsystem 5 - Part No SW: -----------    HW: 480 401 511 13
   Component: FrontSensor_D  001 6149
   Serial number: 35565029D1230BC31320
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels: 5Q0-953-549.clb
   Part No SW: 8V0 953 521 BT    HW: 5Q0 953 549 C
   Component: Lenks. Modul  002 0110
   Revision: --------    Serial number: 13101304400902
   Coding: 8018
   ASAM Dataset: EV_SMLSKLOMQB 017001
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 0D08B9178D51A7EA64E6479-8058
Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
   Part No SW: 8V0 920 870 G    HW: 8V0 920 870 G
   Component: KOMBI         H03 2220
   Coding: 078D19082B8000081A00EA00100000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008031
   ROD: EV_DashBoardVDDMQBAB_AU37.rod
   VCID: 3F9453DFF77D457A261A6D1-806A
1 Fault Found:
16777026 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 151
                    Mileage: 9233 km
                    Date: 2015.12.25
                    Time: 13:10:23
1 Fault Found:
          U1110 00 [009] - -
Address 19: CAN Gateway (J533)       Labels: 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2163
   Revision: --------    Serial number: 18111310801186
   Coding: 030100042B085A005B0002481C0B00000001000000000000000000000000
   ASAM Dataset: EV_GatewConti 010015
   ROD: EV_GatewConti.rod
   Alternator:
   Multifunction unit control module:
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Component: E221 - MFL  H02 0014
   Serial number: 25 10 2013  C0368803
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Component: J367-BDMHella  H03 8043
   Serial number: 2164821503
Address 30: Special Function II (J843)       Labels: None
   Part No SW: 8V0 907 440     HW: 4H0 907 440
   Component: STS MQB       H06 0020
   Serial number: 00000000048725
   Coding: 1C1000
   ASAM Dataset: EV_PrepaTrackSysteAU37x 001032
   ROD: EV_PrepaTrackSysteAU37x.rod
   VCID: 76FAF6FB98C7C43235FCC0D-8022
Address 42: Door Elect, Driver (J386)       Labels: 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Component: TSG FS        020 0025
   Serial number: 19101303110829
   Coding: 001C0E204100040000001002
   ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 3E6A2EDBF0774C722D0C78D-806A
Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 P    HW: 5Q0 909 144 P
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 8103
   ASAM Dataset: EV_SteerAssisMQB 010031
   ROD: EV_SteerAssisMQB.rod
   VCID: 419055278189338A50EE1B9-8014
Address 52: Door Elect, Pass. (J387)       Labels: 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Component: TSG BFS       020 0025
   Serial number: 14101306070596
   Coding: 001C06204D00040000001002
   ASAM Dataset: EV_DCUPasseSideEWMINKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Part No SW: 5Q0 907 357     HW: 6R0 907 357 A
   Component: LWR-ECU       005 0080
   Revision: --------    Serial number: --------------
   Coding: 019A000001000000
   ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
   ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
   VCID: 75F8F1F785C1CF2A3CF6DF9-8020
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 8V0 035 045 B    HW: 8V0 035 045
   Component: MU-H-N-RW     H42 0282
   Serial number: A307K0D7503474
   Coding: 01730103FF0A000021220001001A00002F000104010001005E
   ASAM Dataset: EV_MUHig6C3HBAS 001040
   ROD: EV_MUHig6C3HBAS_AU37.rod
   VCID: 317005E73129A30AA08ECB9-8064
   Engine Control Module 2:
   Subsystem 1 - Part No SW: V03 959 800 TF    HW: -----------
   Component: ROW 2016  --- 0055
   Serial number: --------------------
   Seat Adjustment Driver Side:
   Subsystem 2 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
   Component: DU High  H49 0013
   Serial number: AUZ8Z9DY2001SJ
   Sound System:
   Subsystem 3 - Part No SW: 8V0 919 614 R    HW: 8V0 919 614 D
   Component: ControlUnit_H  H64 0766
   Serial number: C1000014091300010230
   Door Electronics Rear Left:
   Subsystem 4 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote  --- 4005
1 Fault Found:
7207 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
End-------------------------(Elapsed Time: 03:40)--------------------------
here`s my [5F] adapdations, besides the OPS, i lost the "joker" button too
http://txt.do/5fzr7
http://txt.do/5fzrn
Reactions: DJAlix
I only have a few mins to look at this at the moment but will be back on line in a few hours.
Configurations via Coding look to be OK for the "Joker" button. Adaptations still need to be checked.
Looking at Codings for OPS:
  • 01 - Engine > Byte 3 > Bit 5 needs to be Active
  • 10 - Park/Steer Assist > Byte 1 > Bit 0 I believe needs to be unticked
Within Byte 1 you also currently have Bits 4 and 5 active. Currently VCDS does not have labels for these so I am not sure as to what they are but I have not yet seen them activated.
Errors / DTCs:
  • 5F = Do you have Satellite Radio or Connect with no subscription or has your subscription just run out?
  • 10 / 17 = Present themselves as possible cable / wiring issues but are more than likely coding problems.
My iPhone screen is to small to work with for the moment so I will message you when I am back in front of my Mac.
Tried to enable rear DRLs this afternoon but under channel 9 Leuchte 23SL HLC 10 there were a load of options but none saying Tagfaghrlicht which I believe is the setting needed.
Using VCDS 15.7.3, any ideas ?
Looks like RossTech may have been using Google Translate :)
Attached is a screen cap of my 15.7.3 Admap which has rear DLR active.
Reactions: Rob2k68
Awesome thanks for that - top work!
I didn't see that or would have had a shot at it but could have easily missed it I'll have another look tomorrow. Thanks again.
Reactions: DJAlix
Which method are you using to activate this?
Leuchte23, 24, 26 and 27 ?
Reactions: Rob2k68
Yes that's right as per your pdf. I'm not aware of any other.
Could you test something for me while doing it? Could you code 23 & 24 and then test the results please? Reason for asking is that last time I did this to a (15 plate) 26 & 27 were not needed it seemed. I ended up fully coding anyway but would be cool to know if possible with only the two channels.
Reactions: Rob2k68
Yes of course.
Reactions: DJAlix
I can confirm 26/27 weren't needed on my 65 plate
Yes same here on my 15 plate I've just nipped out and coded it 23 was LHS and 24 RHS. No idea is there's any drawbacks from only coding two but that's what I've done for now.
I would just suggest testing what the lights do in all switch positions and all lighting conditions (assuming you have auto lights).
Reactions: Rob2k68
Yes I'll have a good look tomorrow and will probably enable 26/27 to be on the safe side - the darts is on now lol !!
Reactions: josedebardi
Darts... That still on at Alexandra Palace? 5mins walk from where I live :)
I knew there was a reason the rear DLR mod had stuck in my mind and I just remembered. This was one of the first mods I found as opposed to worked out. Knowing what I know now I just worked out the following:
  • (9) Leuchte26NSL LA72 light function D26 = Rear Left Fog Light, Inner Cluster
  • (9) Leuchte27NSL RC6 light function D27 = Stand Back Lights Left and Right, Inner Clusters
So only 23 and 24 need coding to activate DLR. I have all four coded and have not seen any issues but my first job when I get back to the UK will be to revert the coding for 26 and 27 back to "Not Active".
Reactions: Rob2k68
Yes Aly Paly is epic getting really good. I was wondering if SL was side lamp and that NSL was something else but couldn't make much sense of it also whether the inner and outer lights were separate which they're not so what you said makes perfect sense. I'll leave mine as just the two set. Many thanks - have a good time wherever you are anywhere hot for the New Year ?
Greece visiting the in-laws, hence why I sat on my laptop talking to you guys and trying to figure out @Aluzjunior's Parking Sensor / MMI issues + other bits lol Was 19c today but set to hit -5 and snow on NYE!
Reactions: Rob2k68 and Wondering Soul
Little update for folks interested in adding drive select. I went the official route and bought the retrofit kit 8V0-063-765 (8V0-063-765A is for manual transmission). Anyway, I got a local dealer to activate it and something weird is going on. I'd previously coded the front fogs to the static cornering lights. Drove home in dynamic mode and got home and the front left fog light was showing as blown on the DIS. Turned off, set to comfort and the static cornering lights work again.. Since drive select apparently also changes some of the settings for cornering lights - has anyone any idea why I'd be getting errors on dynamic? Also, the fog lights no longer work as actual fog lights lol press the button but nothing happens.. Weird.
I checked all my other vcds mods remained after visiting the dealer and they're there, but the fogs/cornering on dynamic is weird.
I took a full scan of 09 and 5F by the way prior to getting drive select activated and will let you know if I see any differences. Just need to see how I can also get efficiency turned on too. Dealer didn't manage that sadly even though the retrofit said it should be there.
Ignore my last post :/ They didn't clear out an undervoltage error and they reset the light switch coding. It's all working now. As for ad maps before vs now - they're all the same as before except 09 where the drive select switch (the one on the dash) is now checked. Can't find anything to enable efficiency but then again I can't find anything for the other drive profiles either. It's definitely worth it though just for the dynamic steering. Have contacted Audi in Germany to see why I don't have efficiency and will report back if they have anything to say.
When I got my ADS installed earlier I had my Macbook and vag-com cable in the boot just incase they messed with anything :) The only ones I was concerned about were the euro rear led's you helped me out with in the summer Alex! Didn't want amber brake lights going home lol I seem to have found a good dealer and a tech who also has vag-com at home for his S3... lol
On the battery disconnect, all it does is reset your current trip info (miles, mpg) and the clock in MMI. Everything else stays the same. No idea why it forgets the time when it remembers the date, but whatever. The official word on what to do after reconnecting the battery is do the one touch windows up and down a couple of times, and drive a few metres to lose all the abs and tire pressure errors. Unofficially the steering also feels a bit off for a while too but it'll come back and the parking brake will take a couple of presses to disengage at first.
Quick vcds question: How do we view the adaptation screen shown here?
http://www.ross-tech.com/vcds/tour/adaptation_screen.html
It seems from other posts for other models ADS is in channel 66 in 09 Central Electronics and the sum of the value corresponds to which drive select profiles you can view. Only problem is I can't see or "read" this channel. If there's a way to see it, it might show a number that corresponds to what I see today with my profiles which should be 15 and making it 47 should add efficiency. I'm guessing though that our adaptation view is different because they already have labels for the hundreds of 09 channels. Only thing is trying to find which one is this "channel 66".
So if you just type 66 into the channel box, what do you get?
In a word - nothing of any use. I even went through the whole 09 ad map and translated all the channels in Google docs and none of them are related to drive select. Maybe it's not in 09 like other models. As mentioned before, nothing in 09 changed before or after the dealer did the drive select activation. Just wondering if it's some channel we can't see in vcds? I dunno..
Either you get an error 'channel cannot be read' or you will get something...
Looking around, it seems channels 63-66 were the way to do on on other platforms, but can't see any reference to it on the 8V.
I did find people mentioning activation of channels 86 and 88 to enable the ADS menu in general in the 5F module, so might be worth looking in that module for some other options.
Reactions: kc1174
Hey! That was a nice little project and you know what? This post prompted me to look in my junk mail box just now as I thought I had not heard back from you all this time, turns out there is an email from you in there! :) Will catch up in a little bit.
That screen you are looking for is the "non-UDS" module adaptation screen, think 8P as an example. You will not see this adaptation method with our control modules.
I have a number of before and after ADS maps which people have been sending me and have spotted a few differences. Problem is that RossTech have not labeled all the related bits as yet and VagTech (VCP) has even less, that and not having a non ADS car to play with means the project is kinda on hold but I am close to cracking it. As with other models I also thought that gaining access to the Green Engineering menu would assist but I have now done that and it's diagnostics only.
I have some notes for Efficiency Mode but from memory there is not much to it unless you have an S-Tronic. It's mainly DIS prompts telling you to close windows and stuff to stop drag.
Reactions: kc1174
Ha! Yeah most of my important emails end up somewhere else or Gmail flag them as "social" and I don't look at them lol Hope you're well!
That makes sense now looking back at the manuals but for some reason I was reading UDS as something for VW light trucks lol
Yep my DIS already has the efficiency thing in there from stock - the whole "roll up your windows you're causing drag" or whatever messages and instant and current trip mpg etc (which by the way are pretty conservative numbers compared with what my real world numbers show). I think the efficiency mode in MMI for ADS does things like drop dsg into neutral when your foot's off the accelerator from what I've read. If you need any ad maps off me let me know and I'll send them to your junk folder ;) Actually, if you spot any places in the maps with ADS with a value of 47 I'll be a guinea pig and see what the same adaptation says on mine. If the same channel has a value of 15 on mine, then that might be where we choose which profiles we get. By the way, I heard back from Audi in Ingolstadt "Please be advised that all concerns related to products and services provided in the US market fall under the jurisdiction of
our USA affiliate, Audi of America Inc."... ***...
