Dead Car
DieselJake
Well-Known Member
The Internet
My car's taken that stop start technology and decided to use it cutting out on a roundabout :aggressive:. She runs for a short while then cuts out after you give her a couple revs whether it's parked or in moving, seems to be fine sitting with the engine on without revving the accelerator. No idea what the problem is but the guy who pulled it home said it could be the EGR... I'm not brilliant with engine components but surely a blocked EGR would just pump crap into the engine, been meaning to clean and blank it for a while but surely it's something else :think:. It's a 1.9tdi manual 130bhp.
Please help!
Here's a picture of her crying for mercy on the roundabout
Sorry to read about your troubles. I'm in a similar boat right now, so hope you find a fix soon that doesn't empty your bank account.
It mght be your shudder valve on the egr. Try disconecting it.
The black plactic thing next to egr. Just pull hose off and stick a large nail or screw or anythink to stop crap getting in.
EGR blanking plate off eBay for £3 and 30 minutes to fit. Best mode ever, better mpg and no rev fluctuations on idle on my 1.9 PD in my Passat. Currently on 207k miles!
No help to your cutting off problem though. Could be MAF sensor, temp sensor, or crank sensor. If its had cambelt done recently, could be fuel pump timing. Hope it's a cheap fix!
Cheers, hopefully we hit two birds with one stone in that case.
Not going to lie I'm useless under a bonnet haha may have got it with this solution though will definately give that a shot, thanks Deano :happy:
Picked one up a while back but never fitted :crying: god I need to stop collecting parts and start fitting them haha. 207k is ace! fingers crossed mine lasts that long, currently only on 104k.
Could easily be MAF, temp or crank, I'm useless at problem solving but will take a look at posts where people have had issues with these and see if any match up :happy: cheers jojo.
Just to update the car started working again :think: really weird how this problem's coming and going pretty sure it will die again soon. Gave it to a mechanic who took it for a drive to see how it felt, came back saying "it goes like a rocket" pahaha was pleased but ****** off at the same time because he didn't even put it on a diagnostic. Got it booked somewhere else for tomorrow.
id say the egr
have you had it plugged into a code reader to see what error codes are stored in there ?
Hadn't at the time, although the entire reason for me going was for the mechanic to plug it in instead of taking it out and letting me know "it goes like a rocket" haha
went somewhere else today and this guy actually used vag com :o.k:
4 Faults found:
17994 - Engine Mount Solenoid Valves (N144/N145)
P1586 - 35-10 - Short to Plus - Intermittent
Mechanic didn't know what this was... pretty sure I do the engine vibrates a fair bit so one of the mounts is gone, could do with replacing but far as I know shakey engine's won't cause problems... or will it... hmm
17965 - Charge Pressure Control
P1557 - 35-10 - Positive Deviation - Intermittent
Mechanic said this is to do with the wastegate on my turbo, apparently I need a new turbo which for most people would be a horror story but to me means a good excuse for a bigger turbo haha, in all honesty though couldn't tell if it's genuinely ruined or the guy just saw dollar signs when I walked in. Surely the turbo isn't the issue... hmm
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
Mechanic didn't seem to know what this was and I told him it must be because the alarm doesn't sound... but looking again I'm fairly sure that code was to do with me putting my foot on the throttle and it cutting out, argh what the hell is causing this
16485 - Mass Air Flow Sensor (G70)
P0101 - 35-00 - Implausible Signal
No clue on this one, mechanic said something about turbo again
Readiness: 0 0 X X X
So yeah he says I need a new turbo, clutch and DMF, that's all good and I probably do but surely that has nothing to do with the problem, argh no idea with this
id say the egr
Cheers, pretty sure I need to read up more on egr's, always thought they just took air back to the engine and have no clue how they cause problems
When the car cuts out - do you get the symbol of a flashing car with a key on the dash?
Nope absolutely nothing, would think the car would tell me something :sadlike: wish it wasn't intermitent would make it allot easier to resolve.
Would the injector loom cause this issue?
I believe it is common on the 1.9's
I've had a failed MAF once that caused similar problems. Engine would tick over fine , but the moment I tried to rev it, it would die.
Worth unplugging the MAF to see if there's a change. Pretty sure Audi tdi's go into limp with the MAF unplugged, but it could isolate the issue.
10
13
4K
12
