Reesy's Big Turbo A3
Some pictures. Won't be in order as I can't be *****!
Large port with both manifolds on and ready to go.
For karlos to see what left when the head and relentless mani are off. And tuffty to see how much heat that thing causes..
New rods
Heat shielding added:
Random
Took the car to combe last week for ADI, went well although it was a shame the session was cut short. Also didn't help that the discs are completely warped and made heavy braking impossible.
Large port has made the car completely different as I mentioned before, it is laggier but definitely goes better as it climbs through the revs.
I have got hold of an N/A cam so that will go in the car during the week/next weekend and I will be doing some logging to see if it makes any difference. Not too fussed on peak numbers, but if it gets the car a bit more spritely off boost it'll be a success and be pretty easy to tell.
What engines the cam from mate? Also are you fitting just the inlet or both?
It's from an ADR but I'm pretty sure it doesn't matter which 1.8 N/A engine the cam comes from..
Only the inlet cam mate, i'm pretty sure the exhaust cam would do the car no favours.
Where did you get it from mate? Been lookig for a set for ages but cant get hold of any!
i think from the thread that got started the adr ones are the better togo for, and i think your right on the exhaust cam, would be interesting to see what the both would be like though.
Published documentation suggests a variety of profiles for N/A engines. Even the ADR engines have multiple cam specs. You should put a calipers on the one you've got -- and you should also reconsider the exhaust cam. All N/A engines shared one profile, and it's significantly better than the one used on the 1.8T.
Might be able to get hold of another one if you like?
If I remember I'll stick some calipers on it.
Surely the exhaust cams characteristics on a N/A car would be different to a turbo'd car, and if so, would the N/A cars characteristics be wanted when the car has a turbo?
Also, what is the general consensus on 76mm Throttle bodies?
Could you get hold of both inlet and exhaust? If so pm the details mate.
Im running a v6 tb which is 70mm ID i think, i had the plenum mouth ported to match and had a adaptor plate made and the car loves it, powers smoother and the engine feels revvier.
It's a possibility mate..I'll know more after the weekend.
I think it might be 70mm ID, but a 76-63mm reducer fitted on it like a dream so I'll use one of them. That's good news on how the car feels though, I have the chance to stick the larger TB on mine, so I might go ahead with it. How much did you pay for one out of interest?
Im running a 76 to 63mm reducing elbow onto a 63mm ally t piece for a custom dv relocation kit.
the TB cost about £40 and the manifold and all the work cost £40 delivered which i thought was a bargain, i also gasket matched the runners myself just for the sake of a few hours.
That's a good price. The one I have (possibly) is from a 20V V5, also 70mm ID. That is a similar setup to mine, minus the DV relocation. Should be able to get my inlet mani sorted on saturday so it all fits as it should, then I'll do some logging and see if it's made any difference. Looking like a busy Saturday!
Anyone upped their rev limit whilst running a k04? I know Big Turbo builds have (welly back in the day & tuffty now).
Is it worth it on the K04 or is the fact that they are out of puff by then the key factor in not bothering?
Depends where it is now mate :) standard is 6800 I think, most normal maps are 7200ish.
Mines currently at 7100 and it used to absolutely headbutt that limit at 300bhp.
Ill be asking Niki for 7600 or 7700 next time :)
normal k04 are done by 7krpm so no gains in power upping beyond there..
wellys hybrid pulled a lot more, and we used 7800rpm on that one
Think it's around 7k at the moment, i usually change gear about 6600 - 6800 anyway, mainly because I'm not entirely sure where the limiter is and didn't want to be pinging it off the limiter on stock rods..
Might go to 7200, then 7k changes are compulsary.
Have another map coming to me tonight, which will have more timing and boost. The large port has made the car feel a bit flat, despite pulling as well, if not better, then it did on the small port. It will be another multi map, so i can run a decent amount of timing and if the worst comes to the worst and it's super hot and I have to put 95 octane in the car, i can knock it back to sensible stage 1 or 2 power.
So whens the cams and inlet going on mate? Also have you managed to get hold of any more n/a cams mate?
Cam and throttle body should be going on to the car on Saturday. Not had chance to see about getting hold of any more N/A cams yet, i'll also know more on the weekend.
For nothing yes, ill pretty Much have anything for free, ill even take your virginity for free if you like ;)
I need to reword that. And no thanks, I never want anyone to take my anal v plates, besides, Camscockgobbler would dump you if you went with another fella...
Was a serious question though. If anyone is interested in the k04 from my A3 let me know. I have a big turbo that'll be going on when this is sold..
That a gt28? Very nice indeed mate, whens that going on?
If I've got this right, it's a 3071 core in a 2871 housing, but it's got the full frame wheels
As soon as I have a buyer for the k04 bits, i'll get the rest of the bits for this and get it sorted. Will run it on whatever it'll run on and hopefully it'll get mapped properly when I'm on holiday at the end of Nov..
Top marks mate nice one :)
Bored of the K04 already? You've got power hungry now and it will never end ;)
25
4K
50
847
