Lee what paint did you use to spray the caps? I rushed this with some high temp stuff which has now started flaking off as its not proper plastic paint.
To poliah the inlet you first need to sand it flat, as its textured. Then wet n dry to get it smooth and rubbing/polishing compound.
I had a go on mine, the amount od Sanding and rubbing needed is crazy, I gave up in the end and polished it, its shiny, but no means mirror finished. I believe s3_kev did his the same way, but his looked awesome, god knows how.
