- Joined
- Apr 6, 2017
- Messages
- 59
- Reaction score
- 37
- Points
- 18
Hi all, a friend of mine has just bought an S3. He’s looking for a VCDS user in Somerset area.
Mindak - I'm new to the forum and don't have PM functionality just yet. I'm between Swindon/Devizes can I use your VCDS service? If so please could you PM me for more infoI’m in Devizes if that’s any good?
Regards
Josh Brown
As a new member, Josh won’t receive pm. If it’s ok with Josh I can forward you an email addressHi mate, Iv sent you a message
Morning Mac, hope your well. Try user @scoTTy he is based in Essex.HI gang anyone near Braintree Essex with VCDS... MMI stopped working, anyone help out with a scan
Mac
Hi mate, it's 2012 S5 B8.5What age is the car? My Hex+can cable is getting a little out of date for the latest cars. I have a q5 coming and will get a new cable but haven't done it yet....and then this one will be up for sale
you did you same as me Unlike the steering wheel when the battery was taken off, I never thought to do it for the seats until I was under the seat with the airbag plug in my hand ah well I thought, should be fine but fully expected to have the airbag light on the dash which I got. Pulled out my OBD eleven tool first and it said it had cleared but didnt . Then tried the VCDS ( thinking the OBD eleven was not up to the job) and that also failed. which left me puzzled until I went back under the seat , pulled the plug, sprayed some contact cleaner and then did the VCDS and all was well againHi ,I now need help (hopefully just )clearing airbag light after fitting different seats
Didn’t disconnect battery as I did when I fitted my fbsw which didn’t produce a code
Nottingham area
if you promise not to cut up my seats and cover the postage costs of the reader, I can send you mine, you use my credentials to log into the app, scan your car, wipe the code, and then send it backI had that same moment of realisation under the seat ,I think I was more aware of the steering wheel bag exploding in my face was why I thought to do it then and not under the seat without an air bag staring me in the face
Ggod to know re contact spray
My lad has a vw so he might get an obd for Xmas
No worries, its only a small device OBD Eleven so would fit in a jiffy bag. speak to your contact, if no joy, the offer is thereThat would be very good of you [mention]swisstony [/mention] and I promise no seats (of yours at least ) will be harmed during our exchanges
Are we talking obd ,reckon special delivery would be the way to go for insurance purposes
I’ll see what response I get from the chap on here who did me some coding 10 mins from me ,haven’t had to use his very kindly offered service of late so not sure it’s still an option
I’ll get back to you
Turns out it was the other rear bearing had gone, that is why replacing in pairs is always advisable.Hello, new member near Thirsk close to York/Malton, looking for my codes reading on my A3 8p BKD but I can not PM users. I am happy for Sandra to forward you my email address.
I have the abs/tracs/headlightrange faults. I fixed it last year with a new front headlight range sensor but they have all come back, my recent stabs in the dark of a new rear bearing and rear range control unit have not helped. Reading other threads, water under the skuttle around the ecu or abs sensors are most likely but I thought a scan may save me time.
Thanks, Ben.
