Hi
I recently purchased a 3.0 TDI CAPA Engine
The car has some service history and it seems the traction and steering light has been an on-going issue since 2015.
When I start the car up I get ESP Fault straight away,
Anyway heres the vcds log I have
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1B-Active Steering -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAPA) Labels: 059-907-401-V1.clb
Part No SW: 8K0 907 401 F HW: 8K0 907 401
Component: 3.0TDI EDC17 H01 0004
Revision: --H01---
Coding: 010C002C180F0118
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_ECM30LTDIA5 A02004
ROD: EV_ECM30LTDIA5_A02.rod
VCID: 2E53689D71C6D6326B-807A
5 Faults Found:
4807 - EGR System
P0401 00 [101] - Insufficient Flow
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 253823 km
Date: 2022.11.03
Time: 19:57:34
Engine speed: 1736.50 /min
Normed load value: 46.7 %
Vehicle speed: 105 km/h
Coolant temperature: 89 °C
Intake air temperature: 18 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 14.200 V
Unlearning counter according OBD: 40
Engine speed: 1736.5 /min
Vehicle speed: 105.55 km/h
Charge adjuster output stage: 6.57 %
EGR valve output stage: -13.34 %
Throttle valve output stage: 5.99 %
AFS dm: 180.6 kg/h
Inj Ctl q Curr: 15.00 mg/stroke
4698 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [047] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Mileage: 253793 km
Date: 2022.10.29
Time: 13:24:02
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 90 °C
Intake air temperature: 38 °C
Voltage terminal 30: 12.260 V
Engine speed: 0.0 /min
Vehicle speed: 0.00 km/h
CCS target speed: 0.00 km/h
CCS status-Bit 0: 00101000
Cr Ctl st Shut Offirev-Bit 0: 00000000
Cr Ctl st Shut Offrev-Bit 0: 00000000
Cr Ctl st Shut Offrev-Bit 16: 00000110
Cr Ctl st Shut Offrev-Bit 24: 00000001
Cr Ctl st Shut Offrev-Bit 8: 00000000
Cr C st Key 0-Bit 0: 00000000
Cr C st Key 0-Bit 8: 00000000
4699 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [047] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Mileage: 253793 km
Date: 2022.10.29
Time: 13:24:02
4984 - Glowplug for Cylinder 1 (Q10)
P161A 00 [101] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 253794 km
Date: 2022.11.03
Time: 14:28:03
Coolant temperature: 10 °C
Intake air temperature: 12 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 11.560 V
Vehicle voltage terminal 30: 11560 mV
Coolant temperature: 10.5 °C
Preheating system status-Bit 0: 00000000
Preheating system status-Bit 8: 00000000
Glw Plg r LVS Ps: 14.99 %
Intake air temperature: 11.9 °C
4986 - Glowplug for Cylinder 3 (Q12)
P161C 00 [101] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 253794 km
Date: 2022.11.03
Time: 14:28:03
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 S HW: 8K0 907 379 S
Component: ESP8 quattro H04 0210
Revision: -------- Serial number: --------------
Coding: 1B6500
VCID: 49993B01E068910A5E-801C
2 Faults Found:
01486 - System Function Test Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 222
Mileage: 253793 km
Time Indication: 0
Date: 2022.10.29
Time: 13:24:09
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x0015
Hex Value: 0x319A
Hex Value: 0x00FF
03110 - Active Steering Control Module (J792)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 13
Reset counter: 222
Mileage: 253793 km
Time Indication: 0
Date: 2022.10.29
Time: 13:24:09
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x000D
Hex Value: 0x339A
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 AE HW: 8K0 907 064 AE
Component: BCM2 1.1 H71 0134
Revision: 00002001
Coding: 031200
VCID: 73E5B9E9D264BBDAC4-8026
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000012910021
Subsystem 2 - Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
Component: ELVAUDIB8 H35 0039
Serial number: 0208000008591016
1 Fault Found:
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 6
Mileage: 253814 km
Time Indication: 0
Date: 2022.11.03
Time: 19:35:40
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 N HW: 4E0 035 729
Component: Interfacebox H43 5170
Revision: 00000000 Serial number: 329D.087555638
Coding: 0001002
VCID: 44872A35074A4C62AD-8010
Subsystem 1 - Part No: 8T0 919 609
Component: E0380 BedienteilH08 0100
Subsystem 2 - Serial number: 00000000065069
Subsystem 3 - Serial number: 0131.03.080000000100010090ÿ
Subsystem 4 - Serial number: 010090ÿ
No fault code found.
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 N HW: 8T2 820 043 N
Component: KLIMA 3 ZONEN H05 0120
Revision: D1000000 Serial number: 0128.03.080309
Coding: 36040000
VCID: 3D715FD1A4A03DAAE2-8068
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H21 0253
Revision: 05021001 Serial number: 00000000120176
Coding: 260050914034AF311E01000300001D0D0F9D874800010141000000
VCID: 306F76E563F2C0C279-8064
Subsystem 1 - Part No SW: 8K2 955 119 HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 160308 H05 0060
Serial number: SWFBIE 0000632
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10089126
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000003103080661
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T2 035 110 C HW: 8T2 035 110 C
Component: MP3-Changer H42 0390
Revision: 00042001 Serial number: AUZ5ZBH8331836
Shop #: WSC 00000 000 00000
VCID: 2B5561898AD4A31A4C-807E
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 7
Fault Frequency: 1
Reset counter: 221
Mileage: 253794 km
Time Indication: 0
Date: 2022.10.29
Time: 16:51:10
Freeze Frame:
Text: 00000000
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 B HW: 8K0 919 475
Component: PARKHILFE 4K H06 0010
Revision: 11001001 Serial number: 75330808905744
Coding: 000003
VCID: 387F4EC58B82188231-806C
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8K0 907 364 HW: 8K0 907 364
Component: DAEMPFUNGS-SG H08 0052
Revision: 00000000 Serial number: 10030802820002
Coding: 050181
Shop #: WSC 00483 210 82588
VCID: 70EFB6E5A37280C239-8024
2 Faults Found:
00776 - Level Control System Sensor; Left Front (G78)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 221
Mileage: 253793 km
Time Indication: 0
Date: 2022.10.29
Time: 13:24:09
Freeze Frame:
03262 - Comfort Restriction
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 15
Reset counter: 222
Mileage: 253793 km
Time Indication: 0
Date: 2022.10.29
Time: 13:24:09
Freeze Frame:
Error Code: 2
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD14DAXI
Coding: 30363434363030303030554A3052384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_A02.rod
VCID: 3C7752D5B7BA34A2D5-8068
Crash sensor for side airbag: driver side:
Serial number: 6334MSME3B716774J
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME3B725476J
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME5A69340BP
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME5C014D67Q
Crash sensor for front airbag: driver side:
Serial number: 63732SME5B773413/
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME5A6339171
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H10 0012
Revision: -------- Serial number: 90304HCM000CA
Coding: 000017
VCID: 3E7358DDA9A626B2FB-806A
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 980 B HW: 8K0 920 980 B
Component: KOMBIINSTR. H15 0221
Revision: 00000000 Serial number: 7BY10U848
Coding: 2F04110032002600010000
VCID: 316973E168F8C9CA76-8064
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 K HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0092
Revision: EB302042 Serial number: 4200E083228078
Coding: 000303
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H03 0150
Serial number: 18010099200308
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 221
Mileage: 253793 km
Time Indication: 0
Date: 2022.10.29
Time: 13:25:11
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 A HW: 8K0 907 144 A
Component: DYNAMIKLENK. H05 0322
Revision: 50000003 Serial number: --------------
Coding: 0C0000
VCID: 2D516F9174C0AD2A52-8078
1 Fault Found:
01087 - Basic Setting Not Performed
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 14
Reset counter: 255
Time Indication: 0
Freeze Frame:
Count: 56
Count: 1
Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 D HW: 4E0 035 785
Component: SG ext.Player H15 0830
Revision: 00000000
Coding: 010000
VCID: 29599B814028B10ABE-807C
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 E HW: 4E0 919 887 M
Component: MNS ECE H51 1050
Revision: 00000000 Serial number: 333DV087556168
Shop #: WSC 00483 210 91463
VCID: 306F76E5A3F2C0C279-8064
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000006997371
Coding: 011C02204001410001
VCID: 3F8D25D9AEAC2FBAF0-806A
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0110746970
Coding: 013B062220393454002002
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J245 PS124 H06 0036
Subsystem 4 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J394 PS240 H08 0043
1 Fault Found:
00166 - Access/Start Authorization Switch (E415)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 253794 km
Time Indication: 0
Date: 2022.11.03
Time: 14:29:13
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 T HW: 8T0 035 223 F
Component: DSP Prem H14 0400
Revision: 00H14003 Serial number: 34814000726300
Coding: 020101
Shop #: WSC 12336 024 394758
1 Fault Found:
00422 - Rear Right DSP Midrange Speaker (R106)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 221
Mileage: 253793 km
Time Indication: 0
Date: 2022.10.29
Time: 13:38:21
Freeze Frame:
Voltage: 12.50 V
Temperature: 53.0°C
Temperature: 52.0°C
Bin. Bits: 00000100
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000006999412
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 D HW: 8K0 907 801 D
Component: EPB Audi B8 H04 0050
Revision: 00000003 Serial number: 00000000108968
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000005
Shop #: WSC 06334 000 00000
VCID: 34677AF557EAFCE21D-8060
1 Fault Found:
00471 - Control Module for Elect. Regulated Dampers (J250)
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 221
Mileage: 253793 km
Time Indication: 0
Date: 2022.10.29
Time: 13:24:16
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000006969237
Coding: 010C02204001210001
VCID: 7F0D65D9EE2CEFBAB0-802A
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8K9 827 851 HW: 8K9 827 851
Component: J605 Master H24 0220
Revision: -------- Serial number: 8K9827851
VCID: 7BF591C9FA34F39A9C-802E
Subsystem 1 - Part No SW: 8K9 827 852 HW: 8K9 827 852
Component: J756 Slave H24 0220
Serial number: 8K9827852
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000006974632
VCID: 7EF398DDE926E6B2BB-802A
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 K HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005132011
Coding: 0010920
VCID: 2A5B648D852EBA12B7-807E
End-------------------------(Elapsed Time: 03:56)--------------------------
Any ideas or anything I can look for first?
The headlights are facing the floor so I guess the level sensor has gone.
Revision: --H01---
5 Faults Found:
4807 - EGR System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 253823 km
Date: 2022.11.03
Time: 19:57:34
AFS dm: 180.6 kg/h
U1017 00 [047] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Mileage: 253793 km
Date: 2022.10.29
Time: 13:24:02
U1017 00 [047] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Mileage: 253793 km
Date: 2022.10.29
Time: 13:24:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 253794 km
Date: 2022.11.03
Time: 14:28:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 253794 km
Date: 2022.11.03
Time: 14:28:03
Coding: 1B6500
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 222
Mileage: 253793 km
Time Indication: 0
Date: 2022.10.29
Time: 13:24:09
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x0015
Hex Value: 0x319A
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 13
Reset counter: 222
Mileage: 253793 km
Time Indication: 0
Date: 2022.10.29
Time: 13:24:09
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x000D
Hex Value: 0x339A
Hex Value: 0x00FF
Revision: 00002001
Coding: 031200
1 Fault Found:
00956 - Key 2
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 6
Mileage: 253814 km
Time Indication: 0
Date: 2022.11.03
Time: 19:35:40
Coding: 0001002
Coding: 36040000
Coding: 00FD11
Coding: 025028
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 221
Mileage: 253794 km
Time Indication: 0
Date: 2022.10.29
Time: 16:51:10
Freeze Frame:
Text: 00000000
Coding: 000003
Coding: 050181
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 221
Mileage: 253793 km
Time Indication: 0
Date: 2022.10.29
Time: 13:24:09
Freeze Frame:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 15
Reset counter: 222
Mileage: 253793 km
Time Indication: 0
Date: 2022.10.29
Time: 13:24:09
Freeze Frame:
Error Code: 2
Coding: 000017
Coding: 000303
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 221
Mileage: 253793 km
Time Indication: 0
Date: 2022.10.29
Time: 13:25:11
Coding: 0C0000
1 Fault Found:
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 255
Time Indication: 0
Freeze Frame:
Count: 56
Count: 1
Revision: 00000000
Coding: 010000
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 253794 km
Time Indication: 0
Date: 2022.11.03
Time: 14:29:13
Coding: 020101
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 221
Mileage: 253793 km
Time Indication: 0
Date: 2022.10.29
Time: 13:38:21
Freeze Frame:
Voltage: 12.50 V
Temperature: 53.0°C
Temperature: 52.0°C
Bin. Bits: 00000100
Coding: 0000005
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 221
Mileage: 253793 km
Time Indication: 0
Date: 2022.10.29
Time: 13:24:16
Address 56: Radio
Cannot be reached
Coding: 0010920
