  2. Dismiss Notice
Dog bone mount insert.
Naylor92 Oct 27, 2020
  1. Naylor92
    Naylor92 Registered User
    561
    90
    Hi all,
    I’m looking to add a dog bone mount insert just to stop that transmission slop now that I’ve tuned the car. Any recommendations on the best ones to go for which offer the least vibration of course.
    Cheers.
  2. Avatar
    snack-media
    Advertisement
  3. coolbreeze
    coolbreeze Registered User
    24
    15
    I got the 034. No noticable difference from OEM, until hard acceleration when shifts are much more crisp compared to stock.
    Sent from my Pixel 3 using Tapatalk
    Naylor92 likes this.
  4. Evolution_Roy
    Evolution_Roy Member Gold Supporter
    14
    Where do you buy 034 products?
  5. T-1000
    T-1000 Registered User
    1,215
    1,168
    Apr stainless here with 034 upper insert.
  6. Sequence
    Sequence Registered User
    132
    76
    Using Powerflex one here very good, and cheap also!
  7. Naylor92
    561
    90
    Cheers for the replies and pictures chaps. Quite a varied preference then really! I’ve had a few cars with the dog bone mount on now and always gone for the yellow powerflex rubber ones but suffered mad vibration. I want to go for something different this time round, before I posted I was looking at the APR one. I want the most noticeable difference with least vibration possible really, which is obvious haha.
  8. Naylor92
    561
    90
    Notice much in the lower gears also? Less slop when moving at lower speeds? Then crisp when giving it a bit?
  9. coolbreeze
    24
    15
    No difference in lower speeds that I could tell, only in hard shifts under acceleration.
  10. Tonka332
    Tonka332 Registered User
    29
    10
    I have yellow powerflex one and mine is fine. Tiny bit in reverse but thats it
  11. Naylor92
    561
    90
    Yeah I’ve always had the yellow power flex ones on my previous cars however always suffered with the vibration at idle and very badly in reverse and that’s what I don’t want chap.
  12. Avatar
    snack-media
    Advertisement
  13. Naylor92
    561
    90
    Reckon I’d be better off going for a billet alluminium one then instead of the rubber ones?
  14. Naylor92
    561
    90
    Do you get more vibration with the stainless steel one though? Would I be better going for the 034?
  15. T-1000
    1,215
    1,168
    Never even given it a thought really.
    I fitted them 2 years ago and haven’t noticed any NVH.
  16. Naylor92
    561
    90
  17. Naylor92
    561
    90
    Okay chap cool, I need to just go for any of the Apr and 034 ones then really. Would you advise on going for both then or just stick with the lower as I’m only stage 1.
  18. T-1000
    1,215
    1,168
  19. Naylor92
    561
    90
    Okay nice one chap. Would you advise on both then and You say you have both fitted without any noticeable vibration? How easy is the top one to fit as I know the lower is a piece of **** and only takes a matter of minutes. Also, do you have a link to both items you bought please chap.
  20. trufflebutter
    trufflebutter New Member
    +1 for PowerFlex, have used them in the past (MK4 Golf era admittedly) but were compliant without too much vibration.
  21. T-1000
    1,215
    1,168
    Awesome GTi.
    Pendulum mount needs undoing to fit the upper one.
    I used new bolts on assembly as they are angle tightened after torquing.
  22. Naylor92
    561
    90
    Cheers chap, think I’m just going to go for the lower insert to start. Have done on all previous cars, albeit not quite as powerful as this car.
  23. Naylor92
    561
    90
    Anyone tried a pedal box on their cars? I’ve had them in the past and they’ve been good but would it work in sync with a stage 1 and tcu tune?
  24. T-1000
    1,215
    1,168
    Upper one stops lower one bending as per photo.
  25. Naylor92
    561
    90
  26. Tonka332
    29
    10
    No need for a pedal box, can be adjusted in vcds or obd11
  27. Naylor92
    561
    90
    Does it have the same effect though, I’m not sure it does? I have Carista, can it be done on that?
  28. Tonka332
    29
    10
    ? Find someone with VCDS they will do it.
    Sure I seen another member on here Boj27 maybe able to help
  29. DJAlix
    DJAlix VAG Car Coding™ Limited Site Sponsor Gold Supporter VCDS Map User VAG Can Professional ODIS (Offboard Diagnostic System)
    6,729
    5,154
    Pedal box can be adjusted to suit, VCDS mod is on or off. I use a TMC Motorsport pedal box, approx £100.
  30. Naylor92
    561
    90
    Yeah I thought as much too Alex. Thanks for the message though, I’ll take a look at those. I have been looking at the DTUK ones as I’ve used their previous generation ones on some of my cars and they have been very good.
  31. DJAlix
    6,729
    5,154
    All pretty much the same apart from price. I like "set and forget" so picked up a basic TMC motorsport box. It has three modes:
    • City
    • Sport
    • Off
    It defaults to city each time the car starts but I don't care about the modes, I just wanted something which made the throttle response better so I popped the cover off and turned the dial inside to where I wanted it to be, so the car starts moving as soon as the pedal is touched, and done. No messing around with modes and everything is hidden behind the dash. Instant throttle response for £100'ish = perfect.
  32. Drewsus
    Drewsus Registered User
    74
    Does anyone mind linking to what upper and lower inserts to buy please? No idea which version etc to look at.
  33. Avatar
    snack-media
    Advertisement
  34. T-1000
    1,215
    1,168
    You need to look at your rubber insert and determine if it’s version 1 or 2
    Mine was 2
  35. Naylor92
    561
    90
    If I don’t go for the ECS one which comes with a new bolt. Where can you get the new bolts from for the others?
  36. T-1000
    1,215
    1,168
    Audi parts department.
    Forum sponsors here too.
  37. Naylor92
    561
    90
    Sound chap, might be just as easy going for the ECS one. Best of both worlds with that one.
  38. Marshy
    Marshy Settled in
    1,763
    730
    I have a ecs dogbone insert that’s only done a couple of thousand miles.
    Would need a new bolt as the one with it has been used
    Fits this type of mount
  39. Naylor92
    561
    90
    How come you’re taking it off the car? How was it?
  40. Marshy
    Marshy Settled in
    1,763
    730
    I removed it when I sold the car.
    Doesn’t fit my 2019 Golf R so I opted for the Revo mount instead.
    When I had it fitted to my RS3 it really tightened up gear changes although you did get the initial kick on start up which you get with every mount/insert.
  41. Naylor92
    561
    90
    Ok fair enough chap.
    Would you say that there is no vibration then with this one? I’ve had the powerflex ones in the past as I’ve said and although they do the job, the vibration becomes unbearable at times.
    I was looking at the billet or alluminium ones in hope that they don’t cause the vibration. Then I saw this ECS one and it’s not like any other is it. Would you advise on going for it over the billet ones?
  42. Marshy
    Marshy Settled in
    1,763
    730
    From memory I paid about £60 for the ecs one, I tried the 034 before it and lasted a couple of days.
    The ecs has the bush then plate to eliminate vibration.
    Compared to the powerflex ones I’ve tried previously it is a huge improvement but for me there’s always a little extra vibration.
    I’m really fussy though.
    When I get round to listing it in classifieds I’ll be selling for £30 delivered as the bolt has been used.
  43. Naylor92
    561
    90
    Yeah cheers for the offer chap but for the sake of £30 and having to source a new bolt I might aswell just buy new. Would you definitely advise on going for this one then over the competitors? Also, to find out which type you have, do you have to remove the undertray or is there somewhere you can find out by registration or anything?
