- Joined
- Sep 4, 2003
- Messages
- 29,111
- Reaction score
- 3,854
- Points
- 113
- Location
- Solihull, Midlands
- Website
- www.audi-sport.net
Hey Bob,
Looks like we can both do each other a favour at the same time then! Sorry I've not been in contact about meeting up but I've recently split up with my gf and moved back to my parents (Hythe) so everything has been a bit up in the air.
I've got VAG-Com so if you can find out from CC what logs they need to see, we can scan your car for errors and pull together some logs for them to look at. I'm free Thursday after work if you're around? The roads around Hedge End aren't exactly the best for logging results tho as you need to do some high speed runs from around 30 to 80mph. Things are much quiter over my way so if you fancied popping over one evening then we could sort you out, and I could finally have a ride in your car!
Andy
Bob ive not been able to scan my graph across as havent got a scanner any more and havent checked my car with a full version of VAG, thinking it might be worth a trip to JBS as i live 10 minutes away.... just need to find the time, think they said they charge £50 per hour - dunno how long they'll need it though
my graph is definately choppier than that though..... also Leon i read somewhere that it depends on what type of 4wd rollers are used, apparently free rollers with no resistance are the way to go with the haldex unit
Sorry to hear about the GF situation mate its gutting when crap like that happens.
Cool so yeah if we can meet up we can do many things done at once first off we can go for a spin in my car n get it Vag'd like you say. Not sure if i can do thursday as i have an appointment to get my back looked at (i sneezed badly n threw my back out). So once i am feeling a bit less crippled we can sort it out. Plus we can do they same on your car and give both sets of results to CC
i will ask CC what logs they need etc.
should just get a revo save yourselves the hasle.
answer to your question vrbob,your car is losing boost drastically over 5000rpm also running far too rich over 5000rpm.To see whether this is a mechanical problem or a remap issue,record your requested/actual boost level and afr level with vag-com.
