Hi,
I have the below fault code showing on my '56 BKD (2.0 TDi) A3.
I've swapped the sensor (F00C2G2055) over from a known working car (I also put the 'faulty' sensor on the good car). The fault stayed with the car.
As per the VCDS wiki page I then checked all fuses, all are OK.
Last remaining thing to check is the wiring. Physically all looks OK, so just wondered if anyone knew what values I should see at the plug?
Voltage-wise there's +12V between pin D and battery negative (as per attached image), and +5V at pin B. Which seems sensible. Note there's no metal pin at point E.
Any ideas on what to check next please? Also, how do I interpret the 3 temperature readings shown in the log?
Thanks in advance!
Adam.
VCDS Log:
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 021 LG HW: 03G 906 021 AN
Component: R4 2,0L EDC G000SG 9558
Revision: --H06--- Serial number: AUX7Z0FDFN40X8
Coding: 0000072
Shop #: WSC 06314 000 00000
VCID: 6FE641B17EEC5CF1A8-803A
VINID: 9D196AAAA2202074410891C20CADF97904
1 Fault Found:
000275 - Intake Air Temp. Sensor (G42)
P0113 - 000 - Signal too High
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 280552 km
Time Indication: 0
Date: 2021.09.17
Time: 03:39:12
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Temperature: 133.2°C
Temperature: 9.5°C
Temperature: 9.9°C
Readiness: 1 1 0 0 1
VCDS Wiki info:
Thanks in advance!
Adam.
VCDS Log:
Coding: 0000072
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 280552 km
Time Indication: 0
Date: 2021.09.17
Time: 03:39:12
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Temperature: 9.5°C
Temperature: 9.9°C
VCDS Wiki info:
Possible Causes
- Fuse(s) faulty
- Wiring and/or Connector(s) from/to Intake Air Temp. Sensor (G42) faulty
- Intake Air Temp. Sensor (G42) faulty
Possible Solutions
- Check Fuse(s)
- Check Wiring and/or Connector(s) from/to Intake Air Temp. Sensor (G42)
- Check/Replace Intake Air Temp. Sensor (G42)
