Sorry, that was my fault, I gave the wrong block (I was looking at a log on my S3 chasing an issue with a map I had when I fist got it). Block 009 is requested & actual boost. Looks like your RS4 valve (assuming that's what you've got fitted?) is failing. I've seen them spike upto 200Bar on gearshifts but not during WOT like that. However I can't see this being your issue.
Also, your boost is pretty low for a Revo on boost setting 9 - usually they peak around 2.9Bar.
Here's an extract from my car using the same vcds blocks;
Code:
Group A: '003 Group B: '230 Group C: '118
Engine Speed Mass Air Flow Throttle Valve Angle Ignition Rail Pressure Rail Pressure Rail Pressure Engine Speed Intake Air Boost Pressure Boost Pressure
TIME (G28) Sensor (G70) Timing Angle TIME (specified) (actual) Difference TIME (G28) Temperature (G42) Control (N75) (actual)
STAMP /min g/s % °BTDC STAMP bar bar bar STAMP /min °C % mbar
301.37 5160 269 98 9 301.5 129.99 129.24 0.75 301.25 5000 14 61.2 2370
301.76 5520 292.64 99.6 9 301.89 129.99 135.59 -5.6 301.62 5400 15 63.9 2880
302.14 5880 309.97 99.6 9 302.28 129.99 128.93 1.06 302.02 5760 16 66.7 2860
302.53 6200 323.56 98.4 10.5 302.65 129.99 132.66 -2.67 302.4 6080 16 69 2800
302.92 6480 312.92 39.6 12 303.05 129.99 132.38 -2.39 302.8 6400 17 71 2920
303.31 6760 324.83 44.7 12.8 303.43 129.99 134.43 -4.44 303.17 6680 17 71.8 3080
303.69 6640 307.92 42.7 6 303.83 129.99 124.28 5.71 303.56 6880 18 70.2 3000
304.09 5400 259.11 40.4 9 304.21 129.99 130.71 -0.72 303.96 5320 18 63.9 3080
304.47 5520 262.42 40.4 6.8 304.6 129.99 131.06 -1.07 304.35 5480 19 64.7 3040
304.87 5640 269.42 40.8 9 305 129.99 132.28 -2.29 304.73 5600 20 65.5 3040
305.24 5800 278 40.8 9 305.38 129.99 137.45 -7.46 305.12 5760 21 66.7 3060
305.64 5840 44.58 19.2 27 305.76 115.94 134.12 -18.18 305.51 5800 21 1.6 2660
