P0299- The Infamous annoying *** code
R0n Ai
29
New York
I changed the DV, and still get the p0299. I checked the wastegate rod and it doesn’t jerk or move at all so I’m assuming it can’t be the wastegate? The turbo works fine, the car jumps when I floor the pedal. I cleaned the MAF sensor, changed the purge valve, smoke tested the PCV valve and no leaks, however there is a leak from the head gasket. Any suggestions what it could be?
Does it stutter slightly at about 16 -1800 rpm ?
Mine did, I'm pretty sure that was the code I was getting.
It was the actuator on the inlet manifold that controls flaps inside. Easy fix
Nope. The turbo seems to work. It jumps when I floor the gas pedal. I tried jerking the wastegate arm and there was no play so I’m assuming the turbo is fine. What else could it be?
Hi, how did you solve this problem? I too have the P0299 code, changed the dv and smoked tested and found no leaks. When the turbo kicks in it sounds a lot different. Maybe it needs replacing? thanks
