Hi guys, where do i start to try to fix this ?
Limp mode and error code p 0299 turbo underboost.
2.0 tdi Brd engine
Many thanks
2.0 tdi Brd engine
Many thanks
2.0 tdi Brd engine
Many thanks
Leak check the DV diaphragm.[/from
Thanks, where do i find that ?
On a 2.0 tdi is this accessible from the top of the engine ?On the turbo. A leaking diaphragm will cause underboost. Check by applying vacuum and see if it holds.
That's interesting Dave. Yes i replaced the vac unit a few years back. Can't remember the code. I might clamp the hose on the vac unit and see how it goes. Thank youmm707 - Is it you I've seen before posting about the vacuum unit on the inlet manifold and replacing that to resolve the flashing glow plug light?
I just did that fix and worked fine on mine. I the same error on my car as it went into limp mode before I did the fix.
