What have you done to your A3 (8p) this week
Painted wheel centres black. And from spoiler lip black. Not finished with it yet.
Sent from my SM-G935F using Tapatalk
Y'know the splitter cover is literally just a cover only 2 screws holding it in place on the underside, much easier to paint off the car
No I didn't mate I was laid on my back masking it up. Will take it off tomorrow and finish it off. Thanks for that
No worries, was gonna mask mine off like you did but realized when I had the bumper off to replace the grille how easy it was to remove. Probably still a little bit of laying on the floor to get the screws out though lol T20 I think they are but maybe smaller, took a lot of screws out of the car that weekend
Reactions: leonwilliams
Thing having a I'd finished and took masking tape off I'd realised that I hadn't followed the contour or the lip. Which you don't notice so I've just to redo that not tomorrow .
Fitted Mintex 1144 front pads to my Yellow Speed Racing BBK (MDB1977M1144). This is the final piece in getting my car certified for New Zealand roads.
0D983ACF 33A0 4C09 81BB EA8DF97EC149
Reactions: S. and ch1z64
Fitted H11 resistors yesterday works perfect no errors. Also my mate has vcd. Modded fogs to come on when turning corners at night. Any idea how to do needle sweep on clocks ?
Reactions: D7YAB
Front lip finished. Also anybody know where I can get this aluminium part from ?. Doing my head in now with all scratch marks on it
I have a set of s3 brushed aluminium door trims in better condition than yours. Not perfect but a lot better, without such deep scratches.. I want £100 for the set.
I won't sell one. Also, mine trims are different from yours: brushed aluminium vs dotted.
Replaced the center speaker with a pair of Audison Prima AP1 tweeters. Cover doesn't quite sit flush - need to work out what can be done.
IMG 0726
IMG 0725
Reactions: D7YAB, Shane-Ireland, samisnake and 1 other person
Wasn't the case with mine, it was moulded into the bumper.
I took the entire bumper off and masked it up before spraying.
By any chance did you take a pic of the OEM speaker before you replaced it?
No pic of it in situ - but if you want a pic of the speaker itself then just search for Audi A3 8p dashboard speaker. I still have the speaker so can photo it if you wish?
It's true for the S/S-line bumper. The SE one is moulded as one piece without any separate splitter.
Didn’t even know there were speakers there! Does it make a difference?
Yes - very noticeable. The OEM speaker produces very little sound and maybe this is deliberate as you would interfere with stereo imaging. The reality is in a car given the odd seating pattern imaging is not going to be too much of an issue (purists would disagree). Anyway I’m getting a more ‘full’ sound in the drivers seat. The Audisons are quite smooth so I’d match very carefully as anything too harsh will be exaggerated. I have Audisons in the front doors as well.
Next mod puddle lights for my wing mirrors. I need a donor mirror if anyone has one even if it's just the shell.
So I can do a test run. Happy to travel not too far and pay for a mirror. Doesn't have to be exact. But size and shape would be better.
Replaced corroded rear door triangles.
A3 8PA Door Triangle Replaced
Than run Dyno test as I didn't do it at the time of remapping the ECU a year ago. I was surprised that my small 1.6 TDI could produce 150HP and 372Nmn :) Here's a video of two first test runs.
And the graph
Remapped A3 16 TDI Dynoresult
Reactions: maccalo
The 034 Motorsport billet aluminium dogmount insert has been on for about three weeks now ... There is still some vibration once on the move 5-10mph and I did get a little in reverse tho that seems to have gone now. Let’s see in another 3 weeks.
Have done SFA to mine not even driven it for a week cause Jack got my steering wheel , chatted to mate in NZ to see how he's enjoying the driving off his S3.
Thats it Folks
Checked my timing chain tensioner wear using the method from this video:
Great video and 1° KW (I guess clockwise?) is a very happy result. One less thing to worry about.
For those with a vagcom, video summary:
Go to Engine, Block 93 Read 'inlet camshaft phase angle' under 4° good 4 - 5° risky >5° replace.
From my understanding this measures the long term correction added to the cam phase. More correction = more wear.
Also fixed the seatbelt warning whilst I had the vagcom linked :)
Reactions: Shady0808, ch1z64 and Daveyonthemove
- Mot
- Racingline intake
- Miltek sportcat & downpipe
- Service
- Cam follower service
- TTS engine cover
Now skint and eating toast & beans for the rest of the month
- Mot
- Racingline intake
- Service
- TTS engine cover
Now lets see the pics , beans n toast ones :thumbs up:
Reactions: maxpayne
Retrofitted High Beam Assist to my S3 8P using an Audi TT dimming interior mirror with forward facing camera.
20180902 161204
20180902 161252
Reactions: Dave-v-v, ch1z64, mechanic69 and 2 others
Dropped her off to the local garage for cam belt, water pump and fuel filter cos I can’t be ***** with the hassle of doing it myself.
Just the rear BCS to arrive and be fitted before booking into RTech for a tune, happy days
Reactions: samuelh_888
You can’t leave us hanging there, any details on the retrofit part nos, guide, etc???
Can this be used for active cruise control??
Nice mod
HAHA Sorry,
The kit I purchased consisted of an Audi TT interior mirror with the forward facing cmos sensor and a wiring harness. Unfortunately you cannot use it for adaptive cruise. Here is the kit I bought as its hard to find a mirror at a decent price. The mirror in this kit is also brand new and a genuine part.
https://www.ebay.co.uk/itm/AUDI-A3-...h=item3d3e78da21:g:TvUAAOSw9RdbDjjJ:rk:1:pf:0
The kit came with new wiring harness with a new 8 pin connector to the new mirror. All you have to do is wire the CAN + and the CAN - into the CAN Gateway. As for the other end at the mirror you use the new 8 pin connector and swap your other 4 wires to it from your old 6 pin connector. Code in using VCDS and job done.
I will be doing a full write up soon and including all pictures and video in the retrofit section. This was just short and sweet for you.
HAHA Sorry,
Thanks for the heads up, look forward to more info. Looks like you need the auto dimming/rain sensor stuff fitted before to work, mine never hand that but all the other upgrades, never really worked that out
checked mine today and at -3.0
Done test run with 8p mirror for puddle light. Hardest part was figuring out how to run wire but sussed it.
Next job fitting reckon full day to do will post pics when done.
Reactions: Dave-v-v and samisnake
