Ok so from the beginning. I bought a 132k on the clock 2001 s3 about 6 weeks ago with a cracked manifold. New manifold was fitted a long with headgasket, cambelt, water pump and a full set of gaskets for the turbo and exhaust etc. I also fitted new vacuum hoses. Mods to the car are a full PCV valve delete, n249 delete, SFS oversized TIP, 3" DP, Forge recirc valve, upgraded catback and S2000 filter.
Now the car has had a stage 1 map fitted and only produced 230hp and 260lbft on the dyno and was accompanied by thick black smoke. I did notice a kinked hose from my simplified PCV setup which has since been rectified.
So symptoms are black smoke, low power and an unsteady idle. The PCV hoses have all been tidied up and anything unnecessary has been removed as per the guide. Currently venting to atmosphere.
Doing diagnostic work I realised the following:
Rear o2 sensor has been unplugged and removed completely by PO.
Considering this is the hottest day of the year, I noticed that the IAT didnt go below 50C no matter how I drove it.
I did a log and noticed up to 10 degrees of timing retardation among all 4 cylinders under WOT pull in 3rd
Mass airflow sensor only showing 170g/s at redline and 4.5g/s at idle.
Removing the MAF sensor plug the car runs exactly the same. Plugging it back in whilst idling shows no change at all.
o2 sensor ageing degradation (dynamic factor) was 0.002 when it is supposed to be between 0.5 and 2.0
Boost achieves target and seems to hold there
Smoke has appeared to have cleared up now, on last few pulls I noticed no smoke at all.
Turbo has slight up down play in shaft, approx 1mm
Compression test with throttle closed (forgot to press accelerator) dry was 145, 120, 150, 145 with a very cheapy am tech tester. Waiting for my decent one to come before repeating.
Emissions do smell very much like petrol (possibly because of decat?)
Completely unrelated but the brakes are very spongey
Any ideas?? I'm really pulling my hair out. Car seems to be making boost but not the power from what it appears to be timing pull.
