hey there tuffty. was hoping you would pop up on this tread with some useful advice as I have seen your name popping up all over these forums will great advice and knowledge.
no no don't worry that intercooler is well and truely gone everything that I don't need has basically been sold on so the money has helped with getting other bits for the build.
I do have to bam pistons and rod assemblies that still need a loving home if anyone is interested.
so yeah will carry on with this thread.
after inspection of the damage to my amk block and head ect I decided to get rid and start a fresh. I brought a low milage 225 BAM engine with 50000 miles on it for just shy of a grand with basically everything bolted on as standard. (this is where the bam pistons come from not the knackered amk block) and work began stripping down the new engine and getting the block off to the machine shop. as pictured. everything withing the engine is being replaced weather it needs to or not for this power but doing it more for piece of mind as want a relatively reliable build.
the spec I have gone for for the engine build is as follows.
oversized 81.43mm wossner pistons with a bore size of 81.50 allowing for the 0.07mm bore to piston clearance
forged zrp H-beam light weight connecting rods
all acl main and rod bearings
all arp. (head..main..rod..crank gear ect)
brand new oil pump and pickup + chain and tensioner
both new seals on crank
new sump (unsure weather to buy a baffle plate)
I/E press fit crank gear kit as suppositivly better than pegging.
I/E manual timing kit which includes the following..
billet idler roller kit
billet spacer
timing belt tensioner roller
mechanical tensioner hardware kit
metal water pump
gates racing kevlar belt
every sensor is being replaced with new
performance head gasket (not sure what yet)
need to get a good clutch (unsure)
have the head currently being worked on to replace all parts with supertech to support higher revving. (valves, springs ect)
the head will still remain small port with standard manifold.
be running 630cc injectors after breaking in on standard injectors with boost set at minimum.
will be looking at getting cams after break in but unsure as to what route to take yet.
unsure if oil cooler will need upgrading to radiator type but will deal with that later on down the line.
obviously all new gaskets and seal and thermostat for coolant.
I pretty much have all the parts I need other than the oil seal on the crank gear side but will have to source than unless anyone can help out.
I have also purchased a gt3071r turbo kit from CTS turbo where the guys there were a great help with questions I had. it is currently in transit from America and will hopefully be here in the coming weeks so will get pics up of those parts when I have them. the turbo kit I am buying will come with the following parts.
gt3071r turbocharger ( will look to run in the 24-26psi range)
630 high impedance injectors
Walbro GSL 392 Inline fuel pump
high flow fuel filter
cts 1" diverter valve
CTS 1.8T T3 Turbo Manifold
Thermal coated turbine housing
Thermal coated exhaust manifold
3" Stainless Steel O2 Housing with integrated wastegate recirculation (external dump)
3" Stainless steel downpipe with rear Vband section
3" Stainless steel rear catalytic converter eliminator section
Stainless Steel Turbo Heat Shield
Thermal wrap for upper downpipe
3" Inlet Pipe Kit w/ silicon and Advanced Flow Engineering (AFE) Re-useable Air Filter
Stainless steel compressor outlet pipe (to connect to factory dual SMIC piping)
Stainless steel oil feed line kit
Oil drain line kit and required fittings
Coolant line relocation kit for oil cooled T3T4 turbos
Precision 39mm External Wastegate
All Gaskets, Studs, Nuts, Clamps for installation
I'm sure I have missed parts out that I have but will add if I can remember.
so as I stand at the moment I should be getting the block back from the machine shop this week so can get on with prep work for a respray (red to my taste) and just really waiting for parts to arrive from the states so I can crack on with getting this engine back together. will put pictures up I have on my phone but will take more when parts arrive. Cheers everyone for reading and like I said if any one can give advice and info on anything related whether I know or not it will all be appreciated.
just to add all engine mounts will be uprated as don't want stripping to occur again and all silicone hoses will be new along with high flow radiator and a good decent intercooler for this set up to suit.
