Small update on the engine front, been waiting an age for a parcel to be delivered so I could get on with the build and it arrived today
Once I had my piston ring sleeve I set about building up the bottom end. i fitted my crank and torqued up to spec and when I span it I could hear a rubbing noise coming from the trigger wheel, i narrowed it down to the trigger wheel bolts I welded up and found they were catching on some small nubs in the block. So it was off with the crank again
and the I got the dremmel out to smooth over the welds,clean down the crank to get rid of grinding dust, re-install torqued up it span freely
Next i fitted the pistons using the piston sleeve, lovely bit of kit( probably abit self indulgent when i bought it works a treat) torqued to 55ftlbs and released 3 times then re torqued.
[/IMG]
Next i fitted the front main seal, was a bit of a pain in the **** as i had no tapered adapter to aid sliding the seal on so i improvised and used the neck off a tall slim bottle worked a treat slid over and then bolted it down complete with the sealant, i used the sleeve for the rear main but didn't get any shots as i only had a helper for 5 mins to remove it from the stand then back up.
[/URL]
also managed to get some stainless steel pipe from my work that was surplus to requirements, will be a while before i get round to mocking that up tho as i don't plan to fit the engine until late spring as its all going to done in my street lol
Still have to torque up my crank pulley then i can close up the bottom end with my sump, buy new knock sensors and crank sensor and fit the oil filter housing etc then its turbo purchase time once i actually decide on one.....
