Well it's been a little while again since update so expect this to be quite picture heavy. Annoying because this forum has updated it's policy with regards to the size of pictures that can be uploaded so lower quality pictures I'm afraid.
I started to get on with the intercooler piping marking up lengths and where I'm going to put the inserts into the hard pipe. It's about the time I was starting to realise how little space you have when everything starts to go back in..
I don't have any pictures on the fabrication of the pipework but you will see in following pictures how it looked.
I got a heat shield for the turbo to try and further keep down engine bay Temps and has been fitted as shown
On the inlet to the turbo as many before have found with cts kits is the heater matrix pipes get in the way.. I got around this by using some spare hose and just extending around inlet as can been seen and joined using 19mm barbed joiners. Bit fiddly but done the job in end.
I then finished off the coolant return and carbon cannister piping using some braided 8mm ptfe pipe using some nice little keepers on the end to make it look nice.
I also simplified the breather set up for the catch tank.
The done the servo vaccume and temp put fuel rail on
I got all the intercooler and oil cooler mounted up properly next. Rather please with how it all sat in the end
Next picture shows the intercooler pipe all fabricated and in position. Can also make out the relocated fuel filter and pipework.
Rather tidy if I do say so.
Tucked up from the day
Next thing I wanted to do was get all the gauges sorted inside.. now I know alot of people don't like pillar pods but personal preference and each to there own. Really helped being an electrician doing all the wiring.
****** mess tbh.
Looked alright in the end. Also got the inline pump relay sorted ect but not pictured
You can see the green sensor wire I brought through the firewall in the next pic
Quite hard to make out the next pic pics but it's of the new inline fuel pump in the place of the original fuel filter. Was like it was made to fit. Also installation of fuel swirl in boot. All piped in 8mm reinforced ptfe pipe. It was tidied up considerably before back seats were put back in to make sure no chance of damage to the pipes as would be a disaster waiting to happen.
That's all for now. I have don't the battery to boot conversion but will show that in next upload.
Again all constructive criticism is appreciated. Still need advice on the original oil cooler coolant pipes as asked on last post if tuffty can pitch in. Cheers
