the last two letters stipulate which model they are.
BF like yours is standard xenon suitable for RHD UK roads.
But they are for 2008 onwards models not 2006. So you would need full front end in order to fit them.
Adapters can be bought from eBay or kufatec but I avoid kufatec as there is always problems with them.
I like yo re-pin a new headlight plug rather than use adapters looks more OEM.
As long as your new xenons end in BF they will work fine once fitted and coded.
The car has been face liftedThe headlights your trying to fit are for 2008 onwards with that part number supplied. Not a direct fit into your car as it's different model. Unless your car already has the facelift done?
I have a set of bixenon 06-08 adaptive headlights for sale, do you want a supply/fit solution?
Ah just saw the facelifted remark
Thats fine pal, thank you for the help!With your car been 2006 model it will have the F module which accepts coding for the LED xenons. No DRL switch is needed unless you wanna turn them off? All you need is adapters or re-pin your current headlight plug and then coding via VCDS job done.
