The cameraman needs to buy an iPhone 6!
I thought the S3 was going to spank it as well......And I thought the video was gonna be good?!
Trust me it would have! Only is the RS3 didn't have the TTE500 bad boy fittedI thought the S3 was going to spank it as well......
Emphasis on Smoke......My diesel would smoke them both haha
My point exactly!Emphasis on Smoke......
Experienced Allys car personally and the things a beast... There was a better video than that floating about tho Si..
For what they are tho, theres not much in it..
Really?
yes they're really fast cars 11.6 quater mile with tte 450 upgrade.
Impressive. I wonder how the engine copes with the bigger blower, must be under alot more pressure.
The block is very tough.
Head also flows very well without any work,and even with a turbo like mine(a modified GTX3582),the engine copes very well indeed,so there would be no likely issues with either of Simon's turbos.
Good to hear from an experienced tuner like yourself Alex. So the clutch is the only weak point then?
I have a friend with a stage 2+ Golf ED30 and after giving it big licks it will spit oil into the exhaust (minimal), he was advised it was because the engine is under so much pressure with the high tune.
Is the S3 block more robust than the 230 engine in the golf?
ED30 got the same engine as S3
Red has answered the block question,but if the car is smoking on the overrun,it's more likely to be the turbo oil seals are about done.
It uses a little oil and smokes when it's been pushed a lot. Otherwise fine
Does sound a bit like oil seals.
Mine runs a lot more boost than a Stg2+ car,and doesn't smoke(or at least not now that I've got rid of the RS4 injectors!)
