Would it come with 350m weekly for NHS too?Problem is HVAC has about 30+ channels all of which have start button at the bottom.
Great shame they dont just fit a brexit button which liberates the car, makes everything work and engages a life time warranty on all parts.![]()
If you have heated seats the 8U0820043G is fine. I think there is an earlier version than the G (with heated seats) that also works.
If you have heated seats you can’t change the internals.
Sand the sides. You also need to take the back off your old CC and swap it onto the new CC. Fit then run Adaptation and seat heating temperatures (both via VCDS)
Yeah goto 08 HVAC then 04 Basic settings, then click on/off and wait until it says Adaption OK, that did it for me.
the fault code never goes but doesn't cause trouble.
There is only 1 code I got on both units I have fitted.
00457 - Control Module for Network (J519)
004 - No Signal/Communication
For the adaption left to right go here
Cheers @mechanic69 - when I go into 04-Basic Settings I don’t get any On/Off.
It only appears after I select Go! beside Group 001. I need to give Group 000 a try as @paddy suggested. Beyond that I’m not sure what Group to select.
Nevertheless it’s working brilliantly - the support, as always, is much appreciated.
Awesome work @samuelh_888 gives me inspiration to do mine. Did you sand it just 2/3mm then? I might be messaging you for advice when i do mine!
Your in the wrong screen, that is just to see what the groups are reading you can’t change the settings there, these are measuring blocks on the left of each module screen.
You need to go the module selection screen/menu, there you select HVAC 08. Then each module screen has basic functions on the left like the screen you show at Meas Blocks 08.
On the right side of each module menu is advanced functions, there you got to Basic Settings 04 to run the adaption
Yip, about 3mm off each side. I taped the unit up and left the edges free but unfortunately I didn't take a before photo.
Thanks @mechanic69 - I'm not sure where I'm going wrong. I just want to the car to have another go - I'm accessing Basic Settings - 04 under the Advanced Functions (on the right) - I've added a couple of screen shots below. Only after I select Go! beside Group 001 do I get ADP OK and the ON/OFF/Next button. I'm not sure why it say's my Basic Settings are OFF.
Img1: From Control Module page, 08 - Auto HVAC
Img2. Basic Settings - 04
Img 3: I'm not sure if Group 001 is correct but if I select Go! I get ADP OK. It only takes 6.5 sec to calibrate.
If I go into Measuring Blocks - 08 I see a very similar screen to above except it has more groups on the page.
It all seems to be running well and the memory is on the drivers seat so I'm pretty happy with it as it is - just not sure if I'm being thick on finding the right settings!
your nearly there press the on/off/next button at top and wait till it says adaptation ok again. the only change you will notice is that you can control the passenger temp from the drivers side
if you then go to measuring blocks GRP20 you should see this when you hover the mouse over the numbers, the last three should change from 000 to 100
yeah group 001 to run the adaption and group 020 to check its worked. if your still having trouble ill check mine again this weekend, good luck
Thanks mechanic, i now have driver side operation
I notice in your sig you have a BCS Downpipe + CAT ? Is that mated to the std exhaust ?
I plan to do this but i just wondered if there were any problems with the restrictive silencers or smaller rear pipe sections.
Yip - If I hold the Auto button down for several seconds then I can control both sides together. If the passenger dares touch their side then it resets...
Hi @paddy.
It seems to be working well but I believe it’s the adaption step needed for learning.
From my 3rd image, I’m not sure what channel to run the adaption against. I did run it against 01 but maybe @mechanic69 or @Arkious could confirm! Until I run 01 I don’t get an ON/OFF. Just not sure what the correct Group to run against is.
I am however getting one error but it’s expected based on previous posts: 00457 - Control Module for Network (J519)
i guess theres no fix yet for that, right? my OCD is driving me nuts with it, i guess you're all the same.
is it something you get used to it?
Does the RS3 not have a better CC in it than the Q3Never tried looking for one as it makes no difference to its function, just a little error code.
On the newer 8V yeah, but the 8P is just the same as the A3. I put the RS Q3 one into my RS3 which is slightly different again
As it’s the only error code I have, I know it’s self inflicted so my OCD can deal with it at the moment!
