Mowbray89
- Joined
- Sep 15, 2013
- Messages
- 13
- Reaction score
- 2
- Points
- 3
Thanks for the heads up on this! I've just been out and tried this on my car and the sound is definitely different! What would you recommend as the best levels to use on the bass & treble? Not sure if it will just take time to get used to the difference but I'm struggling to get the levels just right to where I am happy, so any advice will be much appreciated.
One thing I have found when removing the pin from my retrofitted RNS-e naturally it shows a coding error when scanning with VCDS as its still configured for Bose so bear this in mind. Not sure if going in to adaptation and removing the Bose setting will 1. rectify this coding error and 2. give you the option to be able to adjust not only the bass and the treble options but also the mid range, GALA etc too. (Can't remember as its been a while!). Has anyone else re-coded theirs after removing the Bose wire?
Again any help will be much appreciated.
Cheers.
Cheers.
