Probably better to ask here:Got a cheeky question but just wondered if there is anyone around the Notts area with VCDS as wouldn't mind a few bits doing.
To do this you need to recode the Light Rain and Humidity Sensor it seems. Am trying to work out how to do it as I type this. It's a Dec to Hex value translation but the major issue is that even with Beta 15.3 nothing in the LRHS is labeled for the moment lolmy biggest WANT is altering the sensitivity of the auto lights, did it quite easy on the 8P
This would be great! As much as I love the automatic lights they come on far too early, even on the late settingmy biggest WANT is altering the sensitivity of the auto lights, did it quite easy on the 8P
Surely you can never have your headlights coming on too early. Too late Yes, but too early!This would be great! As much as I love the automatic lights they come on far too early, even on the late setting
STG 09
- Stop the dimming of the DRL LED beams when you turn on your indicator light (always full brightness)
Access code 31347
Adaptation
(18)-Leuchte2SL VLB10-Dimmwert GH 2
Default: 30%. Set to: 100%.
(18)-Leuchte3SL VRB21-Dimmwert GH 3
______________________________________________________________________________________________________________
STG 09
- Stop the dimming of the DRL LED beams when your xenon bulbs are lit (always full brightness) These are the same as sidelights.
Access code 31347
Adaptation
(6)-Leuchte2SL VLB10-Dimmwert AB 2
Default: 30%. Set to 55%
(6)-Leuchte3SL VRB21-Dimmwert AB 3
_______________________________________________________________________________________________________________
They are all the same, you just have to try different letters like CD, AB, or GH...
- Full brightness for the DRL LED beams when you turn on your left or right parking light
In this case it may be CD, and if you see the Leuchte part has numbers like 30, its the dimming %.
In my case I also have 100% LDR while coming/leaving home and I don't know the parking lights but they are also bright like the 60% I said earlier.
Its just a matter of trying inside the ones that have value 30%.
PD: Its very important that you dont set the Leuchte AB ones to 100% as you may blind drivers but I'm sure you will test and see it for yourself.
If you get error with the value 0 try turning off the function of dimming it
I don't remember it by memory but when you're select the leuchte thing there is one that's like leuchte... Lichtfunktion G? Maybe
So go to the one that links the G letter to the function of dimming the lights with indicators and turn it off
Anyway I think your mixing stuff as my coding up there is for when you turn your indications
I see. Then try
Adaptation
(16)-Leuchte2SL VLB10-Lichtfunktion G 2
Default: Blinken linksaktiv (beide Phasen)
Set to: 100%.
(19)-Leuchte2SL VLB10-Dimming Direction GH 2
Default: ??? Set to:maximize.
(16)-Leuchte3SL VRB21-Lichtfunktion G 3
Default: Blinken rechts aktiv (beide Phasen)
Set to: 100%.
(19)-Leuchte3SL VRB21-Dimming Direction GH 3
Tell me if theres any luck finding this adaptation options in your car.
Try going even lower than light configuration as its way below that zone
Anyways in Europe the % is 30 and has a cool dimming effect so the indications can be seen better, just to let you knowThanks ChiYoung for all your help! You were right the Leuchte channels are towards the bottom and not in alphabetical order with the other adaptation channels.
I used:
Adaptation
Set to: 100%.
Set to: 100%.
For these two: I set it to "minimize" so that when I turn on the headlights, it would stay at the natural dimmer setting at "100%" and not actually get brighter.
Now it looks perfect. THANKS!
Does anyone have a list of mods and coding for the 8p. A local guy is asking me to do a few things for him.
Been running with this mod for approx 4 weeks in London, with a few police cars behind me, and have not been pulled up on it...... yetNot legal on road (if you are bothered)
Still loving this.
I can't find if you posted how to do this but can you please elaborate on how you did this?
Thank you
Nope. If you complete the mod then your left / right and hazard indicators will function like this also.That only affects the lights when you lock/unlock the car right? It doesn't affect anything during normal driving?
My Coming Home and Leaving Home functions were open from factory.
I did some changes unintentionally and now when you lock doors at night:
DRL and Xenon and Fog Light illuminates for about 20-30 seconds
Back LED Lights illuminates for about 60 seconds.
Normally, they close at the same time.
What can I do to reverse this change?
