8V VCDS Mods
Audi connect services server needs your MMI details, MAC address etc, to be registered before connect will fully work. Connect cannot be retrofitted so to speak as the registration takes place during a vehicles build process.
Hi DJ
So even though I can get all the menus up there is no way to access it as many are greyed out
What about google maps for the navigation. Can I get my phone to connect to the cars modem to enable the overlay of mapping?
On a side note, somehow, I must have accidentally touched something or, as you have noted elsewhere doing one thing can change something totally unrelated. My hatch no longer wants to open with the remote or by the handle. The strangest thing is that when I drive away after I manage to close it, it unlocks itself all the time and when I go to lock the car and close the hatch lid, it keeps opening itself and I have to leave the keys away from the car, close it and it will not open. Any idea what to check, or can you send me your spreadsheet to check against for that area
Appreciate your help
Hi DJ
Google maps is supplied via Audis network so is also not gonna work without the needed registrations. Everything to do with Navigation and Connect on the MMI4G and 4G+ is SWaP (software as a product) and licensed. The MMI3G and 3G+ is so much easier to mod, and the firmware is available for "user" updates which plays a part in feature activation.
Will have a look in to your boot / trunk issue and see if I can suggest anything.
Reactions: Jay.Ing
Hi DJ
Sorry I forgot to state it but my car is a 2015 S3 so I thought it was potentially possible to do opposed to the new cars.
As you said the new cars have to be registered etc upfront, but not the 8V.
Sorry for not mentioning this, so does that mean we can potentially do something
Hi DJ
All 8V's, facelift and pre facelift, use the MMI4G and 4G+ systems. V1 (pre late 2016) and v2 (late 2016 onwards) and they all share the same licensing and activation procedures unfortunatly. It's not the car thats registered its the unit, and a unit only gets registered once it's installed into a car during the cars build phase on the production line. One of the last steps is to "code" the car, and this is when the units info is registered with the Audi server, ready and waiting then for the new owner to finish off the registration process via myAudi etc. We may be able to activate and code all the needed options and menu etc but until an authorised Audi employee adds the mmi units MAC address etc to the Audi server it's never going to work.
is it all possible to do this with the 3G+, here in aus the 2015 PFL's did not have a sim slot, but they had every other option, go figure . .
It is indeed possible but MMI3G and 3G+ Systems are Audi A1, A4, A5, A6 (pre late 2016), A7 and Q5 and Q7 cars only. The Audi A3 8V has only ever used the MMI4G and 4G+ systems.
edit: Q3 = MMI3G / + also, so basically should have said all Audis bar the A3 8V lol
Can the MMI MAC address coding (to add to Audi's server) be performed with ODIS tool?
Hi DJAlix, can the connect icon be made visible on the MY15 S3 (as abarth695) did above using VCDS ?
Making some coding changes on my FL S3 with ODBEleven and as I was browsing through the adaptations for the engine, I noticed there is a setting for Engine Run In Oil Pressure. My car is new (624Kms) and was enabled. I would be interested to know if anyone who has the tool and is past run in can check their setting. I'm wondering if there is an automatic trigger after 1500kms to change this setting automatically.
Any chance you could post up your alarm information from an Autoscan please? Would like to see if you have the same system as mine.
Here's mine:
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000037212838
Same component as @Jay.Ing which suggests its a hardware difference that is causing the volume issues.
Reactions: Jay.Ing and DJAlix
Has anyone looked into the Electromechanical Brake further?
Mine seems to auto-disengage abruptly when setting off from lights etc. Also won't allow me to disengage manually unless I apply footbrake and I'm sure there's a setting to disable the footbrake requirement (assuming its similar to B8 etc).
Reactions: Jay.Ing
There is, its in the ABS module, but im still looking for the security code for the module!
Hi guys nice to meet you here, just upgraded from Golf 6R to S3 8V Stronic, I am trying to do some adjustment with VCDS and I have some questions.
I have a HEX+CAN from Ross, 12.12. I used to download the latest version, but when I try to enter I got interface error.
Then I uninstalled and downloaded the VCDS 12.12 and now it works.
I was able to activate the OIL temp on menu, but I was not able to do the exhaust valve mod, when I enter the Long Coding under Engine menu I got an error saying that I need to do autoscan and send to Ross for further verify. Maybe you can also help, thanks in advance!
My Autoscan:
Saturday,11,March,2017,17:21:20:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ8V3EA200287 License Plate: EW
Mileage: 81538 Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 42 44 52 55 5F A5
A9
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CJXC) Labels: None
Part No SW: 8V0 906 259 HW: 06K 907 425 A
Component: 2.0l R4 TFSI H09 0006
Revision: --H09---
Coding: 0A1D00322466010B3004
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TFS0218V0906259 001008
ROD: EV_ECM20TFS_AU37.rod
VCID: FDFB61B46C0F2FF67F5-80A8
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4517
Revision: 06253104 Serial number: TFK01510150318
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1F47FB3C06431DE68D9-804A
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 AB HW: 5Q0 907 379 H
Component: ESC H31 0557
Revision: 00000000 Serial number: 6109400000035C
Coding: 32F16BA254202A6C0379070841CA694CD62A54C0E08296F7F84150F88608
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 7CFDECB0F715A6FEC8B-8029
Address 05: Acc/Start Auth. (J518) Labels: None
Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
Component: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0334286293
Coding: 030C0C
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB.rod
VCID: 3A712AA8BDA158CE9A7-806F
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000319540
Coding: 03000014000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 336F078C9ACBA986591-8066
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011413200126
Coding: 04151D46C24106FD03844004B31C07A80800000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_AU37.rod
VCID: 7BFFEFACF21BA1C6C11-802E
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119
Component: WWS370 140427 042 0580
Serial number: 140429183616
Coding: 0A47F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Serial number: 22626620
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 G HW: 8V0 941 531 G
Component: E1 - LDS MQB H05 0032
Serial number: 06 01 2014 00000335
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY140913M9E
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000029691797
Subsystem 6 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO28910767
Coding: 901F00
3 Faults Found:
204546 - Remote Key 2
B147A 18 [009] - Current Too Low
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 181
Mileage: 80945 km
Date: 2017.02.25
Time: 09:01:23
721416 - Switch for Sunroof
B13C4 29 [008] - Signal Implausible
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 232
Mileage: 81457 km
Date: 2017.03.10
Time: 11:49:16
721420 - Switch for Sunroof
B13C4 01 [008] - Electrical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 232
Mileage: 81457 km
Date: 2017.03.10
Time: 11:49:16
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 G HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0133
Revision: -------- Serial number: 39331412302503
Coding: 0070050051
ASAM Dataset: EV_EPHVA18AU3700000 002019
ROD: EV_EPHVA18AU3700000_AU37.rod
VCID: 3F875BBCA6837DE6AD9-806A
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-567.clb
Part No SW: 5Q0 907 567 H HW: 5Q0 907 567 H
Component: ACC3 H10 0096
Serial number: 03051476110548
Coding: 003E1701FE0309
ASAM Dataset: EV_ACCBoschMQB 001023
ROD: EV_ACCBoschMQB_AU37.rod
VCID: 40855840DB7D021ED43-8015
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8V0 907 376 C HW: 8V0 907 376 B
Component: DAEMPFUNGS-SG H08 0066
Serial number: 140314015
ASAM Dataset: EV_AudiMagneRide 002003
ROD: EV_AudiMagneRide.rod
VCID: 41835D44D0770B16DBD-8014
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 M HW: 5Q0 959 655 M
Component: AirbagVW20 011 0361
Serial number: 003M1R04YCJ-
Coding: 98FCC0000C0000005C540000004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 4A917A68ED41C84E0A7-801F
Seat belt tensioner; left:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H35 0341
Serial number: 34120583B12051450006
Coding: 333135
Seat belt tensioner; right:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H35 0341
Serial number: 34120584B12051450206
Coding: 333135
Crash sensor for side airbag; driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 000 705 14
Component: SideSensor_Df 001 0887
Serial number: 35767000000320596F0P
Coding: 2D2D2D
Crash sensor for side airbag; passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 000 705 14
Component: SideSensor_Pf 001 0887
Serial number: 35867000000500596F0Q
Coding: 2D2D2D
Crash sensor for side airbag; rear driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 400 805 14
Component: SideSensor_Dr 001 6149
Serial number: 3516502C7156E9F0F1CX
Coding: 2D2D2D
Crash sensor for side airbag; rear passenger side:
Subsystem 6 - Part No SW: ----------- HW: 480 400 805 14
Component: SideSensor_Pr 001 6149
Serial number: 352650299156E9F5D1F$
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 7 - Part No SW: ----------- HW: 480 401 404 14
Component: FrontSensor_D 001 6149
Serial number: 3556502A5157E9D2728N
Coding: 2D2D2D
Pedestrian protection crash sensor; driver side:
Subsystem 8 - Part No SW: ----------- HW: 480 402 404 14
Component: PedP_Sensor_D 001 6149
Serial number: 2286502AD157E9D2B29Z
Coding: 2D2D2D
Pedestrian protection crash sensor; passenger side:
Subsystem 9 - Part No SW: ----------- HW: 480 402 404 14
Component: PedP_Sensor_P 001 6149
Serial number: 2296502AB157E9D1A29W
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 10 - Part No SW: ----------- HW: 480 402 504 14
Component: PedP_Sensor_C 001 6149
Serial number: 2306502B7157E9D2E2EV
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 DR HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 30041408490223
Coding: EC18
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB.rod
VCID: 8D1B31745CAF1F766F5-80D8
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 870 N HW: 8V0 920 870 N
Component: KOMBI H03 2220
Coding: 078D081A7F8400080481EA00100000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: 46894E58F9592C2EEEF-8013
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001974938
Coding: 030100042F085A005B00027C9C0B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_AU37.rod
Generator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 15 04 2014 F0002112
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 3663123303
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000109863002
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 346D04909FC5AEBE40B-8061
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 25041403112144
Coding: 005D1E205C00048000001003
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
Address 44: Steering Assist (J500) Labels: None
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 9103
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB.rod
VCID: 356B399494BFB7B6775-8060
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 24041401101190
Coding: 005D16205E00048000001003
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
Address 55: Xenon Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 B HW: 7P6 907 357 B
Component: AFS-ECU H01 0040
Revision: -------- Serial number: --------------
Coding: 01A200002B230200
ASAM Dataset: EV_HeadlRegulLEDAFSMQB 001001
ROD: EV_HeadlRegulLEDAFSMQB.rod
VCID: 3E7926B8A18974EEA6F-806B
Subsystem 1 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F
Component: LED LeiMo li. H07 7530
Coding: E00100
Subsystem 2 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F
Component: LED LeiMo re. H07 7530
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo links H01 7000
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo rechts H01 7000
Coding: E00100
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8V0 035 043 C HW: 8V0 035 043
Component: MU-H-N-EU H42 0281
Serial number: A303E0E7520952
Coding: 017303010000000021110002000A00032F000225010001009E
ASAM Dataset: EV_MUHig6C3HBAS 001040
ROD: EV_MUHig6C3HBAS_AU37.rod
VCID: 306508806BDD929E243-8065
Engine Control Module 2:
Subsystem 1 - Part No SW: V03 959 800 QA HW: -----------
Component: ECE 2016 --- 0134
Serial number: --------------------
Seat Adjustment Driver Side:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0013
Serial number: AUZ8Z9EY200ZES
Sound System:
Subsystem 3 - Part No SW: 8V0 919 614 S HW: 8V0 919 614 E
Component: ControlUnit_H H64 0766
Serial number: C1000028031400010242
Door Electronics Rear Left:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 1008
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 F HW: 5Q0 980 653
Component: MQB_MFK H05 0052
Serial number: 10000074437
Coding: 0101010001010303000500000100000100
ASAM Dataset: EV_MFKBoschAU370 001001
ROD: EV_MFKBoschAU370.rod
VCID: 3B7F2FACB29B61C6811-806E
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 140429201530
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
End ---------------------------------------------------------------------
My Autoscan:
A9
Revision: --H09---
Coding: 0014
Coding: 030C0C
Coding: 0A47F7
Coding: 00006C
Coding: 901F00
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 181
Mileage: 80945 km
Date: 2017.02.25
Time: 09:01:23
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 232
Mileage: 81457 km
Date: 2017.03.10
Time: 11:49:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 232
Mileage: 81457 km
Date: 2017.03.10
Time: 11:49:16
Coding: 0070050051
Coding: 333135
Coding: 333135
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: EC18
Generator:
Coding: 9103
Coding: E00100
Coding: E00100
Coding: E00100
Coding: E00100
Sound System:
What you need to do is uninstall your current v12.12 version. Once complete, make sure that the USB drivers have been removed, go out and buy a genuine cable!
Reactions: Jay.Ing and dpaz
But actually my cable is genuine!
And as I mentioned is not completely unable to work, electronics was OK ...Engine not.
Should I just upgrade to latest now that USB drivers are OK?
If your cable is genuine then why are you running a software version that is from January 2014? You need to update as v12.x does not fully support the 8V so 80% of mods cannot be made. You need at least v15. Version 17 is the current.
EDIT: Just seen your images, 100% FAKE.
Reactions: T-800 and Rob2k68
DJAlix I don't know why you are replying me so "rude" . Let me explain a bit, maybe I was too rush.
I bought a used Golf R in Dec 2016, and the previous owner give me a bunch of accessories, also the VAG Cable. At that time I don't even know what VAG is but I know some about PC i am a bit nerd so I kept it when I sold the car last week to upgrade to S3. I never used VCDS on Golf, no need. I decide to try VCDS on S3 last Friday, i downloaded the latest 17 version, i connected to my car but I got interface error. I don't remember where but I found some user saying that the problem was solved using the 12.12 version software (same as cable) and infact i managed to make it work, but only in some function.
So this is the story, if I read ross-tech on a cable and it works how can i assume it's a fake cable ( and how do you recognize)?
So sorry if I don't explain myself not very well but please don't judge me as a scammer I am totally new to this world
Some people, just can't be helped.
It's a fake cable. The text on the sticker doesnt look genuine and did you not think it was a bit of a coincidence that the 12.12 numbers on the back happen to be the only software version that works.
Throw it in the bin and buy a genuine.
Reactions: GSB
Rude?! Try posting your autoscan on Facebook and see how much abuse you will get lol
Not being rude fella, nothing personal at all, you need help I will be the first to supply it... time permitting. Fact is you have a fake cable and I do not support or have time for fakes full stop. I have advised that you need v15 of above to complete most of the mods on an 8V. My straight the point answers are to prompt you to stop using a $12 monkey cable on a £10k plus car!
While there are success stories with fake cables I have seen first hand the damage some can do and problems they can cause.
Re the changes you would like to make, some are possible by said "monkey" cable but most will need v15 and above. You can get both v15 and v17 fakes but please don't buy them. A used "real" cable will cost around £180 onwards and a new one £280 onwards.
Reactions: Rob2k68, T-800 and GSB
I got your point but for the future please try to analyze the situation first. I am not guilty at all and I do have 180$ still in my pocket lol
Inviato dal mio SM-G925F utilizzando Tapatalk
Am sorry but there is not much for anyone to understand here let alone myself, and I DO NOT have to analyse anything. I took the time to read your post, saw the evidence you posted and pointed out you have a fake. My time was then given to / spent helping someone else...simple.
Am trying not to be rude, honestly, but understand that fake cables are the bane of many "professionals" lives due to the loss of income. More so they can also cause huge problems to the people who use them, as a $12 eBay / aliexpress cable can end up costing £1000's in repairs. Also the use and support of fake items is not allowed via this forum, even if the user is aware or not!
Look... at the end of the day you were given a fake cable and you tried to use it. Fine, not your fault... UNDERSTOOD. What is your fault is that you tried to use it without researching in order to find out what you were given, and if it was SAFE to use. This is not a fake Rolex or Tag Heuer which might just make you late for work, this is a cheap item with crappy componants that could potentially cost you money or hurt you and or your loved ones! I am being short because honestly you are lucky that you did not burn out your ODB port or Gateway. Actually that would be fine with me as I could be paid to fix them :) I have seen windscreen wipers and climate control systems blown due to the use of fake cables. I have seen a Driving Instructor, a professional, loose money and customers while his car was off the road due to his cars safety systems being disabled via a fake cable his so called "friend" used.
This fake cable which you were "given" could activate a lap timer "eye-candy" Bull S%$* menu for you to show-off to your friends or it could turn your car in to a weapon which you cannot control and hurt mine.
Hows that for an analysis? Your Welcome.
Reactions: -Ju-, TMB, pastey and 2 others
DJAlix, I do appreciate anyone spend time on a board to explain something to other people, I do it myself in my business and it's the base of the evolution of self learning , so I have no clue about what are you trying to address me .
I just got a bit shocked because I feel "attacked" for something that I really (still) don't know how can I discover by myself.
You said my fault is I used it without spending time to research what I was given? Ok, how do you judge that?
If I review what I did I don't think I did anything stupid.
I searched on Ross Tech website and I saw my version is no longer available , so I googled HEX+CAN USB and I was redirect to this page http://www.ross-tech.com/vag-com/old-interfaces/huc.php and it looks what I got on hand ( probably you can discover differences on the spot, but can you imagine me, I don't even know that there is a fake market on this business ) I see Ross Tech on the cable....
Furthermore when I connected the cable with the 12.12 software version, the TEST result told me that the found Inteface is exactly Ross Tech HEX+CAN USB .
Seriously, I know you are trying to educate other users , but please understand I am not a kid want to play with death, when I do this kind of things I do it studying a lot, I spent several years on forums trying to learn so I am a bit disappointed I am pointed out as a dangerous person can lead to someone else death. You are not fair saying this to me , that's it. There is way and way to reply and educate rookies , and you choose the most dramatic one . Maybe you hit your goal and you will still represent the GOD of VAG on this board , but I just let you know that everything I did , I did it in good faith ( don't know if this sentence has the same meaning in italian, means I really couldn't know I was doing something wrong )
Anyway, I find this kind of board chat always constructive, I still learned something important today.
But the thing is driving me crazy is this one:
When you say that using a fake cable can lead to death, do you mean that if I use a fake cable the program can do something by itslef on the system? Just magic? Disable my ABS or Airbag while I just activated OIL on display? This is something really serious you should reply and make it sticky , and those cable suppliers all need to go to jail.
If what you mean instead is that people using VAG without knowing what they are doing then it's another story.
But now I am incredibly curious about that....
Thanks for understanding ( I hope )
Rob.
Has anyone figured out how/what's needed to make the engine data displays in the virtual cockpit function correctly? I was able to add the very easily with ODBeleven, but as other have reported it only shows 0% when off throttle or 100% with the slightest touch (or more )..
You need another module that is only present in the RS3 model. If you can figure out which module it is and where it goes, you will be able to make it work properly.
Reactions: Jay.Ing and Rob2k68
Is this a software module, or are you talking hardware? I would expect the ECU knows exactly how much torque and power is being produced, so it's probably a software thing, maybe there is a calibration required
Hardware, an additional module.
Sent from my SM-N910V using Tapatalk
Alix, Have you had time to look at the FL wink differences yet?
Also does any on know the naming convention/Functions of the Lichtfunktion B, Lichtfunktion C, Lichtfunktion D etc?
For example is Lichtfunktion B = With Side Lights on
Lichtfunktion C = With Doors Open
Any insight appreciated:grimacing:
Not sure if it is a VCDS mod or not but does anyone know how to get the DIS to show when the car is using 2 cylinders or 4 cylinders? I followed instructions to enable the display from a thread on another forum but mine was supposedly already set to display yet I can't find it on any menu. Is is this possible?
Hi DJ
Hi DJ
Sorry to be a pest but did you get a chance to find out why my tailgate hatch keeps unlock caking itself when I drive away
It also keeps opening itself when I lock the car and have to leave the keys on the front windscreen, close the hatch and then walk away and it's fine
Even if you can send me a log from a standard car and I can compare settings
Thanks mate
It only displays when you select the "On-Board Computer", and not the speedometer or any other menu.
Indeed! Just got done with making up a new cable for VCP so I can hit the floor running :) Been a while since I had the soldering iron out.
I can see myself getting some workshop time in order to complete the detail. Not a bad thing actually as I can have the car on power at the same time in order to dump all the data from the control modules.
DJAlix where did you buy your ODB IP connector from? I am Looking and getting VCP and im interested going the IP route.
Reactions: rcnacura
Made it myself. DoIP does not work on MQB cars btw, new A4/5 and Q5/7 only.
Reactions: Jay.Ing
Oh :disrelieved:
Would you recomend the VAG CAN Profesional dongle then?
OR
The new HEX V2 from VCDS?
VCP is everything VCDS is plus more however VCDS is better documented, supported and labelled. If you are planing on working with FL MQB and MLBevo platform cars forget VCDS as no version of it fully supports the "good stuff". Suggest doing some bedtime reading on both as it would take a good few hours to cover the features of both applications.
If leaning towards VCP be warned... its lacking documentation and allows access to dealer level, actually I mean engineering and development level, coding and as such a large portion of the application is a "black art". Things can go south pretty fast if one is not sure about what they are doing.
EDIT:
Have been taking a few days out from the forum but am thinking to do a VCDS vs VCP video as I have some time free tomorrow. Have not forgotten about all the requests I have / am getting via pm, they will be answered, but making a little video will actually clear a good number of them out of my queue and free up some time :)
Reactions: BodegaBay, umm, Jay.Ing and 1 other person
Is there a particular section within the on board computer as I've cycled through them and can't see it?
