2.0 TDI remap recommendations
phatAvant
Hi Everyone,
I would like to get my 2.0 TDI (143) remapped, its a 2011 model, so not sure how it all works as I think some can't be done directly.
Anyone on here done it, was it worth it, which gains did you get?
Cheers.
Hello !
The ECU is the engine control unit which is a small box which controls the engine underneath a pannel under the bonnet,
As the car is a new model like mine the ECU (engine control unit) has a tri core locked ECU to prevent remapping.. but still can be remppaed, they will take the ECU out of the car, the ECU is bolted in by bolts which the heads pop off when they are fully screwed in so they have to pattern a screwdriver pattern on the bolts locking the ecu in and unscrew and unlock the ECU via there computer and insert it back into the car again, and put new bolts back into it again so Audi can not tell that it has been fiddled with rarely they look at the ECU anyway. then they remap it by the old fashioned way ( under the steering wheel) they take out the engine data and send it revo and revo will send it back with different performance which will be uploaded to your car, as the ECU has to come off your car to be unlocked to remap there is abit of extra work and time to do so be expected to pay abit more than a normal remap price.
I would recommend a revo remap as they are one of the best and well known for vag cars and you will have 100% peace at mind, you will expect to get a few mpg more aswell depending on how you drive it.
with a revo remap you should be look at about 181 bhp and 290 lbs/ft torque (392 nm)
visit
Revo |o find a local revo dealer near you, all the garages on the map are authorised to do the job right
There are more remapped cars than you actually think and it will not harm your car, the bhp and torque are still well with in its limits of engine components so nothing will go wrong you will get slightly more wear to some engine components but not much but as you would do anyway if you drive fast often, it will also put abit extra wear onto your tyres, it will remove all flat spots and much more power in all of the gears and any rev range it will totally transform the car, there is a large improvement as you look at a 143 bhp like yours which does 0-60 in 9.4 and you look at one exactly the same but a 170 bhp does 0-60 in 8.3 but the revo puts it up to 180 so there is abit more to go on top of that and when you also add the extra torque on top that will help much better aswell,
personally i own a 2011 audi a4 2.0 tfsi quattro 211 bhp which i have had a revo remap and all is good so far, everybody thinks that the remap is worth it and i have never heard any bad reviews about a revo remap personally i think it is your best bet.
If you have any questions please feel free to ask and let me know how you go on if you get it remapped or not
Thanks very much :)
Mine's a 2008 143 and just got it remapped last week. The performance increase is brilliant,upto 175-180 bhp and torque up from 235 to 290. Its not just the acceleration it pulls a lot better from low revs and 3rd gear is superb. Mine was done by cheshire autotech over xmas period for £200 and he came out to my house aswell. The car should leave the factory with this power. Ive only just got car and as my last car was a 220bhp 2.0T going to a 143 tdi was disapointing but this has put a huge smile on my face. Mpg not decreased either,maybe better? If yours is a 2011 i think your ecu has to be removed as audi lock them so will probs cost you more but i would still defo recommend getting it done.
Will a remap void a warranty? I guess the car will be capable but what about the clutch? I had a b6 remapped then 5 month later the clutch started slipping!! 😭
Cheers for the replies, I knew how it works on the 2.0T but wasnt sure if the 2.0 TDI had the same lock thingy on the ECU.
Im interested by the Revo, but being in Spain it's not the easiest.
well some people say it does some people say it doesn't, but i suppose it wont void your warranty on say for example parking sensors or a radio but anything to do with an engine component and Audi prove that the remap has caused the problem then it will void you warranty then unless Audi has proved the problem has been caused by the remap that is when they will void your warranty
Yep i am pretty sure it is locked, all vag cars from 2009 onwards have been locked up, but tuners have found a way around this :p
my 2009 2.0 tdi 170 ppd wasnt locked.Colin from cnlremapping did mine.well impressed.Got a 30bhp gaine and more torque.Could have had a bit more if it wasnt for the wretched dpf
Reactions: BigGreg
celtic tuning, yep heard of them very good ! and have got a big name for them self !
Had no probs(touch wood) upto now and have had it done for just over a month. Would defo recommend it to anyone. It pulls a lot more than it used to. Take the plunge and get it done. Ive heard of celtic tuning as i got quote off them but it was about £350 maybe a little more? So I went with cheshire autotech as they quoted me £250 but i bartered them down. Blair who done the job was knowledgeable and a decent fella.
Looking to Re-map my 2008 Audi A4 2.0TDi 143 and was hoping for some advice.
2 work colleagues (1 has 04 Vauxhall Astra, and 1 has 07 BMW 520D) have re-mapped their cars with Motech in Earl's Barton, and both recommend the EcoMap. Motech advise this increases performance by approx 40BHP + Torque, and will slightly increase MPG depending on driving style. I have a laid back driving style as a rule, but like to put my toe down every now and again.
Any help / advice would be appreciated!
Duff gen there my man. The majority of TDI ECU's from 59 plate are locked and you can get some 09 plate that are and are not. 2.0T, 2.0TFSi and S3's are unlocked from factory BUT there are other marques within VAG that do not follow this such as Skoda so the best bet is to get the serial number of the ECU and get it checked 1st before committing to the remap.
Thanks, How come this thread has re appeared from ages ago ?
ECU's can be locked retrospectively that weren't locked on production. We can unlock them to allow OBD tuning, but still needs to come out first.
Rick
Reactions: Paul @ Unit 9 Remaps
Apologies, I've posted a new thread half way through another.
Has anybody remapped a 2008 08 A4 2.0TDi SE 143, or know of anybody that has? And If so, what are the results?
Rick, thanks for the response.
Is there any reason why you'd not want to keep the DPF? 175BHP is also what the garage have estimated my new power output to be.
What concerns me the most is putting extra wear on engine and mechanical parts. I expect slight more wear on tyres and things like that, but what about the turbo etc?
DPF's suffer from reliability issues and a remap, depending on how it is carried out, can reduce the life of them further. Your engine is however much more tolerant than the earlier PD engines. The nature of the DPF as an exhaust blockage means greater pumping losses and therefore reduced power/economy.
The rest of the engine will be fine, don't worry about that :)
Rick
I know this is an old thread but I am wondering what the remapped 143tdi engine drives like after it's been mapped as a friend has had his done and the torque curve seems all wrong it just wheel spins on setting off its difficult to drive its like the power delivery is all at once instead of being smooth like the unmapped engine is???
The remap will vary depending on who did the tuning, there is an awful lot of rubbish out there, unless you are going to the likes of AMD you run the risk of getting a rubbish file on your car. Do not think that a big name means you get a good file for your car, I used a local company who really knew their stuff, how much to add, what maps to change and by how much, not like the larger companies that just reuse files and only change a few of the maps in the ecu, the difference was massive, my car was very smooth even when driven slowly, I got an extra 10 mpg on the motorway and loads more power and it did not cost what the large well known companies where charging, I have had lots of cars remapped and have used different companies in the past, eventually I stuck with AMD as their work was miles better than any other company, the local company I used last time was just as good as AMD remaps I have had in the past and was 1/2 the price.
Can anyone recommend where I can get a remap on a 2008 Audi A4 2.0tdi can? I live in the Guildford area.
Can anyone recommend a remap specialist for 2.0 tdi a4 with 136bhp or does anyone have a tdi tuning box on there car
Looking to remap my 2.0 TDI 2012 A4 177ps after the warranty has ended.
Located in London (West).
Checked the Revo site and it shows I would get an increase of up to 35bhp; seems quite small compared to other companies I've checked.
Can I get a recommended stage 1 map from leeds area, cheers
A3 2010 2.0 tdi 140
Rick is very helpful and may even be able to provide a remap via your android phone (if you have one)
Has anyone had a a3 2.0 tdi Quattro 2014 remapped??
Just wanna know how it affects the auto box etc??
The box is plenty strong enough to handle a engine remap, maybe you should also get a gearbox remap at the same time, that will speed changes up hugely!
If you have a CVT auto just be grateful it can take stock power :)
Having said that I did tune my cousins 2.0CR with CVT and held power ok with around 430nm
Very true, with massive transmission losses and change lag, the newer stuff is much better by far!
