what happened to your engine mate? pat is it?
Text you bud, only thing to consider is the secondary air injection on the APY, the AGU head doesnt have the hole in the head for the EGR portbut you can remove it no probs at all. Ive removed that system a few times with no problems. Most people remove as part of course anyways because its bulky and can fail.
Fair play! So your taking the engine out in your garden?
*Edit to Higher compression pistons.Looking to get a front mount intercooler this weekend to fit while i have my front end off. What size whould you all recommend that i get? I have been looking at smallish ones: Core Dimensions - 550mm x 165mm x 65mm. It says its good for 600bhp... Do you think that will be ok with the spec i have or should i go for something bigger?
Spec:
Golf AGU 1.8t engine (Lower compression pistons and more of a ported head over the S3 engine)
Stage 2 remap (Will more than likely get a new map once new engine and cooler are fitted)
K&N cone filter
Sports cat
Full through Milltek
N75H valve (gives me 22psi of boost)
N249 valve bypassed
Secondary air pump removed
K04 turbo
All of the above should see me good for 285bhp+
jesus christ thats awesome!
so what was the level of tune of your car again? any figures?
