How is the result with 3" dpf delete as this is something I wanted to do on mine for sometime now.
Also waiting for your write up regarding bitdi tune you were doing?
Sent from my ONEPLUS A6013 using Tapatalk
If the dpf is working well and you have little back pressure then 3" delete pipe doesn't offer more performance on the 3.0TDI.
At best a bit more torque and the ability to stay on WOT for longer before egt correction takes place.
BiTDI work - Yes I've done it and have data but awaiting a power run to confirm figures.
According to logs should be 400hp or maybe even slightly more (stock car with dpf).
I did change a sensor as it was close to the limit.
Bobby
