Strut Brace
Mine's fitted...
Dude got it yesterday will be fitting it tonight.
nice one
Chris
Tried fitting it last night but the brake fluid resovior was in the way, very tight fit too.
did you guys just move the bar behind it?? dont want to damage the resovoir at all if avoidable.
Chris
There seems to be a special way of fitting these, i know that when i've fitted them it has taken a bit longer then expected and been a bit more fiddley but they have went on in the end without causing any problems.
I finally got time to fit mine but had it fouling the brake resovoir and ecu cover .
Ive also got a feeling it may not let the bonnet close properly but as i couldnt get it bolted right down i maybe wrong.
I removed the washers but i was still putting alot of pressure on the brake resovoir. The flat metal corner plate is rubbing the ecu cover also.
Cant see any other way to put it!
Well it's the end of the month and I need to know how people are getting on with the fitting or do I hold fire as there seems to be some issues?
10
5K
17
