  2. Dismiss Notice
stripped bolt in head!
ruffrida Nov 10, 2014
  1. ruffrida
    ruffrida Registered User
    1,934
    317
    Well after thinkin i had fixed my diesel leak, today I got very strong smell again.
    Checked the bolt under the vac pump (just below the fuel pipe) ,which was not tight, went to tighten it and round it went. Ffs!!!
    Out come the tap set, ran a 6mm up it, which was baggy as a granny, wobbled it's may all the way in, so now the dilemma is;
    1- Get a imperial tap set and bolt
    2- Take the head of, drill ot out to a 7mm
    I'm hoping to go with 1 but open to your thoughts.
  2. Avatar
    snack-media
    Advertisement
  3. NHN
    31,823
    2,347
    Can you get a dremel in there to make the sides flatter to get a socket or some fixing on to unscrew, I've done this before with success.
  4. ruffrida
    1,934
    317
    Bolt is out. But when you put another 1 in after running a tap down it. The bolt won't get tight, well does then spins!
  5. NHN
    31,823
    2,347
    Ah sorry my mistake, so the tap is the wrong size, so just get a bolt to suit the tap used or change tap set & get bolt to suit, whichever route should be fine, taking care of bolt used is able to handle any heat etc as some are much harder than others.
  6. vr6gordy
    vr6gordy Registered User
    2,822
    193
    How about drill out the threads that remain then helicoil it
  7. ruffrida
    1,934
    317
    Noway will you get a drill in the space between the engine and bulk head.
    That's why the head would have to come of, imperial tap it is!!!
  8. WOLF
    WOLF Registered User
    1,233
    296
    what size imperial tap do you need?i have some but would have to check tomorrow.If I have the correct size you need your welcome to it
    ruffrida likes this.
  9. vr6gordy
    2,822
    193
    image.jpg You can get a little bit the lets you drill on a 45 ( I saw it on wheeler dealers)
  10. ruffrida
    1,934
    317
    Wolf the top man as always, 1/4 = 6.5mm ish, which I am hoping is goin sort it. But may go 7mm, need try the 1/4 first.
    WOLF likes this.
  11. ruffrida
    1,934
    317
    Lol u have also seen that. But the other problem is you can't see the angle right for a drill
  12. Avatar
    snack-media
    Advertisement
  13. vr6gordy
    2,822
    193
    get a bolt and cut the head of it then jb weld the stud in place then put a nut on it
  14. Rrobson
    Rrobson Registered User
    37
    Go for 1/4 bsf, has a tpi of 26 where as m6 would equate to 25.4 tpi so very similar. If the thread is badly pulled you may even be able to screw 1/4 in without tapping however if you tap it it will make a cleaner thread
  15. ruffrida
    1,934
    317
    That did come to mind today
  16. vr6gordy
    2,822
    193
    Thinking on I wouldnt drill it you might do more harm then good
  17. WOLF
    1,233
    296
    Ok,have you the patience to wait till tomorrow or am I to go outside,move 2 cars,reverse my van out of garage and have a look now..........
  18. WOLF
    1,233
    296
    Ive had a look and I have these,the markings don't really a lot to me but may be self explantary.......I don't know.
    m5 x 8m/m goliath gh3
    m 6x1 goliath
    m5 dormer e500
    im guessing these aren't what you want but welcome to them regardless.
  19. ruffrida
    1,934
    317
    Nice 1 for the trek @WOLF but no there no good. Goin get a full set tomoz. If it stops raining lol
    WOLF likes this.
  20. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,313
    214
    Ring around bolt companies and ask if they do a oversized self tapping screw.
  21. WOLF
    1,233
    296
    Hope you sort it mate:thumbs up:
  22. ruffrida
    1,934
    317
    Got me self a tap&die set today. But it's only been weather for ducks in wigan today, hoping for better weather tomorrow, let ya know
  23. WOLF
    1,233
    296
    Ya not made of sugar are ya...:whistle2::cold:
    Fingers crossed for a sunny day for you:yes:
  24. ruffrida
    1,934
    317
    This us where u am at now, imperial tap was no good. So goin leave me super steel to set for 24hrs with a bolt in and then try it
  25. ruffrida
    1,934
    317
    Right that didn't f***in work!!
    How has experience with help coils?
    As i cant drill it out i am thinking of using a m5 (if the is such a thing) or m4 but never used these before so a little lost!!
  26. vr6gordy
    2,822
    193
    Did you mix it right as the weather is a bit damp maybe you should have put more hardener in it also you have to have no sign of oil and grease for this stuff to key to the metal
  27. ruffrida
    1,934
    317
    Yep did all this, and still no good, helicoil kit on route, so fingers crossed
  28. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,467
    200
    Take the head off!
  29. vr6gordy
    2,822
    193
    If you can afford it have the head rebuilt if you take it off .. More power and better mpg
  30. WOLF
    1,233
    296
    :salute:How you getting on with this ruff
  31. ruffrida
    1,934
    317
    Helicoil came yesterday, which looks massive foe a m6, just got to find the time to play now
  32. mattyb6
    mattyb6 Registered User
    977
    75
    I have a oil leak/ smell of diesel
    I'm sure my tandem pump needs tightening up and/or new gasket
    When it's been raining the ground is covered in oily water
  33. Avatar
    snack-media
    Advertisement
  34. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User
    7,298
    3,636
    The metal plate gaskets can't be re used they don't reseal. Get a new gasket they are only around £5 and replace the gasket.
    Karl.
  35. ruffrida
    1,934
    317
    Eventually got some time to have a tinker today. Justin case I got a M5 & M6 helicoil kit.
    Went with the M5 first as the M6 tap looks massive. The 5 tap went in really well but I can't get the helicoil to stay in, every time I wind the bolt in, the helicoil winds out, proper did me ed in.
    So at the moment I have put another M5 helicoil in with plenty of lock tight on, try again tomorrow and see if it holds.
  36. Jimmy TDI
    Jimmy TDI Pro Tinkerer
    1,320
    263
    Turning into a right carry on this mate.
    If it's screwed I have the head from my ASZ pd 130 Bora in my garage that you can have foc if it will be of any help for parts.
  37. ruffrida
    1,934
    317
    Nice 1 @Jimmy TDI bur i think I have sorted it.
    Took over an hour to re-tap the hole, as the was such a difference between the M5&6 but it has tighten up lovely. The test will be when I go pick the mrs up in a bit. Fingers crossed but i think it's all good. Thank fck!!!
  38. ruffrida
    1,934
    317
    Job done happy days, back to spending money on her properly now. Mods mods mods lol
    WOLF likes this.
  39. WOLF
    1,233
    296
    Well done ruff:applaus::applaus::applaus:
  40. Mike.M
    Mike.M Registered User
    2,510
    172
    Sounds like it was a lot of fun and hope we never have the same.......touching wood!
    WOLF likes this.
