Can anyone who has the factory installed Rns-e mk head unit in there car please post a pic off the quad lock in the back as I think I am missing some blocks cheers
Cheers mate I now know I am missing the A Block and wonder if there is a way I can get it fitted if I need it. I originally had a Audi Symphony 6 cd model in and I have checked the back off it and it has pins for A-B-C-D blocks , wondered if the A block is neededThis might help till someone else replies https://www.audi-sport.net/xf/threa...the-factory-fit-bluetooth-box-isnt-it.388297/
Cheers mate for the picture , I am missing the A block not sure if I need tho as I get music out the Bose speakers but I have moved the pin from 5 to 7 but still getting the coding pin error and can't seem to get it shifted , any advice or can you tell me the colour off wire pleaseI used this pic for my RNSE install
Coded in the best I could but still always got the coding pin error , now I only need to get the colour off wire which would be in #6 in block C that way I can look at the wiring and solder a repair wire to it .Did you code it in with VCDS?
Yip I understand the diagram but my plight is I can't mind the colour off the wire that I moved from C ( blue block #5) to its new position as I had a jumble off wires coming from all over the placeOK I upgraded my symphony to RNSE on my old 3.2 and had to buy this quadlock harness. The wiring dia is on the RNSE unit. I do remember i had to move a pin in one of the blocks for Bose i think. There was a thread on here at the time that detailed it all but would have been about 10 years ago now. If you get stuck ask Nige "NMM" because he was around at the time and is the elec guru.
