  2. Dismiss Notice
Not another Nogaro!!!
IPG Jun 16, 2016
  1. <tuffty/>
    <tuffty/> Badger 5 Edition...Its all about the flow... Staff Member Moderator
    24,336
    5,592
    Filling mounts with resin can make them quite 'stiff' I believe and overly so... you would have to ask people that have done it but I would personally use VT mounts...
    Bill did have an R32 with a HPA kit fitted in many moons ago... that had the rather solid poly bush style mounts on it and the knock sensors were having a funny 5 minutes with them...
  2. Avatar
    snack-media
    Advertisement
  3. Tj 0785
    Tj 0785 Registered User Bronze Supporter Silver Supporter VCDS Map User
    3,828
    1,167
    cheers tuffty Il stick with the vibra tronics expensive at around £500 but not wan to go through the hassle of resin and then have to change them anyway
    Ian you can have your thread back now
    IPG likes this.
  4. IPG
    IPG Registered User
    1,841
    778
    Changing over the power steering pump required the pulley to be removed first before you’re able to get to the mounting bolts.
    With all the ancillaries bolted on it’s almost time to lay the loom back over
    The tightness of A/C pulley clearance once again
    Went to tension up serpentine belt when ...
  5. IPG
    IPG Registered User
    1,841
    778
    This is correct. You need the mounts ON THE ENGINE from the vr6 (I’m using the 2.8 mounts).
    * You can re use the s3 chassis to mount part (the one with the rubber) *
    So I’ve filled both sides with resin and they’re stiff but I think I’m used to it now. People who’ve not been in my car before can tell but it’s all peachy for me. Ride quality isn’t bad at all.
  6. IPG
    IPG Registered User
    1,841
    778
    Loom mostly plugged back in. Just have two plugs that physically can’t be plugged in unless the inlet manifold and intake pipe is installed.
    Had a bit of a battle with the clutch slave bleeder blowing off I so wasted a bit of time having to remove the starter then pushing it from behind to be able to re attach the bleeder properly.
    Next - to go ahead and torque up all bolts that were removed.
  7. IPG
    IPG Registered User
    1,841
    778
    Now that all the driveshaft, gearbox and mount bolts are torqued up it’s time for some smaller jobs
    A7458E9A-5F23-4F04-B348-F24AFB7BFDC7.jpeg 49B06417-3F16-42E5-8041-CA7B97B86772.jpeg
    Changed the plug for the oil pressure sensor with a cut and solder
    Put in some fresh gearbox oil because I had an incident aka forgot to drain it before removing the transfer case
    ... and in goes break in oil!
    S3AMJ, hydro s3 and warren9022 like this.
  8. IPG
    IPG Registered User
    1,841
    778
    Had to figure out a way to mount the aftermarket FPR.
    But ended up going with the option to use the in built FPR they use in the next model up. Pictured is the oem fuel filter where the mk5/tt8j fuel filter goes. It has
    - fuel in
    - fuel to rail
    - 4.bar pressure regular to return line
    Part # WK69/2 (4bar) or equivalent
    All I had to do was make up a return hose with come quick connects - just used some bits from the wreckers.
    Cam cover wrinkle painted in black - much easier to care for!
    Most of the car was back together so decided to upload 3.2 software and start up!! ... or not start up... car didn’t run :(
    Slept on it and remembered that
    I grounded one of the wires to a throttle body bolt = not connected to ground. Oops!
    Once that was sorted I got the engine fired up! ... codes ensued!
    AB58262A-F9DE-48EF-802A-87DBA67EC958.jpeg E7D7AE98-F469-4466-894E-EE84FA7E2E5C.jpeg
    These two were strange however.
    This was strange - given its summer and
    Was 30 degrees C that day!!! When starting up the car the measured value went further into negative until - - was displayed ... hmm.
    So I looked toward wiring.
    Upon changing back to the mk4 MAF these issues disappeared. Lesson?
    Don’t use a 3.6 MAF!
    I thought I was ready to put it back together but after running till engine up to temp I got this
    Then while finding the issue leaking hose I found injector #6 was leaking. So...
    Front off again to fix the issue. Getting to the rail =
    - disconnect coilpack plugs
    - remove packs
    - remove all vacuum lines and intake piping
    - removing mounting bolts
    - Front down as in the pic
    - then you can get to the manifold front bolts
    Hassle!!!
    But we got there
    Sam_, superkarl, warren9022 and 2 others like this.
  9. IPG
    IPG Registered User
    1,841
    778
    Out and about
    ... but previous to this - radiator hose blew off! Hahaha
    Lucky for Uber that was able to ferry us to a servo where they had coolant.
    76km’s break-in done!
    hydro s3 likes this.
  10. S3AMJ
    S3AMJ OEM+
    2,091
    727
    Ian.... you never cease to amaze me! Good work, always a quick turn around with you.
  11. Tj 0785
    3,828
    1,167
    That’s true he’s rebuilt his 3 times before I even started mine ha
    so I’d I wouldn’t be able to use a vibratronics mount there then or would I need to mix a 1.8t and a v6 one ?
    S3AMJ likes this.
  12. Avatar
    snack-media
    Advertisement
  13. <tuffty/>
    24,336
    5,592
    IPG likes this.
  14. IPG
    IPG Registered User
    1,841
    778
    Thanks Ash. Was trying to get it done before Friday to take on a b-day track day. Not sure if it’ll be broken in enough though :(
    Haha it helps now I know my way around the thing pretty well. Engine leveller on crane - key equipment!!!
    Re: VT mounts - you will be able to use the gearbox side mounts, but you will need a VR6 specific ones for the engine side.
    Snuck this one on before work. Was considering driving it to work and back but too much idling traffic made me choose otherwise.
    Oil and filter change tonight for 2nd lot of running in.
    hydro s3 and Dohcwp like this.
  15. IPG
    IPG Registered User
    1,841
    778
    @<tuffty/> wow those mounts are expensive! (but probably well worth it)
    This is the first oil change on the engine - it feels nice and strong both acceleration and when coasting and letting the engine do the braking
    The state of the oil drain plug! hahaha oops
    Lucky I was able to just take the cap from the dead 3.6 and pop it on. 300km's on this 2nd oil change and the next draining of oil shouldn't be as messy as this one!
  16. S3AMJ
    S3AMJ OEM+
    2,091
    727
    Fingers crossed you get it broken in, in time dude! Mines going in for its work with Bill two weeks before my birthday. That’s my birthday treat to myself, finally getting it done and on the road :D
  17. IPG
    IPG Registered User
    1,841
    778
    Yeah that was the plan but it’s deifnitley an impossible task. Will go go karting or something instead haha
    The intake bodge - which goes from the 2.8MAF that is taped onto the intake pipe that has an unused breather port near the TB
    Found the proper sized MAF (from a mk5) which luckily came with the
    Intake pipe that eliminates the unused breather/sensor.
    I did try to fit this heatshield for using the pod but clearly it didn’t fit. Got to think of a way to make that work...
    So this was one of the last three codes to get rid of. Both rear o2’s not working so well so I set out to find a definition for the me7.1.1.
    Couldn’t find one but I did find an excel file giving the addresses. Found all the ones
    related to deleting the above error, plugged the addresses into a modified definition from the 7.5 and, checksummed and tried out the flash ... next thing you know
    Down to the final error to sort!!!
    <tuffty/> likes this.
  18. IPG
    IPG Registered User
    1,841
    778
    19475 - Valve for Exhaust Flap 1 (N321): Open Circuit
    IS GONE!!!
    *happy dance*
  19. Stuart B
    Stuart B Registered User
    3,448
    743
    Winner... finally got your s3 up to 250bhp..
    :D
    IPG likes this.
  20. IPG
    IPG Registered User
    1,841
    778
    Well I’ll put the stage 1 tune on there and see how that goes too.
    Have found a wheel bearing needs replacing
  21. IPG
    IPG Registered User
    1,841
    778
    and have just gassed up my a/c - the compressor that i got with the VR6 seems a tad tired. I never charged it up before thinking that the 2.8 was only going to be temporarily on.
    Only blowing cold for 5-10 mins then it doesn't work anymore....
    Should've switched it out for the S3 one while doing the swap... hopefully my mech. won't charge the full amount next regas... *fingers crossed*
  22. IPG
    IPG Registered User
    1,841
    778
    Can anyone more “in the know” suggest how I could make the VR6 sound more wookie-ish?
    Currently the setup is 3” cat back, centre resonator and straight muffler ...
    2F820D73-A2D2-4B8D-BA46-E72855324E35.jpeg A920A158-DE39-4AD9-A95D-77CD0D545B21.jpeg C9C45D8E-40F8-45A4-8C3E-515A00657701.jpeg
    The car sounds great when revving on idle but when there’s load it’s quite muted and doesn’t really give that distinct VR6 Wookiee sound.
  23. superkarl
    superkarl MAN OF STEEL
    10,040
    2,677
    Do you have cats?
  24. IPG
    IPG Registered User
    1,841
    778
    Oem cats still there
    It goes
    - mildly ported headers > stock downpipes > cats > 3” cat back (as in pics) > mid resonator > muffler > twin outlet
  25. superkarl
    10,040
    2,677
    That must be the issue.
    As that would be a very high flow and audible cat-back system in any car
    Maybe Sandip will chime in, his had that classic ‘chewie’ sound you’re after
    IPG likes this.
  26. IPG
    IPG Registered User
    1,841
    778
    ahhh !!!! thanks for the refer ;)
  27. IPG
    IPG Registered User
    1,841
    778
    Slowly sorting out the coil pack conduit - blue’d the plug covers
    Tj 0785 and hydro s3 like this.
  28. Prawn
    12,096
    4,331
    Looking Smart Ian!
    When does the turbo go on? :racer:
    Sam_ likes this.
  29. IPG
    IPG Registered User
    1,841
    778
    So far. No plans. Breaking in has come to a halt because hub bearing needs changing.
  30. IPG
    IPG Registered User
    1,841
    778
    Finally!!!
    Ordered a hub pulled kit tool with the almost correct hub adaptor on it. Had to elongate it a holes a little. Then out came the hub with the inner race attached.
    Pulled out the rear of the broken bearing...
    And in goes the
  31. IPG
    IPG Registered User
    1,841
    778
    Tweaking the file to remove the Exhaust Flapper N321 error
    At address: 10A48
    You find: BC
    We change to: BF
    Commit the change, checksum > upload
  32. IPG
    IPG Registered User
    1,841
    778
    and getting rid of the rear o2's
  33. Avatar
    snack-media
    Advertisement
  34. IPG
    IPG Registered User
    1,841
    778
    Oil pressure checks @almost 500km since re build.
  35. badger5
    10,213
    2,380
    what ecu number/software is your motor dude?
  36. IPG
    IPG Registered User
    1,841
    778
    The ecu is from a 4mo bora. 24v
    Software I’m using is 022906032CN
  37. IPG
    IPG Registered User
    1,841
    778
    hehehe.. what thoughts you got up your sleeve?
  38. <tuffty/>
    24,336
    5,592
    Bills latest acquisition ;)
  39. Tj 0785
    3,828
    1,167
    Turbo build?
  40. <tuffty/>
    24,336
    5,592
    Probably not... Unless he tires of it and I put the engine in mine lol
    Supercharger was considered though
    Rainbird and IPG like this.
  41. IPG
    IPG Registered User
    1,841
    778
    <insert evil laugh>
    I have been using an excel file that outlines all the addresses and have been using it to make the definition. If that’s be of use to you let me know.
  42. badger5
    10,213
    2,380
    ah ok.
    I've *maybe* (lol) bought myself a TT3.2 for the noise... and possible further mods down the line
  43. IPG
    IPG Registered User
    1,841
    778
    hahaha i like the "...and possible further mods down the line" part!
    Nothing like that sound!!! Keen to hear your exhaust when it's on load ;)
