phil miller
In the boot drivers side is the CCM, ive had one before doing just this and it had water ingress, replaced it and it was bang on
No I never have, what difference would that make?When checking for battery drain are you removing your cable from the diagnostic port?
I didn't know that, thanks. I know normally it should be disabled when the car is locked, which I have been doing for the tests.I've read that sometimes the cable can draw power even though laptop is not connected. So if you're trying to rule out things I'd be disconnecting the cable to see if that makes a difference. I take it you're not disconnecting this when doing the tests so as its something that's not normally on the car I'd be disconnecting it when testing for power drain.
Anyone local to Gloucester that wouldn't mind me testing my unit in their car?Fit your climate control to other A3, and look if that car begin to drain current.
Perfect, thanks! How do the references on that drawing tie in with the pin assignments on the connectors on the back?If you go relay way, here is electrical wiring.
Perfect, thanks! The assignment con b pin 12 is what I was after, were you able to find that out from that drawing? The module only has connector and pin assignments on it.30 is battery (+).
Outside the control module you see many wires connections. Near everyone there is a corresponding letter and number of the connector and pin.
For example from line 30 power goes to F4/F6 fuse, then to F16 fuse, and then to connector B pin 12.
RIght back at the beginning of this I thought you said you had taken out the mods you made to put the seats in. Reading that thread it seems it wasn't straight forward and a module from a later car it's complicating matters.
Looking at ETKA if I read it correctly the part number for the correct AC panel is 8L0820043J.
Is that correct ?.
There are likely to me functional differences between the part you have and the one above.
There are several on Ebay but they all appear to be in Europe.
http://www.ebay.co.uk/itm/AUDI-A3-S...481092822?pt=DE_Autoteile&hash=item4189949ed6
Karl.
That's quite alright, easily done with this car!My bad about the parts number as you say your car is an early 8p.
I don't think Audi are correct in there assumption that the extra A means it has heated seats. The module you are trying to fit is physically bigger and a different format from a later car.
There are loads of AC module part numbers 220mm , 230mm single double DIN.
http://www.partsbase.org/audi/audi-...itioning-system-climatronic/#p-aud-8p0820043b
I think the part you wanted was 8P0820043C or G, At least it looks to be the same size with heated seats on, and has very similar options.
Karl.
Yes, I have the symphony 2 double DIN, there, all the single DIN units are wider as far as I know.If you look at the option codes associated with the unit
http://vag-codes.info/files/options/vag-option-codes.pdf
Apart from the seat heat options 4A0 means no heating 4A3, 4A4 is heating, the rest are related to nav or not and the kind of radio in the car. The original you have seems specific to the Symphony radio. You can get issues by mixing modules designed to work with other specific modules. Don't know if this is related to your problem but you would have been better off with a C or G part number in the first place.It could just be in this case the symphony is a narrower radio hence it's a physical size constraint.
Are the other radio systems in the A3 wider than the symphony ? is that why they have 220-230mm width units ?
Karl
TBH I suspect the problem is the wiring to the seats from the AC module may not be correct, It could however also be the module.
Does the battery still go flat when the seats are disconnected? Could you not refit the original module.
There are too many possibilities.
If you look back at the fuses supplied by that one you identified earlier fuse 16 looks to be the main power feed for the module and there was a good drop in current when that was disconnected.
Is there a fault code on the air quality sensor G238 ? is this at all related ?
Put the original unit back and see if all the codes are clear and if the car is taking less current.
Karl.
I will have a look tomorrow, thanksi told you to resolder the board near the canbus chip , this should restore comms . we have seen a few like this and it seems to be poor soldering . once the solder is re-flowed it corrects it , if youre an electronics engineer it should be no problems to you .
Sorry didn't answer instantly, but yes, everything I said is in the document. Just zoom in to see letters and numbers.Perfect, thanks! The assignment con b pin 12 is what I was after, were you able to find that out from that drawing? The module only has connector and pin assignments on it.
Ben
