MMI Basic Plus Navigation Disc Drive Unlock
Tay
Active Member
Hi,
I've been trying to help a friend with an A6, fitted with the MMI Basic Plus unit with Navigation (I believe). He's asked to unlock the Navigation disc drive to swap to a European Map disc while on holiday.
After trawling through the control modules with VCDS, all I've been able to find is in Navigation 37 - Adaptation Channel 64 will eject the disc once, but I'm trying to enable the disc drive to eject using the button.
I know this can be carried out using Adaptation channel 68 on a 2G MMI high unit, but does anyone know what needs to be coded for this unit?
Pictures of the set up in question.
Any ideas anyone?!
c4a5er
have you tried three zeros in channel 64?
c4a5er
i only say cos RNS E uses three zeros
c4a5er
RNS E actually uses channel 67 for the drive....do you have anything similar
Tay
Active Member
Nope 67/68 were both unavailable, 64 ejected the disc once when changes from 0 to 1, 65 didn't activate the eject button when changed from 0 to 1.
B5NUT
Well-Known Member
With VCDS what channel are you accessing the device on 07, 37 or something different?
Tay
Active Member
I had looked into 37-Navigation, 07-Control Head, and even tried the Media Players, and Central Electrics modules in the hope there may be a setting hidden somewhere in there.
B5NUT
Well-Known Member
So it response to both 07 and 37? I always hated MMI basic and thankfully only had to work on it a couple of times.
B5NUT
Well-Known Member
Think I have found it select Media Player 0E, select channel 64 and set the value to 0.
Tay
Active Member
Will that not be for the CD changer? I shall have a go and report back, in 37-Nav channel 64 did an once only disk eject.
Tay
Active Member
Okay thanks! Will the channel not need to be set to 1 as this is the case with Channel 68 of 37-Nav for a car with MMI High?
johnny_m
Hi Tay, Did you manage to get this to work ? I looked at this a couple of years ago as mine is locked too and didn't get very far !
Tay
Active Member
Nope got nowhere so far, I'm awaiting a response from Ross-Tech to see if they can shed any light onto the problem.
@udi A3
Well-Known Member
Did you do a reset of the mmi unit ? this definitely works.
Tay
Active Member
Yep I did this multiple times after attempting some of the coding changes
johnny_m
Yep Definitely works for MMI High...but not for basic plus. I have also tried it many times then gave up !
PawelM
Hey Tay, did you hear anything from Ross-Tech? I am new here and also have the same problem with Sat-Nav eject button. Audi in Glasgow quoted £45 to do it but I am condidering a VCDS which will be really pointless if it can't be done.
FactionOne
Administrator
Staff member
Administrator
Just thinking laterally... Long coding rather than adaptation?
R
PawelM
Hi Tay,
Refreshing - did you hear anything from Ross-Tech regarding the issue with locked eject button?
I have the same problem and need to know whether I just gave up or try to find somebody with VCDS who could do it for me?
Tay
Active Member
No positive answers from Ross tech, they only told me I was trying MMI high coding which I was well aware of.
PawelM
Hello again Tay. If your friend is still after unlocking the sat nav here is how i did it.
Last couple of weeks I have been on holidays in Poland where among other things I have managed to unlock my MMI Basic Plus eject button. I was adding rear parking sensors there and asked whether the guy who did it knew by any chance how to unlock sat nav. He did not know but could not sleep over night and called back next morning asking if it is ok for me to come back because he really need to try it. After 10 minuts a result and £50 asked by Audi Glasgow saved.
To do it you need to go to Media Player 1 (or Media Player 0E - as this was Polish version of VCDS I have no idea if the translations are accurate). Next - channel 65 to be changed from 1 to 0 and done. Only thing you need to rememebr is that the eject button only works with key in the ignition (red lights on the player are on) and you need to press and hold eject for couple of seconds.
I am now using 2012 maps instead of 2008 which in Glasgow makes a difference and I am happy.
Hope this will help somebody.
Trevski
I know it's a long shot but does anyone know how I can have the sat nav unlocked so I can change the country, I brought my s3 from Australia to uk but Audi can't unlock it to put uk maps on it
My car has the HD mmi system
Thxs
B5NUT
Well-Known Member
It's not just the case of unlocking the maps, you need to be running the EU version of the MIB software for the maps to run. Unfortunately I not sure if anyone has converted MIB modules as yet. Your quickest option would be to purchase an European 5F module for ebay and get component protection removed & maps enabled by an Audi dealer.
Trevski
is their a part number for a 5F so i can look on ebay.have you heard of this working as i have been tiold that once i buy a unit from ebay and have it unlocked as soon as i try to load maps from audi it works out that my mmi should be australian and then wont work
any help will be great
B5NUT
Well-Known Member
The online side of things won't work anymore, don't think you will ever get that working again. You will have to perform manual map updates. Don't have any part numbers, put a post in the A3 section someone can get a number off their unit via a VCDS scan. I would just look for a 2014/2015 unit on ebay, just make sure it has the same options as yours (dual SD slot's, SIM card slot etc).
Trevski
hiya
will google work on maps, would some one with a vag cable and software be able to unlock companent protection,how does audi enable maps
sorry to ask but you sound as you know electronics
thxs
B5NUT
Well-Known Member
You will get google maps on retrofit components, but the myaudi side of thing and download the free map updates won't work. CP & map activation on MIB components is dealer only. VCDS has never been able to remove CP or activate maps.
JNight
Know this is an old post, but didn't look like it ever got a clear fix, so....
This is for MMI Basic, which for this car was the red and black display.
I'll take it you all know to plug the VCDS gear in and make sure ignition is to red lights on>
First page gives "select control module"
Click
Next page gives tabs. First one says installed. I ran an autoscan first, but don't think it needs that.
So, Click installed and you should see the list of what your car has as installed modules.
This car had 20 installed entries, though yours may have more if you've got ectra factory options.
Most of the forums keep pointing us to 0E-Media Player, which I spent ****** ages trying to find the fix in there.
Wrong place!
Look for 5F - Information Electr.
Click
Now it should open that module and give you the Basic Functions and Advance Functions at the bottom of the sceen.
Look for Adaption - 10
Click
Drop Down bar in middle of screen - Documented adaption channels can be selected here -> click
Nice list of all channels.
Look for Ejection Lock
Click (double click)
Comes up with channel 18
Below this stored value
Below this new value
Change from 0 to 1
Test > Save
Done.
Hold down eject button on DVD unit.
If you're as lucky as me..... Out pops your DVD.
Result :)
Good luck.
JNight
Further images
