hello,
i'm doing a rebuild on my 1.8t APY and would like to know the maximum bore on which stock pistons can be used. I read in the workshop manual that for standard 80.95 mm pistons the bore must be 81.01mm, and for a repair oversize it's 81.45 mm piston and 81.51mm bore.
After 200000km the bore won't be 81.01mm anymore (i haven't measured yet) so according to the manual I need to rebore my block to 81.51mm if it's bigger than 81.01mm? but i don't want to spend a fortune on new over sized pistons or aftermarket ones.
So my question is what would practically be the maximum bore (less than 81.51mm) for stock pistons with not pre gaped rings?
Thank you
Thank you
