Hello,
I have an issue with my MMIS screen not coming out of the dash when the car is turned on. Due to this I don't have radio/bluetooth/sat nag/tv and on the drivers display screen when I try to go into the menu foray of the entertainment it says "Rado/Sat Nav etc is being initialised, please wait" and says that for the entire journey.
I have purchased a VCDS cable and ran the Auto-scan, cleared all faults down, ran the scan again and below are the errors I am left with
Does anyone have any ideas on the problem? Could it be a fuse that is stopping the MMI functions rom working?
I have tried to find reference to these fault codes on the Ross Tech site but nothing came up.
Code:
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Cannot be reached 0100
19-CAN Gateway -- Status: OK 0000
30-Special Function II -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 0100
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 0100
57-TV Tuner -- Status: Cannot be reached 0100
5F-Information Electr. -- Status: Cannot be reached 0100
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
82-Heads Up Display -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8E-Image Processing -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 G HW: 4G0 907 468 A
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000335076
Coding: 00CD077D00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 3461607C9F716EBE4F5-8061
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790346374
Voltage stabilizer:
5 Faults Found:
6151 - Instrument Cluster Control Module on Optical Bus
U10C0 00 [009] - No Communication
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 55762 km
Date: 2014.09.25
Time: 02:25:30
6221 - Control unit for information electronics 1
U1054 00 [009] - No Communication
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 55762 km
Date: 2014.09.25
Time: 02:25:30
6231 - TV-Tuner
U105C 00 [009] - No Communication
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 55762 km
Date: 2014.09.25
Time: 02:25:30
6226 - Radio
U1066 00 [009] - No Communication
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 55762 km
Date: 2014.09.25
Time: 02:25:30
6227 - Digital sound System control module
U106A 00 [009] - No Communication
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 55762 km
Date: 2014.09.25
Time: 02:25:30
End ---------------------------------------------------------------------
