Help wanted with VAGCOM fault codes
scal
Hi All,
I've run a scan on my "new" Audi A3 and have recovered the following fault codes. I have the Engine Management light on on the dash so I know there is an issue with the engine faults, however I dont want to change evergything! Does anyone have any suggestions as to:
1 - how to work out what the fault codes are exactly (Ross-Tech site wasn't very helpful here and not all the codes give a description!)
2 - Apart from the engine faults, how important are the others?
Thanks!!
VCDS Version: 17.1.0.0
Data version: 20170106 DS267.0
www.Ross-Tech.com
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels: 06F-906-056-AXW.lbl
Part No SW: 06F 906 056 BT HW: Hardware No
Component: MED9.5.10 00 5340
Revision: 00000000 Serial number: AUX7Z0C6FNT0HQ
Coding: 0000072
Shop #: WSC 06435 000 00000
VCID: 7CF792D53F3AF4A193-8028
Subsystem 1 - Part No: 06F 907 807 A
Component: NOX 0307300042 004 3608
06F907807A NOX 0307300042 004 3608
12 Faults Found:
18354 - Control Module 1 for Coolant Fan
P1946 - 004 - Defective - Intermittent
17833 - Unlicensed Version. Not all DTCs
P1425 - 002 - - Intermittent
17935 - Unlicensed Version. Not all DTCs
P1527 - 002 - - Intermittent
17923 - Intake Manifold Valve (N156)
P1515 - 002 - Short to Ground - Intermittent
17702 - Unlicensed Version. Not all DTCs
P1294 - 002 - - Intermittent
18068 - Unlicensed Version. Not all DTCs
P1660 - 002 - - Intermittent
17441 - Sensor for NOx (G295)
P1033 - 002 - Signal too Low - Intermittent
16575 - Unlicensed Version. Not all DTCs
P0191 - 008 - - Intermittent
17811 - Unlicensed Version. Not all DTCs
P1403 - 008 - - MIL ON
16825 - EVAP Emission Control Sys
P0441 - 008 - Incorrect Flow - Intermittent
17439 - Unlicensed Version. Not all DTCs
P1031 - 004 - - Intermittent
18322 - Unlicensed Version. Not all DTCs
P1914 - 002 - - Intermittent
Readiness: 0000 0000
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 HW: 8P0 820 043
Component: KlimavollautomatH11 0130
VCID: 69D9DB8140A8710978-803C
3 Faults Found:
01592 - Air Quality Sensor (G238)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 21
Reset counter: 114
Mileage: 94266 km
Time Indication: 0
Date: 2017.03.09
Time: 10:05:30
Freeze Frame:
Temperature: 18.5°C
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 39
Reset counter: 77
Mileage: 94249 km
Time Indication: 0
Date: 2017.03.02
Time: 11:03:36
Freeze Frame:
Temperature: 9.0°C
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 100
Mileage: 131072 km
Time Indication: 0
Date: 2032.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 6.80 V
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H27 0401
Revision: 00000000 Serial number: 00000000108020
Coding: 018C4F00A0141000000000000000000000
Shop #: WSC 00000 000 00000
VCID: 3B7551C97AB43399DA-806E
Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0180
Coding: 16711696
Shop #: WSC 00000
3 Faults Found:
01320 - Control Module for Climatronic (J255)
004 - No Signal/Communication - Intermittent
00466 - Control Module for Steering Column Electronics (J527)
00446 - Function Limitation due to Under-Voltage
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 008800186D288505485AC63000
Shop #: WSC 00089 210 12751
VCID: 79F98BC13008C18988-802C
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 1K0 907 719
Component: Neigungssensor 002 0002
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H01 0010
3 Faults Found:
01135 - Interior Monitoring Sensors
00323 - Unlicensed Version. Not all DTCs
004 - will be decoded. - Intermittent
01134 - Unlicensed Version. Not all DTCs
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H52 0060
Revision: 05S Serial number: AUZ2Z3C1317541
Coding: 0001001
VCID: 6FEDB5997E4C9F3926-803A
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 100
Mileage: 95526 km
Time Indication: 0
Date: 2017.05.14
Time: 00:00:42
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 104
Time Indication: 15
Freeze Frame:
Bin. Bits: 10
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 104
Time Indication: 15
End-------------------------(Elapsed Time: 01:43)--------------------------
going by what i am reading it looks like your Vcd's is not genuine the ( Cable i mean ) as it comes up in some parts saying unlicensed version so i would advise getting someone with a genuine Cable to run an auto scan and see if these faults are there and compare them to your scan .
Hi ch1z64, thanks for your reply. You are correct, it is an non-genuine cable, but in general the output should be the same no? (barring the fault code descriptions)
I am new to using these diagnostic tools, so the output posted above is what it returned before clearing any fault codes. I cleared them all recently and have done a few hundred miles since.
Focusing only on the engine faults (I'm not too worried about the rest... yet), today it returned 3 faults before clearing any fault codes and then only 1 fault after clearing the codes and re-running straight away.
Before clearing DTCs:
3 Faults Found:
17811 - EGR System
P1403 - 008 - Regulation Deviation - MIL ON
18322 - Pressure Sensor for Brake Boost (G294)
P1914 - 002 - Implausible Signal - Intermittent
17480 - NOx Sensor (G295) Heater Control
P1072 - 008 - Circuit Malfunction - Intermittent
Readiness: 0000 0100
Straight after clearing them and re-running:
1 Fault Found:
17811 - EGR System
Readiness: 1110 0101
What I do not understand now is whether the only actual fault I have is the EGR? I assume from what I have read that I need to either replace the EGR valve, just clean it and replace it or get a removal kit. The question is whether the "intermittent" fault codes for brake boost and NOx are an actual issue or just unhelpful errors due to the EGR valve?
i see where your coming from , so probably better to get someone with a genuine cable and updated vcd's software and get them to do a Autoscan and then that should tell you if the original faults you got using your cable are real or just errors that had not been cleared before you bought car .
There is a VCD's users map on here and usually the lads will help tou out for a few beer tokens , hope that helps
