So I got cruise control retro fitted the other day.
When I was driving home I had it on and was going up a slip road off the motorway and the brake pedal would NOT press in. I had to stand on it to get it to go in then it was fine. But I was frightened the car was not going to stop.
Happened a few more times when using cruise control so I decided to just leave it and it was working grand in normal driving.
So yesterday I changed my MAF and saw my badger 5 TIP was a bit loose so foolishly spent 4 hours trying to tighten it trying to refit about 7 times (stupid jubilee clip) anyway I got it on (looser than it was originally haha) and went for a spirited drive to see if it the MAF made any difference and if the TIP would fall of.
But as I was going up the back roads and I was boosting and braking into corners. Mid boost if I had to brake the pedal got incredibly stiff again. Is this some sort of vac leak or is it possible when they guy installing the cruise control hit something near the ecu wiper motor area?
The problem was 100% not there before.
Thanks in advance
Thanks in advance
