FMIC Vs SMIC!
Mr.Blonde
ESSEX
Im going to upgrade my intercooler soon and was just wondering which is better & the pros and cons of the FMIC & SMIC??
Fmic is simply better, purely because its getting the most air at the front,
BUT!...
There harder to fit than smic
Fmic also look alot better :)
im running both..with no issues 2 sides plus slim front one quite an easy install too, no crash bar cut, fogs kept, headlight washers kept, 63mm pipework 100% effiency
What fmic are you running dave? And if you don't mind me asking, how much did it cost? I like the sound of your set up, as I don't want to take out the bottom section of my front grill, or touch the crash bar...
im running all three to mate and set me back for all the kit £160 was well chuft
Hi
Do you have any photo's or links to where you got the inter cooler etc from?
Easy install???
Andy
I just bought a kit of ebay off an honda, any universal one will do , try to get the correct size piping 63mm
cost me about £100 all in
I've looked at that one too but it's too thinck to be able to fit without cutting the crash bar. It's also a little small height wise. Dave said there should be room for a max of about 225m.
The main problem is that all the coolers with 63mm in/outs are much bigger. We need to find a medium sized cooler with 63mm ends. Everything I've seen has been 57mm which would require a few reducers.
ever checked the pressure pre-1st intercooler vs @ manifold?
