Facelift FL RS3 has new brakes... again?
Arcam
AFAIK they have the same part number as the old ones!! What a fabulous idea Audi
Sent from my SM-N910F using Tapatalk
These are the new ones going on my car today, they should help with the high inside disk face temp.
Aoon_M
Yeah mine finally turned up the other day, they are the same part numbers still let me know if anyone needs a hand ordering
D0C
If I recall from previous posts he is indeed a track regular! Novice opinion as a road only user, but the brakes and steering are PFL weak points and good places to start when improving IMO.
Arcam
@Arcam - Are you a track day regular? I was just wondering why you tinker with your brakes so often :)
Like Doc said, I am a very regular track user and I over maintain my car.
I have just used another set of pads at the Nurburging last week so have taken the new back plates to fit as I have 2 days at Spa next month and brake cooling is even more important there.
Luc s1
I life in Belgium ...2 days at Spa??....when???
Macintosh88
Just read about an FL owner reporting Low speed squeal on his New RS3.
New style discs and at 600 miles.....
Do you know if the FL owner have the "new" disc? Have seen many FL RS3 who got their cars early this summer/autumn have those PLF disc... don´t know why but have seen that...
Snake Pliskin
Well-Known Member
Supporter
Just read the exact same mate.
Well that's it.
No way I will consider a FL now.
I have put up with brake squeal and weekly pressure washing of my discs to surpress the issue, there is no way I will consider another RS3 to then have to put up with it for another 3 years.
It is disgusting that Audi have not sorted this - it totally spoils the ownership experience.
I was hoping that what appeared to be a new style of disc had sorted it, but it appears not.
So it looks like I will have to consider an Audi S3 / S4 or Merc A45 or C 43 AMG next but no way it will be another RS3 after hearing this.
I am sure we will start to hear from other FL owners now starting to experience the same.
Can't believe it was on the 8P, then 8V and now the 8V face lift - terrible !
T
T-800
Guest
I Agree TX
Had no issues on my fronts when I swapped to Ferodo DS performance pads.
But that’s another story
Snake Pliskin
Well-Known Member
Supporter
After multiple pad & disc replacements in my 1st year of ownership (for squeal & warping) I aint fitting none Audi parts.
If the discs were to warp again, there is no way Audi would replace them if I have none OEM pads fitted.
Evotion
The Greed For Speed
I've had the black beast for a good few months now and it hasn't squealed once. (15 plate)
I assume I have standard discs and pads.. Then again, am on 13K miles now - how long do these things last?
D0C
Had a call from Audi today re my rusty hubs. They are going to paint my rusty hubs as a gesture of goodwill.
Had my oil warning light come on too, so I'll probably get it serviced at the same time as it's due in a month or two anyway. Will also get them to check the car over. Seems ever so slightly clunky to me when downshifting at low speeds. I know it's all the 4WD/Haldex gubbins, but still feels a bit baggy to me.
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
How bad is the warping?
S3 AD
The stupid damper things Audi attach to the back of the calipers ,that shouldn't be needed (and that made absolutely no difference on my 8P RS3) but Audi installed on my PFL 8V RS3 at the last service when I moaned about the noise again seem to have very nearly completely stopped the squeak on mine.
D0C
I've just had confirmation that when my car goes in for a service in a fortnight that I've got a FL RS3 with sports exhaust for the day.
I'm genuinely interested to see what I think of it. I never have a blinded loyalty to a particular car I own so hopefully I will be able to give a fair opinion on how it compares to my PFL. It will also have a pano roof which is about the only option mine is missing.
I've also got a drive in an M4 tomorrow with rain forecast. It will also be interesting to see what that's like in conditions that the RS3 would revel in.
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
Can’t wait to hear what you’ve got to say about both! Never know, could be the most expensive service you’ve ever had ;)
Snake Pliskin
Well-Known Member
Supporter
I had warping on a set of the 'wavy' discs.
These were replaced March this year with a set of optimised/ thicker circular discs.
This cured the warping, but the brake squeal still creeps in if I don't thoroughly pressure wash the discs once a week.
It is the pad compound Audi use which sheds loads of dust and sticks to the discs.
Loads of residue comes off when you pressure wash them.
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
I didn’t experience any squeal in the loaner I had, I did over 400 miles in that car (600 miles on it when I took it back).
I am tempted to look at different pads if I do get the issue, but will have to accept any warranty is then void.
I think I will pressure wash the discs as a precaution anyway.
Arcam
I like the new front brake cooling ducts along with the extra inner ducts on the FL bumper, the new TTRS does not get them which is a surprise.
Evotion
The Greed For Speed
Ah, I don't get much brake dust on mine. How would I know if I have aftermarket pads on it?
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
Having new pads shouldn't void warranty?
Only if they are aftermarket. Any disc issues and Audi will blame it on your choice of pads.
“Well Sir, Audi Genuine Parts Pads would not have warped your discs”.
KKOG
Which duct are you referring to?
Nr 2+3 goes together and is for the cooler only. Nr 1 maybe, as it channels air thru the bumper instead of around. This may help brake cooling a bit?
I´m surprised that it's missing the ducting on front underside of the inner fender as well as the ducting on the control arms. This was something that my old rs3 8p had.
Arcam
Duct 1, it feeds through to the inner wheel arch outer edge.
Aoon_M
TTRS gets them as part of the Audi Sport Performance Parts line.
Aoon_M
It is on the TTRS
Aoon_M
Perhaps it is a TTS calliper as the kit is available for both TTS and TTRS, but more expensive on the TTS due to missing parts from factory I assume
Arcam
Sounds reasonable, when specing a TTRS the Sports option is showing but on the detail tab it does not shown/mention the extra cooling.
beanoyip
Anyone heard the squeaks in the FL RS3? Possibly the rotors are still cold
KKOG
Yes. I get a bit of squeaking everyday for the past couple of weeks. :/
Gonna wait a bit before a drop the car at the dealer to fix it. Hopefully it goes away when I´m now over the run in period (930 miles) and start to drive it more enthusiastic.
beanoyip
Drove the whole day today and didn't hear a squeak at all...
Christurbo
Well that's it.
No squeal on my Facelift. I suspect not bedding them in properly. Treat them with varied braking from easy to hard.
Snake Pliskin
Well-Known Member
Supporter
Definitely NOT that !
Each new set of discs & pads has been run in to a specific procedure by the Audi Tech at the Dealership over approx 3 hours ... I had to agree to this 3 times now otherwise risk them saying exactly that.
When my car was brand new took approx 2 months for the initial squeal to kick so don’t jump the gun too soon, especially as some face lift owners have already reported squeal.
The RS3 brakes are $hi7 and let an otherwise superb car down.
