Hi all.
Been having some issues breaking outer CV joints as of late. I'm currently running the bolt style of outer CV, but am now considering running the Stud and nut type hoping they will be solid rather than hollow and be a bit stronger?
I've broken a mixture of genuine joints as well as a cheaper aftermarket alternative. They had been fitted to the correct VAG specs. I had tried not tightening them quite so much to put less preload against the joint which also failed this weekend.
Does anyone know if the hubs etc are identical for both style of fitments before I start buying bits?
Also on the off chance anyone know if the stud type are solid or also hollow inside the splined part of the joint?
