Basils had a S3X change :D
Yeah loads but this young man ( the only Shepard in bali aside from military dogs) is much more useful for keeping evil out of the house :smilingimp:
IMG 1060
Reactions: SHUk and tcg
Finally made a headunit decision so double din conversion will commence shortly following @IanPG guide :D
IMG 3290
Also this happened :D
IMG 3278
And on its way a custom stainless steel decat exhaust :)
No pics yet as royal fail still have it somewhere !
Reactions: IPG
Finally managed to get round to my double din conversion:)
What was coming out
IMG 3330
Actually out
IMG 3331
The new headunit has blueteeth therefore a mic for phone calls which I've mounted in the factory place :D
IMG 3349
After cutting off the mounting lug
IMG 3351
Goes here
IMG 3352
Like so
IMG 3353
I used "75x" which a search on here showed up as the best ignition live :)
Under the tray below the steering wheel .
IMG 3416
For anyone with non bose rear amplified like me you need "PC9-401"
IMG 3423
All done :) sound 1000000% better than what I took out , well pleased and lights up red and white like the dash clocks :D
IMG 3421
Reactions: Mav190sline
You'll find that vcds cable will be worth everything you paid for it and then some!!!
Reactions: Tj 0785
A small update !
1st mot due since I bought it .
Months ago I had someone put the car on VCDS to discover what was intermittently wrong with the haldex and headlight levelling .
The levelling was front sensor so I ordered one
54C89F57 9A19 4CCA 99AD 39173D0E6C66
Which has solved that problem :)
Haldex came up as brake light switch which I chose to ignore as the brake lights worked !
DB7C76C0 200E 4194 9117 CABABDAD6615
Sadly though at the time of my MOT they didn’t !!!!
Euro car parts to the rescue inside the time taken to test it so NO fail or advisory’s :D , brake lights and haldex now as they should be :D
74D0B11C 6C7B 4B99 B89F CD454B660080
Now the bad news !
Mentioned a while ago I secured myself a nice custom exhaust off a face-ache group .
While at the MOT garage we decided to chuck it on , it’s too short !!!!!
It’s going back up for sale to fund a non res miltek at least that will fit properly without bodging !
So this arrived :D
D2934C92 56A5 4E2E B1BD F94DE1B160DB
Cracked straight on
1BAC5CCA 9DE9 49D6 97CA 29816C8C681A
CEB723C0 0122 4AB0 B408 82AED54AF0BD
EA44AC9E 1DDC 4413 B228 193C57A7DADE
Took this opportunity to fit the DIY polyurethane gearbox mount kindly donated by a member of a Facebook group :)
E0026243 2541 41E5 A53E 0EC5BAD09B90
Not before time either, the old one flops about like a sausage in a top hat !
did you run out of pictures! where's the new mount? how's the new TIP?
Ha ha , it was all back together when I realised I didn’t have a mount photo :)
The mount is questionable !
It gives a lot of vibration , I LOVE how direct it’s made the gear change ,the old mount was knackered so MAY go back to a standard new one with a yellow dogbone?
It may grow on me and not being a daily could put up with it , only time will tell ?
The TIP was easier to fit than I’d anticipated, I was concerned about access down at the turbo end but using a 1/4” drive ratchet with a 7mm socket to do the jcs clip up and the same ratchet with a 2mm Allen bit made the grub screw a doddle when at the 3 o clock position.
On the road I can’t tell any difference at low to medium revs (1500-4000 rpm) however over 4500 rpm there is much less of a drop off in delivery .
Ultimately this was always meant to be a small piece of the bigger puzzle .
My end game is 350 ish bhp with a strong torque curve so breathing “will” be everything , it came up cheap so took the plunge .
It’s made a difference to my otherwise stock engine and can only help once I’ve gone hybrid k04 .
Loving this thread bud. Very inspiring and potentially costly for me as I'm hoping to get my wee S3 on the road again. Nowt wrong with it, just using the big car but that'll be getting sold in a few months. I see you have access to a garage and pit. Do you reckon I could do most of this stuff with a set of axle stands?
Yes but obviously makes it a tad harder but if your not restricted on time is no real issue .
Everything I’ve done I would do on axle stands if the pit at work want available to me !
Most of the things I’ve done have taken a LONG time as I’m constantly gathering bits when they crop up cheap !
Look at the dates between finding the double din console for no money and actually fitting it !
A because I couldn’t decide in headunit . And
B once I did I wanted it to be as cheap as possible !
The brakes I’ve just bought were shocking but cheap . Add blasting and painting to that and a seal kit and they’ll still be cheap :)
Bit by bit is my approach .
I have stashed nearly all of the front suspension components but wound be fitting them until I have it all :D
But most importantly doing it all myself ensures it’s done properly and is also where I get the most enjoyment as my S3’s my hobby , I have a caddy van for daily use so doesn’t really matter how long it all takes :)
4A6ED61A 19C7 4893 8D0F 9FA08E27A672
Reactions: hydro s3
Great pics and mods basil brush 350 is very achievable with the hardware you have..
Loving the brakes aswell.
Wow there's a s3 8l in bali must be super rare also.
Errrr no !
My S3 is in England !
My dad lives in Bali which is why I was there in June .
350 isn’t happening until I have fully sorted the chassis and done rods and valve guides and inconel valves
Errrr no !
Sorry buddy England it is lol yeah know what you mean got to take major organs out first to get power up been toying with the idea of some cheap quality rods..
Eventually got round to these !
6B639EAC F13F 430A 9587 721DC933785A
A shocking state and painted with no thought to masking anything whatsoever ! Still they were cheap :)
The fitter at work has some sort of blasting contraption at home so asked if he’d strip them for me ready for painting , case back in the next day done and ready for primer :D
843F226D 5B9C 4A20 9526 8C07BEC9C3F1
Colour next , keeping to the understated theme no red here :)
24E8988D EC72 4279 9B04 D10122F0C54B
New set of decals , seals and nipples !
1D50EE03 7979 48A2 8F13 94408FD66656
Decals lacquered on :)
DF49CF89 81E3 4661 8438 B4D53E18F8D1
Seals in
A04B4165 440E 49BF A5F1 0DC16490232E
Finally on the car complete with some Facebook group spacers (15mm)
A2E358A8 BF0E 46C8 9FAA E63A975788A8
Everything was going so well until I went to connect the Leon cupra R brake pipes to the Audi hard lines that come through the inner wing !
They physically connect no problem but the round boss of the flexy won’t go through the support bracket that’s welded to the inner wing !
Anyone who reads this with any ideas would be appreciated:)
46992C60 4D08 47CD 83A1 70654FB3F3E9
Amazing pics basil them brakes look super grippy nice recon job they look brand spanking lo
The exhaust will make a little of difference I'll be wanting one of those one day my back bits oem downpipe decat etc
The brembos are AMAZING !
The massive difference is almost certainly heightened as I’m convinced the old pads on the 312 set up had gone hard , they were shocking !
These however rearrange my face every time I brake hard !!!!
The postman’s just been and given me a piece of the next little mod !
I already have injector cups , phenolic spacer and injector seals ready so asap the inlet manifold will be off and wrinkle finished .
Just need to order an ultrasonic cleaner quickly !
ED4564C5 347A 438E 8361 67B8B8E52227
Been umming and arrring about these for a while along with an oil top up bag for the boot , kind of just a finishing touch but kept putting it off due to cost .
This came up as an auction with free postage and won it for just £2 :)
New and unused !!!
Oil top up next and the Audi boot bag to put it all in :D
14F05267 8B9F 4C4A A24C 75DF57C700F6
CED7540F F990 44F2 8EDC 82F84B2A7372
Now the Audi is very far from a daily , infact it only gets driven 1 or 2 times a month just to remind me how slow a non turbo VW caddy actually is !!!
Twice now I’ve come to blow the cobwebs off to find the battery is flat , probably not helped by all this cold weather ?
I’ve invested in an optimiser to A stop my battery from failing and B make sure it starts when I want it too !
65AFBA66 6C45 4A77 9DCC D6AE3D9CFE26
It’s all hard wired in so the battery cover won’t have to be on and off :)
Sad looking battery clamp :(
C5360889 0B91 4A48 B489 5EDA0177BB08
C952897F C93F 4233 AE19 311E0E4117E2
Easily sorted with the trusty wire wheel
6332BA1B 0874 469C 8E26 C585229A4712
07DEFE20 5067 4867 B065 0041DE839B0D
A trip to the fastener shop came up with A2 stainless goodies :)
D865A652 BD90 40C2 9E58 C4A1DB44782E
1A8C88A2 8D52 4528 B4D1 3BC0B3FAC876
Clearly In need of some G101 and a detailing brush !! That can wait until Easter weekend :)
6D1A1CFA 8159 4F13 9F5D B4A5B58FA5E8
More A2 goodies
802FC980 BD7D 46B4 A48E 9815B03389BC
Between being busy with work I’ve got round to the inlet stuff that I’ve had nearly a year to the day !!
Cracked on
C6147D8B B3CA 45E4 B1C3 99B4C43484BB
And
9D7432EE 8436 45F1 8CA4 1E065F3C1A5C
Good stuff :)
8155797D 0658 41A3 8954 535A423F89C8
B3517AE4 8083 43A3 8726 EC35C3817F6A
All new injector cups , note the special tool for winding them in (a ground down unf bolt )
E29ECEA5 89AB 4ED3 9FFC 57E22E6E5F1B
With a bead of RTV to prevent any boost escapes
0E57DEF5 E502 4FE2 A6A6 BFB9408CEB4B
Injectors sonically cleaned and new o rings
CB011AD1 640F 483D 8B3D 3788E9DE4DB5
The main purpose of all this was the inlet spacer (thanks to @StaceyS3 ) and the WMI spacer .
Took the opportunity to finish off the JCS hi grip swap to all clips while access was good .
1A6C8DA0 1F10 4DC5 A6E8 66EAAD9E12C0
Annoyingly the phenolic spacer doesn’t come with washers (be warned) so had to pop out as is usually the way when doing things :D
E5A52F58 F431 40DE 85D0 AD5D1519C4C9
Very happy with how this turned out :)
C7BB64D1 B8A3 4B83 A4AC 0EE934A241C2
Next on the agenda is the long overdue front suspension refurb along with hunter alignment I’ve just got to decide if I want to lower it or not !!!!
Impossible decision :)
Lastly this makes me sad :(
12E89F98 0EDC 403A A4AA 384F7CE3EB31
But now I’m happy :)
CBDCC5CF ECC5 408A 882C F4A7D58C48C1
Reactions: StaceyS3 and SamHendry
Cracked on
And
Good stuff :)
Looking great!!
Never put the user name and the face together until now
In :)
E15557F8 A487 480D 8786 C2099650B393
B423150E E2BA 419A B188 1D8D054B053A
8C843198 03C4 4DB1 A787 3B0EAD18F556
Thank god work has a plasma cutter :D
D5EC20A0 E693 46F4 ADEA A06E1AD1EB7A
My solution to not being able to hold the bolt head in the box section
817067B9 3285 42B0 9137 D74C38400712
2B9B4619 E718 476A A3A5 0A8BD88D30E4
C2463502 E1CF 4DF8 816D 5B23EC8A0D80
N/S plumbed in with 2x 63mm 90’s and a 75mm straight connector and O/S with a 63mm 90 and a hard pipe 90 straight to OE
Hats off to the designer :D
Only thing to watch out for is the bit of angled ali at the bottom of the cooler... seems that in the more 'wintery' climates of the UK the salt from the roads can collect there and corrode the bottom part of the core causing a leak...
I didn't design that bit :)
Just make sure you clean it... did think of grinding the lip off or similar... as long as the water can drain and not collect it would be fine...
Today is going to mainly consist of the following :)
5A5B2631 E2C2 4CF3 B1C1 60D5EEE17E93
Bit dissapointed the new hoses don’t have the mid way boss to clip into the clamps on the dampers :(
Making the ming flake pop in this sun will cheer me up :)
A89BCB8E 0644 4937 AA67 93CF240F2041
And at the same time as the AH V2happened I managed to end up with these 550’s too , into the stash box ready for mapping day :D
066D672B 8AEF 4ED8 B99F 2BE46CFF608F
Reactions: scotty_24
Looks a well designed bit of kit that ;)
@<tuffty/> given this is so well designed would you please take a minute to explain where I have gone wrong ?
Trimmed the fog light mounts but am still left with the inlet and outlet of the cooler touching the bumper with at least 2” to go at the bottom before I can get the bumper screws back in !!!
Ta Baz :)
490BB61D 5B75 4167 ACE5 892D1786A086
925E9E95 08F9 45A9 B5BF 6FE404EFE960
9755C81D 6954 41A1 879C 0BEDE742D64C
FMIC may need to sit a little lower as the pipes should tuck more into the gap below the front grille trim... I used two or three washer to pack it down from the crash bar... FMIC essentially has to sit on the lower part of the bumper so the pipes will tuck as far under as they can...
I believe I also trimmed a little more off where the pipes touch (as per your pic) so you have the depth of the fog grille before you encroach on the painted part of the bumper... I didn't take mine right up to the edge but enough that I had more clearance
As for the bottom screws... you will never get them to line up with the original holes... I got the bumper sitting right (with the aforementioned tweaks) and then marked up new holes.. drilled them and slotted the slam panel to allow the captive nut to realign with the new hole
12
37
3K
949
