Basils had a S3X change :D
It's the little touches :)
Before ...
IMG 1274
IMG 1275
IMG 1276
I painted something :D
IMG 1226
After ....
IMG 1278
IMG 1279
Appeased my OCD for a day or two :D
So !
IMG 1286
Easiest way I've found of removing these stupid things ...
IMG 1287
Then
IMG 1288
Leaving this , for this
IMG 1289
Insert screwed in
IMG 1290
Finished :)
IMG 1291
Lastly a small clue as to what tomorrow is going to involve !!
IMG 1285
Today brings this !
IMG 1304
Then
IMG 1305
Finally
IMG 1306
The pick up wasn't as bad as I was expecting however the sump looked like it had been used to cook roast potatoes every day for 13 years !!
Carbon crust all over it , quick cup brush in a die grinder sorted that out :)
Glad I've got that job out of the way for a bit of piece of mind :D
Now on the very few occasions I've driven the car I've felt disappointed in the headlights !!
Bright enough just not pointing where they should !
A couple of weeks ago I checked both level sensors were attached (they are) and today while in the workshop I've put the ignition on and lights and sat and bounced on the slam panel , no sound or vibration from the adjuster motors !! :(
Any way to check if it's the motors themselves or a level sensor and if so which one ?
Reactions: Jay 01 s3
I've been risking a ban long enough now so thought it time to get rid of the split a*se !!
IMG 1580
Found this !!
Not unexpected to be fair given the cars age and mileage , still annoying as now waiting on parts !
IMG 1581
All the sh*t removed :D
IMG 1582
Parts wait begins ...........
Parts wait over :D
IMG 1608
Also new 710"P" fitted (guess it's a revision or the original 710"N" ?)
IMG 1595
Lastly , I'm treating this as an opertunity to start fully jcs hi grip everything , hopefully keeping bill happy come re map time !
IMG 1594
Reactions: feck_on_a_stick
Been busy with work lately so basils had to take a back seat :(
But this weekend I managed to sort my wheels out that the last chimp hammerited !!!!!!
IMG 1777
IMG 1778
IMG 1779
IMG 1780
IMG 1769
IMG 1771
I forgot a before of the wheels but they can be seen in all their glory at the top of page 1 , what was he thinking ??????
IMG 1781
IMG 1782
Got some rear upper tie arm power flex bushes off a group on faceache , waiting on silver project adjustable tie arms and 20mm spacers before it all goes back together :D
IMG 1783
Reactions: feck_on_a_stick and Roadtrain
Much more pleasing to the eye :)
Still waiting on my adjustable tie bars :(
Now to move onto a front end spruce up , cookbot sleeves and more powerflex goodies , 15mm spacers then billies all round :D
IMG 1814
IMG 1815
Reactions: scotty_24
So after parking the car in the other side of the work car park it was quite clear something was amiss !!
O/S had camber N/S didn't !!!
So
IMG 2133
Trailing arm bushes , Hub end tie rod bushes , drop links , bilstein dampers , discs , pads and solid and flexy brake pipes on the way .
Time to clean it all up and paint stuff
:D
might as well drop the diff and subframe and give those a scrubbing too while you're at it! LOL
Great restoration on the wheels though!!! They're looking brand spankin'!
Reactions: basil brush
So !
Hub end tie bar bushes And the easy peasey removal/insertion tool :D
IMG 2190
Going in :)
IMG 2187
Trailing arm powerflexed
IMG 2188
This lot still to go on !
Brembo discs & pads flexy and solid brake lines , drop links , bilsteins and I've discovered the rubber pads at the top spring seat are mullered so I'll call the stealers tomorrow !
IMG 2158
Be rude not to clean everything while it's apart :)
IMG 2130
Reactions: tomjol, scotty_24, S3 Hilife and 1 other person
I just got this kit too! Hoping it does the big rear control arm bushes too
Looking good! Ive re bushed the back end too, car feels much better you will notice straight away!
Reactions: basil brush and tomjol
Started the passenger side to discover my wheelarch liner is split !
IMG 2200
No problem , I'll nip down the breakers and see if the still have the S3 .
IMG 2199
Got a new liner and an uncorroded tail gate trim with working release pads (only 1 of mine works !) for £20 :D
IMG 2201
Stripped , cleaned and protected the new pads
IMG 2202
IMG 2203
IMG 2204
IMG 2205
Reactions: IPG
do not tell anyone of this little treasure trove! hahaha
(do they have the headlight screws/spacers????)
Borrowed it from our fitter at work !
It's actually for a vectra but fitted perfectly :D
To be fair you could do the same job with 2 suitable sized sockets and M10 threaded bar and nuts and washers
Removal needs some imagination!
Don't use the all cup until the bush is half way out , the threaded bar isn't long enough to use both cups .
So removal is , big cup and thick washer to start it then take it all off again and replace washer with small cup .
Fitting is a doddle .
Hope that makes sense ?
Reactions: Crazypete00
Been a bit busy at work but I'm back now :)
Door blades needed a little attention !
The inner white nylon part had separated , I looked into and tried a repair but wasn't 100% satisfied so nipped down to the silver one at the breakers , half bingo ?
It had a near side one but no off side :(
So I took the near side one off him which turned out to be a lot lighter in colour than my ones !
No matter :)
Look much nicer and line up , winner :)
And got the chance to de crud the door bottom and wayoyl it :)
Done :D
Just need an off side one now !
Great job, you made these plastics new with Plasti Dip only, that's awesome!
Thanks :) it's easy TBH !
Right , after sorting the rear end (it's planted now :D )
The last thing was to bleed the brakes / change the fluid so I took basil to work and used the pit and vacuum brake bleeder , I've flushed 2 ltrs of dot 4 through the system and he's lovley now even if the brakes do feel crap !
Still researching front brake convertions and still undecided !
Anyway while under basil I discovered an engine oil leak , with further inspection it's the rocker cover gasket !
No drama .
IMG 2268
The old gasket is like robbies dog (well ard) broken in a couple of places too , this isn't a moment too soon !!!
IMG 2265
Mank and corruption here too !!!
IMG 2266
And
IMG 2267
All in soaking at the moment ready for a hot wash at work then using PT's secret formula I'm painting something :D
IMG 2269
Reactions: Roadtrain and Rainbird
We've had before , now some during and after .
All clean :)
IMG 2285
Etched
IMG 2287
Base and cleared
IMG 2295
While in there noticed what looks like injector seal failure mist deposits on the inlet runners .
As funds are limited due to my impending Bali trip I've put the front end refresh on hold until my return however I can stretch to injector seals and seats accompanied by a phenolic spacer, ultrasonic cleaner and inlet painting , I did forget to move my magnetic bowl when I took the seal evidence photo though (blonde moment :D)
IMG 2296
All face transitions sealed with the correct VAG sealant ( had it left over from my oil pump pick up change :) )
IMG 2303
Not one shred of evidence that I've put all this hard work in , but I know it's done which is what it's all about for me :)
IMG 2304
Good work mate.
You'll enjoy Bali,went there in '95 and it was paradise and the people were lovely.Just need to get your haggling head on as they offer you a 'good price,morning price' on everything.Even found myself haggling over the price of a can of coke!
LOL !
My dad lives there , will be the 1st time I've seen him since I was 6 !!!
Going to be a roller coaster , bit like owning an old S3
:tearsofjoy:
Reactions: IPG
Good work mate.
Can also vouch for Bali, went their 7 years ago. without a doubt the best country i have ever been to. The country as a whole is amazing, and the scuba diving is some of the best in the world. enjoy your time out there.
I thought I'd finished at the rear end , however these just happened (impossible to refuse at the price :) )
Need painting though :D
I've also ordered all the parts necessary to refurb my inlet manifold , new injector seals and seats , phenolic spacer , ultrasonic bath and wrinkle paint
IMG 2474
That's better !
Before is above ^^^
This is during (half hour on the wire wheel at work )
IMG 2508
Here's after :)
IMG 2513
note the 4 new dealer bolts !!
They are "inner" bolts as they're longer than the outers and given the fork end of the tie bars is thicker than OE longer bold are needed to enable the nyloc to actually reach the threads .
Here's the part numbers for anyone who wants some :D
IMG 2514
Back from Bali (what a place !!!!!!)
Bought off faceache before I left and the final piece of the interior is now done (well apart from fitting my double din but can't decide on a headunit !!)
Simple but makes so much difference
IMG 2708
IMG 2709
12
37
3K
959
