Hey guys, I’m looking to swap out my current clutch and can’t seem to find what clutch will be sufficient without spending more than I need to. Is it possible to just change the clutch disc and use the original pressure plate or is it just being dumb and cheap?
I’m going to do stage 2 after I changed clutch and there after build my own exhaust and intake.
I will probably not go further modding after this.
I would appreciate any kind of suggestions on clutches and if it’s necessary to replace something else once the transmission is off.
Base 265hp/195kw
ATM stock everything but with a stage1+ makes around ~300hp
Base 265hp/195kw
